Test existing nRF Connect project with nRF9151
Dear Nordic Support
We have an existing Project that uses the nRF9160 SoC and builds with toolchain v2.4.4 and SDK v2.4.4.
The project basically runs with the nRF9160 DK board (we derived a custom board with few changes and aliases).
Now I would like to evaluate our solution using the new nRF9151 DK Board. However, this undertaking is more difficult than originally assumed.
I tried to take the board definition of the nrf9151dk from the SDK v2.8.0 and add it to our existing custom boards. This seems not to work, as the board is not visible in the custom boards list in the board configuration dialog (when I switch the Toolchain and SDK version to v2.8.0 it appears).
Is there an easy approach to use the nrf9151dk board within the SDK v2.4.4 environment? (that would be the simplest solution for my purpose) (I also tried to migrate the project to SDK v2.8.0 but, so far, failed miserably)
I'm looking forward for your response. Thanks in advance for your support.
Kind Regards,
Stefan
    Can you specify where and how you added the definition of the nrf9151-dk board?
    Dejan
  • Hi Dejan
    Thanks for taking up my request.
    I did the following:
    • Copied the board files from the SDK v2.8.0
      (folder: \ncs\v2.8.0\zephyr\boards\nordic\nrf9151dk)
    • to the board folder within our project
      (folder: \work\YMR\ESW_BluePt_2\platforms\ele_test_hw_01\hal\nrf9151\boards\arm\nrf9151dk)
    Our local board folder is declared in the VS-Code workspace:
    		"nrf-connect.boardRoots": [
    			"${workspaceFolder}\\platforms\\ele_test_hw_01\\hal\\nrf9160",
    			"${workspaceFolder}\\platforms\\ele_test_hw_01\\hal\\nrf9151",
    As mentioned, the board appears when I switch to SDK v2.8.0 (but not in v2.4.4).
    BR, Stefan
  • Hi Stefan,
    You could try to build your project using command line and check during build process if the build system has picked up your board correctly.
    Dejan
  • Ok, after some other priorities I'm back...
    Once I figured out which environment variables to set, I could build the existing project (still using the nRF9160 SoC) via powershell CLI.
    Starting from this base I now try to build using the nRF9151DK board:
    /d /s /c "west build --build-dir c:/work/YMR/ESW_BluePt_2/applications/productsw/comm_uc/build3 c:/work/YMR/ESW_BluePt_2/applications/productsw/comm_uc --pristine --board nrf9151dk_nrf9151_ns -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/work/ymr/esw_bluept_2/platforms/ele_test_hw_01/hal/nrf9160;c:/work/ymr/esw_bluept_2/platforms/ele_test_hw_01/hal/nrf9151"
    returns error
