Gpio config input cause assertion & config missing dependencies
I use SDK v.2.6.1. To avoid other possible factors affecting the results, I only keep the simplest function in the code which is reading the potential of gpio every second and using log to display it on RTT. I have two questions and would like to ask. Thank you.
1. When setting p0.21 of gpio as input, the program will have an assertion error(as the follow fig). I have canceled qspi and i2c0 in the file .overlay.
At first I thought it was a bug in my program, so I modify the sample code zephyr/samples/basic/button and run it. But I soon discovered that this was not a problem with the code, because in the same code, when I set p0.27 as input rather than p0.21, the code could run normally(as the follow fig). I didn’t understand why! I knew that the comment CONFIG_ASSERT=y could Let the program run successfully, but this is not the result I want. How to make p0.21 an input pin?
2. In prj.conf, some configs will have missing dependencies. Will missing dependencies cause config settings fail?
(e.g. CONFIG_UART_CONSOLE was assigned the value y, but got the value n. Missing dependencies: SERIAL && SERIAL_HAS_DRIVER). If the setting fails, how to modify it to make the setting successful?
My prj.conf is as follows
CONFIG_GPIO=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_ASSERT=y
CONFIG_LOG=y
My .overlay is as follows
	zephyr,user {
		chrg_state-gpios = <&gpio0 21 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
/delete-node/ &i2c0;
&qspi_default {
	group1 {
		psels = <NRF_PSEL(QSPI_SCK, 0, 19)>,
				<NRF_PSEL(QSPI_IO0, 0, 20)>,
				<NRF_PSEL(QSPI_IO2, 0, 22)>,
				<NRF_PSEL(QSPI_IO3, 0, 23)>,
				<NRF_PSEL(QSPI_CSN, 0, 17)>;
&qspi_sleep {
	group1 {
				<NRF_PSEL(QSPI_IO3, 0, 23)>;
My main program is as follows
#include <zephyr/kernel.h>
#include <zephyr/device.h>
LOG_MODULE_REGISTER(Custom_Board,LOG_LEVEL_DBG);
static int ret, bat_chrg_state;
#define SLEEP_TIME_MS   1000
#define zephyr_user_NODE DT_PATH(zephyr_user)
static const struct gpio_dt_spec chrg_state = GPIO_DT_SPEC_GET(zephyr_user_NODE, chrg_state_gpios); // chrg_state節點
	if (!gpio_is_ready_dt(&chrg_state)) {
		LOG_ERR("chrg_state is not ready");
		return 0;
	ret = gpio_pin_configure_dt(&chrg_state, GPIO_INPUT);
	if (ret != 0) {
		LOG_ERR("Error %d: failed to configure %s pin %d\n",
			ret, chrg_state.port->name, chrg_state.pin);
		return 0;
	for(;;){
		bat_chrg_state = gpio_pin_get_dt(&chrg_state);
		LOG_INF("bat_chrg_state:%d",bat_chrg_state);
		k_msleep(SLEEP_TIME_MS);
    I am not quite sure about this one. Is it possible to upload the application that reproduces this error on a DK?
    Yes and no. It depends on where you see these warnings.
    When you see a squiggly line when modifying your prj.conf (or any other .conf file) those can be pointers to something that is wrong. But it may also be the parser in VS code being confused. However, when building, if you see the same message in the build log, it means that the config was not set correctly, because of a missing dependency. In this case, try adding CONFIG_SERIAL=y before CONFIG_UART_CONSOLE=y.
    Edvin
    1. I used the the MDBT50Q-DB-40, which I don't sure is it also DK? The application is produces this error on this "DK". Beside,I already made some custom PCB which also used nRF52840. Because I found this error on CB first, so I tried to reproduce this error on DK to check was my CB design wrong? And the DK did reproduce the error. So I thought the problem isn't the CB. It should something I don't know to cause this problem.
    2. In my main project, I have lots of missing dependency messages in my prj.conf. But when I build, I only saw "warning: PM" as the follow. Is that mean all of the config set except PM config assigned successful?
    warning: PM (defined at soc/arm/silabs_exx32\efr32bg22\Kconfig.defconfig.series:18,
    soc/arm/silabs_exx32\efr32bg27\Kconfig.defconfig.series:18,
    soc/arm/silabs_exx32\efr32mg24\Kconfig.defconfig.series:19,
    soc/arm/st_stm32\stm32f4\Kconfig.defconfig.series:20, subsys/pm/Kconfig:13) was assigned the value
    'y' but got the value 'n'. Check these unsatisfied dependencies: ((SOC_SERIES_EFR32BG22 &&
    SOC_FAMILY_EXX32) || (SOC_SERIES_EFR32BG27 && SOC_FAMILY_EXX32) || (SOC_SERIES_EFR32MG24 &&
    SOC_FAMILY_EXX32) || SOC_SERIES_STM32F4X || (SYS_CLOCK_EXISTS && HAS_PM)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PM and/or look up PM in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    About my PM config is as follow, I noted the CONFIG_PM=y is dependencies on CONFIG_SYS_CLOCK_EXISTS &&CONFIG_HAS_PM and CONFIG_POWEROFF=y is dependencies on CONFIG_HAS_POWEROFF.
    But except the CONFIG_SYS_CLOCK_EXISTS, the other 2 config not directly user assignable. How should I let CONFIG_PN & CONFIG_POWEROFF set successful?
    #           PM        #
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_PM=y
    CONFIG_PM_DEVICE=y
    CONFIG_PM_DEVICE_RUNTIME=y
    CONFIG_CRC=y
    CONFIG_POWEROFF=y
    Teson
  • The fact that the build log tries to set a Kconfig in a Silabs board is probably not a good sign. And as you can see, it fails to set it, because of the unsatisfied dependencies (which will obviously fail, because it is not a Silabs device.
    What board are you building for? Did you get these errors since the beginning?
    Is it possible to upload the application that you are trying to build, along with the build command? If you are using VS Code to build, it is possible to copy the build command by right clicking the build configuration and selecting "Copy build command". The copied command is quite long, but I can shrink it down on my side.
    I need to have a look at the project.
    Edvin
  • By chance, I ran into the same issue in another customer sample. You need to use
    CONFIG_PM_DEVICE=y
    instead of
    CONFIG_PM=y
    But for the rest of the questions, I need to see the application.
    Edvin
    Firstable, I am sorry. Because I am a newbie, so I have many question want to ask.
    Is the build log means messages which terminal showed when I click "Build"? And what is Silabs board? Is the Silabs board a specific model of board?
    I build on MDBT50Q-1MV2 which used nRF52840 SoC Solution (Revision 2 IC). No, I didn't see those errors.
    Sure! It's the application which I'm test as the follow "button.zip". Since I wanted to solve the assertion problem at the beginning, I did not write the configuration of PM, nor its functions. Now I've added the PM's configuration and written a k_timer to trigger sys_poweroff(). But I don’t know why putting sys_power() in the timer will trigger the assertion, so I annotated k_timer_start() first. Can sys_power() be put into k_timer and work successfully? Or is it prohibited?
    7178.button.zip
    I right clicking the build configuration, but I didn't see the "Copy build command". Did I right clicking the wrong place?
    You need to use
    CONFIG_PM_DEVICE=y
    instead of
    CONFIG_PM=y
    I have CONFIG_PM=y and CONFIG_PM_DEVICE=y before. Now I annotated CONFIG_PM=y and I did not receive the dependencies warning at terminal. My program can also run normally and sys_poweroff() also works normally. It seems that there should be no problem. Thank you.
