Cannot read/write in nvs when gatt,Bt is active?
iam trying to write the data in nvs which i give input through GATT.i  can read and write in nvs when not using gatt,BT.
I have 2 codes,1 is working but without GATT and BT.
another 1 is not working with GATT and BT.
Working code prj.conf
CONFIG_FLASH=y
CONFIG_NVS=y
CONFIG_LOG=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_NVS_LOG_LEVEL_DBG=y
CONFIG_REBOOT=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_FLASH_MAP=y
CONFIG_CJSON_LIB=y
Non working code prj.conf
# Copyright (c) 2018 Nordic Semiconductor
#CONFIG_BOOTLOADER_MCUBOOT=n
#CONFIG_SRAM_SIZE=128
#CONFIG_SRAM_BASE_ADDRESS=0x20000000
#CONFIG_FLASH_SIZE=512
#CONFIG_FLASH_BASE_ADDRESS=0x00000000
#CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_LBS=y
CONFIG_BT_HCI=y
CONFIG_BT_ID_MAX=1
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_DYNAMIC_DB=y
CONFIG_SETTINGS_NVS=y
CONFIG_BT_SETTINGS=y
CONFIG_BT_HCI_VS=y
CONFIG_FLASH=y                 # Ensure flash storage is enabled if you are storing settings in flash
CONFIG_BT_GATT_SERVICE_CHANGED=y
CONFIG_BT_ATT_ERR_TO_STR=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_CTLR_ADVANCED_FEATURES=y
CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
CONFIG_JSON_LIBRARY=y
CONFIG_DK_LIBRARY=y
#CONFIG_PM=y
#CONFIG_PM_SINGLE_IMAGE=y
#CONFIG_PM_LOG_LEVEL_DBG=y
#CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
CONFIG_BT_GATT_DM=y
CONFIG_BT_GATT_DM_DATA_PRINT=y
#CONFIG_BT_ADV_PROV_TX_POWER=y
#bt Update Data Length and MTU
#CONFIG_BT_USER_DATA_LEN_UPDATE=y
#CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
#for import json
CONFIG_CJSON_LIB=y
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_NANO=y
#CONFIG_HEAP_MEM_POOL_SIZE=8192
#MTU update configurations
#CONFIG_BT_CTLR_DATA_LENGTH_MAX=100
#CONFIG_BT_BUF_ACL_RX_SIZE=251
#CONFIG_BT_BUF_ACL_TX_SIZE=251
#CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_PRIVACY=y
CONFIG_NVS=y
CONFIG_LOG=y
CONFIG_REBOOT=y
CONFIG_FLASH_MAP=y
CONFIG_SETTINGS_NVS_SECTOR_COUNT=3
working code partitions.yml
app:
  address: 0x0
  end_address: 0x78000
  region: flash_primary
nvs_storage:
  address: 0x7a000
  end_address: 0x80000
  placement:
    before:
    - end
settings_storage:
  address: 0x78000
  end_address: 0x7a000
  placement:
    align:
      start: 0x1000
    before:
    - end
sram_primary:
  address: 0x20000000
  end_address: 0x20020000
  region: sram_primary
non working code partitions.yml
app:
  address: 0x0
  end_address: 0x7e000
settings_storage:
  address: 0x7e000
  placement:
    align:
      start: 0x1000
    before:
    - end
sram_primary:
  address: 0x20000000
while initialise the nvs i got the following error,
[00:00:00.059,661] <err> flash_nrf: invalid address: 0x00080ff8:8
Error: Failed to write JSON data to NVS, rc=-22
in wrking code there is a separate partition for nvs,but in non working code there is not.i use the same build config for both the codes.is it because of enabling the GATT and BT?Please someone guide
    There is no fundamental issue with wiring to flash and using BLE in the same project. As you use NVS I assume you write to the NVS partition, and that is missing in the non-working partitions.yml. Did you use a static partition layout here, or was it not added? Do you get any information about it in the build log? Can you share that?
  • EDIT:
    yes,I use/add pm_static.yml..my build log
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    -- Application: C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs
    -- CMake version: 3.21.0
    -- Cache files will be written to: C:/ncs/v2.8.0/zephyr/.cache
    -- Zephyr version: 3.7.99 (C:/ncs/v2.8.0/zephyr)
    -- Board: nrf52833dk, qualifiers: nrf52833
    -- Found host-tools: zephyr 0.16.8 (C:/ncs/toolchains/2d382dcd92/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.8 (C:/ncs/toolchains/2d382dcd92/opt/zephyr-sdk)
    -- Found BOARD.dts: C:/ncs/v2.8.0/zephyr/boards/nordic/nrf52833dk/nrf52833dk_nrf52833.dts
    -- Generated zephyr.dts: C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/build/tx_chaneg_wout_nvs/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/build/tx_chaneg_wout_nvs/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/build/tx_chaneg_wout_nvs/zephyr/dts.cmake
    warning: PM (defined at C:/ncs/v2.8.0/zephyr/soc/silabs\silabs_s2\efr32bg22\Kconfig.defconfig:12,
    C:/ncs/v2.8.0/zephyr/soc/silabs\silabs_s2\efr32bg27\Kconfig.defconfig:12,
    C:/ncs/v2.8.0/zephyr/soc/silabs\silabs_s2\efr32mg24\Kconfig.defconfig:12,
    C:/ncs/v2.8.0/zephyr/soc/renesas/smartbond\da1469x\Kconfig.defconfig:39, subsys/pm/Kconfig:13) was
    assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
    (SOC_SERIES_EFR32BG22 || SOC_SERIES_EFR32BG27 || SOC_SERIES_EFR32MG24 || (SOC_SERIES_DA1469X &&
    SOC_FAMILY_RENESAS_SMARTBOND) || (SYS_CLOCK_EXISTS && HAS_PM)) (=n). See
    docs.zephyrproject.org/.../kconfig.html and/or look up PM in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    warning: BT_CTLR_ADVANCED_FEATURES (defined at subsys/bluetooth\controller\Kconfig.ll_sw_split:292)
    was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
    BT_LL_SW_SPLIT (=n). See
    BT_CTLR_ADVANCED_FEATURES in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: The choice symbol PM_LOG_LEVEL_DBG (defined at
    subsys/logging/Kconfig.template.log_config:20) was selected (set =y), but no symbol ended up as the
    choice selection. See docs.zephyrproject.org/.../kconfig.html
    and/or look up PM_LOG_LEVEL_DBG in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    warning: Experimental symbol BT_ATT_ERR_TO_STR is enabled.
