I have designed a PCB using the nRF52840 microcontroller and the MAX30001g ECG sensor. The sensor requires a 32.768 kHz clock signal via its FCLK pin, as shown in the attached schematic.
Here is what I have done so far:
- Connected a 32.768 kHz crystal oscillator to the nRF52840, as seen in the diagram.
- Configured relevant pins for the sensor.
Here is my prj.conf file:
CONFIG_LOG=y CONFIG_LOG_MODE_IMMEDIATE=y CONFIG_CBPRINTF_FP_SUPPORT=y CONFIG_SPI=y CONFIG_SENSOR=y # #debugging # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=y # CONFIG_SEGGER_DEBUGMON=y #mention this if you want to program in external board CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n #at_configuration #or # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y #or # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y #or # CONFIG_BOARD_ENABLE_DCDC=n
Despite these configurations, the sensor does not seem to be receiving the required clock signal. I also reviewed the MAX30001g datasheet, which specifies the need for this clock input.
Questions:
- What additional configurations are needed in the
prj.conffile to enable the 32.768 kHz clock output on the required pin? - How can I verify that the nRF52840 is generating the clock signal correctly?
Any guidance would be greatly appreciated!
- [MAX30001g datasheet]
www.analog.com/.../max30001g.pdf
