Hi:
In terms of hardware, I have replaced the audio IC with ES8388. In terms of LE Audio code, how can I replace the driver with ES8388?
Hi:
You need to direct this question to the manufacturer of the audio IC, unless you have any specific questions related to the nRF5340?
regards
Jared
The main controller I am using is nrf5340, please replace the audio IC.I don't know how to replace it in the code.
I understand. Usually the manufacturer provides a driver for their devices. A start would be to check if such a driver already exists. Next, you need to understand how the device works by reading the datasheet and correspondingly how the driver works. Then you can try to start modifying the demo code.
We can't do that for you unfortunately. But we can answer any specific question about our devices or the samples/demos that we have made.
regards
Jared
I have the driver for the audio IC, but I don't know how to replace it in the LE AUDIO demo.I want to know how to start in LE Audio demo?
Hi there,
We can't write the code for you, but the first step would be to go through the LE Audio demo code and understand how it works,
Exactly which of the LE Audio applications are you looking at?
regards
Jared
