NRF CONNECT sidebar disappears in nrf5340 audio application
I'm using nrf5340 audio application in nRF Connect SDK v2.7.0.
It has been working normally, but today when I opened folder, the sidebar disappeared, as shown in the picture.
I didn't change any code or settings, and this happened suddenly.
I use other nRF Connect SDK versions and everything is still normal. Only SDK v2.7.0 has this problem.
Why does this problem happen? What should I do to get him to recover?
    Which other NCS versions have you tried to use?
    Is it that what is shown in the picture suddenly disappeared? Did you see this problem while application was opened?
    Is your issue reproducible? Can you provide steps for replicating the issue?
    Dejan
  • I have tried to use NCS v2.2.0 and NCS v2.6.0. Both of them are normal.
    I only have problems with NCS v2.7.0.
    Normally, I can see the sidebar looking like this.
    But now, when I use NCS v2.7.0, the sidebar looks like this.
    After I clicked Refresh Application, it changed to this picture.
    This is still not normal and will prevent me from building.
    Steps I use:
    1. Open nRF Connect for Desktop
    2. Open Toolchain Manager
    3. Open nRF Connect SDK v.2.7.0 VS Code
    4. File -> Open Folder
    5. Then I choose my nrf5340 audio application folder
    6. After opening the application folder, I found that the side column disappeared.
    The same steps, the same application folder, and the same NCS version have been working normally for the past few months. The problem of the sidebar disappearing suddenly occurred yesterday.
    I am not able to reproduce this issue. Do you see the same problem with NCS v2.8.0?
    Dejan
  • Because most of the application I have modified uses NCS v2.7.0, I do not plan to upgrade to NCS v2.8.0.
    Although I don’t know why the sidebar suddenly disappeared, I found a temporary solution.
    I created a new nrf5340 audio application, then moved the changes I made before to the newly created application, and then opened it using the steps mentioned above. I no longer encountered the problem of the sidebar disappearing.
    It seems that the applications I built before this week can no longer be used, and can only be solved by rebuilding them in the above way.
    For troubleshooting purpose, it is always useful if the issue is reproducible. Please let me know if the issue appears again and you need further assistance.
    Dejan