    Parsing C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/Kconfig
    Loaded configuration 'C:/ncs/v2.8.0/zephyr/boards/nordic/nrf52833dk/nrf52833dk_nrf52833_defconfig'
    Merged configuration 'C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/prj.conf'
    Merged configuration 'C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/build/tx_chaneg_wout_nvs/zephyr/.config.sysbuild'
    No change to configuration in 'C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/build/tx_chaneg_wout_nvs/zephyr/.config'
    No change to Kconfig header in 'C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/build/tx_chaneg_wout_nvs/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/build/tx_chaneg_wout_nvs
    [7/7] Linking C executable zephyr\zephyr.elf
    Memory region         Used Size  Region Size  %age Used
               FLASH:      206244 B       504 KB     39.96%
                 RAM:       29240 B       128 KB     22.31%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from C:/Users/Sara/Desktop/NRF/tx_chaneg_wout_nvs/build/tx_chaneg_wout_nvs/zephyr/zephyr.elf for board: nrf52833dk
     *  Terminal will be reused by tasks, press any key to close it.
    pm_static.yml below,
    app:
      address: 0x0
    nvs_storage:
      address: 0x7a000
      placement:
        before:
        - end
    settings_storage:
      address: 0x78000
      placement:
        align:
          start: 0x1000
        before:
        - end
    sram_primary:
      address: 0x20000000
    Thank you. I wonder why the settings_storage region is not part of the Bleutooth application in this case. Can you send the generated .config for both your non-working (bluetooth) application and the working one? Or perhaps the full build folders for both so that I can have a look?
  • working build 1581.build.zip
    non working non working build.zip
    in non working code,error is below while initialise the nvs.........
    [00:00:00.017,883] <dbg> fs_nvs: nvs_recover_last_ate: Recovering last ate from sector 0
    [00:00:00.032,897] <dbg> fs_nvs: nvs_add_gc_done_ate: Adding gc done ate at ff0
    [00:00:00.041,503] <inf> fs_nvs: 2 Sectors of 4096 bytes
    [00:00:00.047,546] <inf> fs_nvs: alloc wra: 0, fe8
    [00:00:00.053,070] <inf> fs_nvs: data wra: 0, 0
    [00:00:00.058,380] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                fe 2c f9 6a 7f 36 22 2e  a0 79 c0 40 be 2c 03 20 |.,.j.6". .y.@.,.
                                                40 c2 f3 32                                      |@..2
    [00:00:00.090,728] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.098,907] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:00.120,819] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 254.63788 Build 573996906
    [00:00:00.132,934] <inf> bt_hci_core: No ID address. App must call settings_load()
    Bluetooth initialized
    [00:00:00.143,341] <dbg> fs_nvs: nvs_recover_last_ate: Recovering last ate from sector 2
    [00:00:00.156,921] <inf> fs_nvs: GC Done marker found
    [00:00:00.162,658] <dbg> fs_nvs: nvs_flash_erase_sector: Erasing flash at 78000, len 4096
    [00:00:00.260,711] <inf> fs_nvs: 3 Sectors of 4096 bytes
    [00:00:00.266,784] <inf> fs_nvs: alloc wra: 2, fe0
    [00:00:00.272,277] <inf> fs_nvs: data wra: 2, 24
    [00:00:00.277,679] <err> os: ***** MPU FAULT *****
    [00:00:00.283,416] <err> os:   Stacking error (context area might be not valid)
    [00:00:00.291,748] <err> os:   Data Access Violation
    [00:00:00.297,668] <err> os:   MMFAR Address: 0x20005abc
    [00:00:00.303,985] <err> os: r0/a1:  0x1dc9c047  r1/a2:  0xe1eb6cf1  r2/a3:  0xe5622bcc
    [00:00:00.313,140] <err> os: r3/a4:  0x4eac21c5 r12/ip:  0x7b07b752 r14/lr:  0x7fd4bf01
    [00:00:00.322,265] <err> os:  xpsr:  0xe9f43a00
    [00:00:00.327,789] <err> os: Faulting instruction address (r15/pc): 0x3adafb9e
    [00:00:00.336,059] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00:00:00.344,360] <err> os: Current thread: 0x20002b78 (unknown)
    [00:00:00.351,501] <err> os: Halting system
    Looking at the configs I notice that the non-working does not have CONFIG_PM_PARTITION_SIZE_NVS_STORAGE defined. Is the issue resolve by adding CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x6000 to your prj.conf? This is skipped by default when using settings.
