If I initialize the IPC and then turn on the bt_enable, it will lead to the status quo in Figure 2, what is the reason?
If I block k_sem_take (&bound_sem, K_FOREVER) and the application core binds the network core unsuccessfully, the ipc sends back -2003, and the Bluetooth initialization can be enabled
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# CONFIG_PRINTK=y
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_MAX_CONN=2
CONFIG_BT_MAX_PAIRED=2
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more stack
CONFIG_MAIN_STACK_SIZE=1152
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=n
# CONFIG_RTT_CONSOLE=y
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_ASSERT=y
#主站
# Enable the BLE stack with GATT Client configuration
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
# Enable the BLE modules from NCS
CONFIG_BT_NUS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_GATT_DM=y
CONFIG_NCS_SAMPLES_DEFAULTS=y
#ADC
CONFIG_ADC=y
#FLASH
CONFIG_STDOUT_CONSOLE=y
CONFIG_FLASH=y
CONFIG_SPI=y
#IPC
CONFIG_MBOX=y
CONFIG_IPC_SERVICE=y
CONFIG_IPC_SERVICE_LOG_LEVEL_INF=y
CONFIG_IPC_SERVICE_BACKEND_ICMSG=y
Here's my config
