Hi
We have a project previously built on NCS v2.6.0 and now we need to migrate it to v2.8.0
I see from v2.9.0 child/parent build setup is not supported and so we are planning to migrate to sysbuild from v2.8.0.
After looking into many references and documents we were able to build the project with v2.8.0 whereas we are facing delay in the execution.
We have DFU (SMP service) enabled in our project and the setup runs smoothly in the NRF52840DK whereas it is taking time (~1min) to run on out custom board with NRF52840 chip.
Both have the same controller and yet we are observing delay in application execution and that too long time (~1min)
Let me share my conf setup here for reference
# # Copyright (c) 2018 Nordic Semiconductor # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_BT=y CONFIG_BT_PERIPHERAL=y CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_ASYNC_API=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y # Below configurations to enable DFU # Enable mcumgr. CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_IMG_MANAGER=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_SECURE_BOOT=y CONFIG_SB_SIGNING_KEY_FILE="priv.pem" # Some command handlers require a large stack. CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_FLASH=y CONFIG_STREAM_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y CONFIG_REBOOT=y CONFIG_DISABLE_FLASH_PATCH=y # Enable nordic security backend and PSA APIs CONFIG_NRF_SECURITY=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_MBEDTLS_ENABLE_HEAP=y CONFIG_MBEDTLS_HEAP_SIZE=8192 CONFIG_PSA_WANT_ALG_ECDH=y CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY=y CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y CONFIG_PSA_WANT_ECC_SECP_R1_256=y # For key generation CONFIG_PSA_WANT_GENERATE_RANDOM=y
SB_CONFIG_BOOTLOADER_MCUBOOT=y SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="priv.pem" SB_CONFIG_DFU_ZIP=y
