Gpio config input cause assertion & config missing dependencies
I use SDK v.2.6.1. To avoid other possible factors affecting the results, I only keep the simplest function in the code which is reading the potential of gpio every second and using log to display it on RTT. I have two questions and would like to ask. Thank you.
1. When setting p0.21 of gpio as input, the program will have an assertion error(as the follow fig). I have canceled qspi and i2c0 in the file .overlay.
At first I thought it was a bug in my program, so I modify the sample code zephyr/samples/basic/button and run it. But I soon discovered that this was not a problem with the code, because in the same code, when I set p0.27 as input rather than p0.21, the code could run normally(as the follow fig). I didn’t understand why! I knew that the comment CONFIG_ASSERT=y could Let the program run successfully, but this is not the result I want. How to make p0.21 an input pin?
2. In prj.conf, some configs will have missing dependencies. Will missing dependencies cause config settings fail?
(e.g. CONFIG_UART_CONSOLE was assigned the value y, but got the value n. Missing dependencies: SERIAL && SERIAL_HAS_DRIVER). If the setting fails, how to modify it to make the setting successful?
My prj.conf is as follows
CONFIG_GPIO=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_ASSERT=y
CONFIG_LOG=y
My .overlay is as follows
	zephyr,user {
		chrg_state-gpios = <&gpio0 21 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
/delete-node/ &i2c0;
&qspi_default {
	group1 {
		psels = <NRF_PSEL(QSPI_SCK, 0, 19)>,
				<NRF_PSEL(QSPI_IO0, 0, 20)>,
				<NRF_PSEL(QSPI_IO2, 0, 22)>,
				<NRF_PSEL(QSPI_IO3, 0, 23)>,
				<NRF_PSEL(QSPI_CSN, 0, 17)>;
&qspi_sleep {
	group1 {
				<NRF_PSEL(QSPI_IO3, 0, 23)>;
My main program is as follows
#include <zephyr/kernel.h>
#include <zephyr/device.h>
LOG_MODULE_REGISTER(Custom_Board,LOG_LEVEL_DBG);
static int ret, bat_chrg_state;
#define SLEEP_TIME_MS   1000
#define zephyr_user_NODE DT_PATH(zephyr_user)
static const struct gpio_dt_spec chrg_state = GPIO_DT_SPEC_GET(zephyr_user_NODE, chrg_state_gpios); // chrg_state節點
	if (!gpio_is_ready_dt(&chrg_state)) {
		LOG_ERR("chrg_state is not ready");
		return 0;
	ret = gpio_pin_configure_dt(&chrg_state, GPIO_INPUT);
	if (ret != 0) {
		LOG_ERR("Error %d: failed to configure %s pin %d\n",
			ret, chrg_state.port->name, chrg_state.pin);
		return 0;
	for(;;){
		bat_chrg_state = gpio_pin_get_dt(&chrg_state);
		LOG_INF("bat_chrg_state:%d",bat_chrg_state);
		k_msleep(SLEEP_TIME_MS);
  • Can you confirm that you are not able to detect the interrupts on the P0.21?
    I can detect the interrupts on the P0.21 when I comments the CONFIG_ASSERT=y.
    You are using a custom board, right? If so, then you don't need to make any changes.
    Right. I see.
    So in that manner, yes, you have a custom board.
    Thank you. I understand.
    Try adding this to your .overlay file:
    I added, and when I build. There is an error happened.
    devicetree error: /aliases: undefined node label 'mx25r64'
    Here is my .overlay
    	zephyr,user {
    		chrg_state-gpios = <&gpio0 21 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>; // 27 work, 21 assertion
    /delete-node/ &mx25r64;
    And I try disabled qspi, but still error.
    &qspi {
    	status = "disabled";
    And if that doesn't help, can you please take a picture of the device you are working on and upload it here?
    Sure. The following is the board I use.
    This is my code. I delete the PM. Now there is only P0.21 interrupt. I cance the comments of CONFIG_ASSERT=y in prj.conf.
    4657.button.zip
    By the way, I misunderstood the meaning of 'annotations' and 'comments'.
    Sorry to trouble you all the time.
    Teson
    So you have the Raytac equivalent of our DK. In that case, I suggest you try to build for that board, instead of our board. That means, create a new build configuration, and build for the board raytac_mdbt50q_db_40_nrf52840, and replace your nrf52840dk_nrf52840.overlay with raytac_mdbt50q_db_40_nrf52840.overlay, and remove the reference to mx25r64 (I also couldn't build, but I didn't dig into why it didn't work, since it is not present on your board).
    Edvin
  • Thank you very much. I finally can use the p0.21 as input without ASSERT when CONFIG_ASSERT=y.
    Teson
  • Glad to hear that it worked!
    I'll close this ticket now. Open it if you have any related issues, or open a new ticket if you encounter any new issues.
    Best of luck!
    Edvin
