Hi Support Team
I want to install ZAP tool for NCS V2.8.0 that for Matter development. The command I use to install is pip3 install -r E:/ncs/v2.8.0/modules/lib/matter/scripts/setup/requirements.nrfconnect.txt. But it failed.
The path of the NCS V2.8.0 like the picture below.
The attachment is the log during installation.
PS E:\ncs\v2.8.0> cd E:\ncs\v2.8.0\modules\lib\matter
PS E:\ncs\v2.8.0\modules\lib\matter> pip3 install -r E:/ncs/v2.8.0/modules/lib/matter/scripts/setup/requirements.nrfconnect.txt
Requirement already satisfied: jsonschema>=4.4.0 in e:\ncs\toolchains\2d382dcd92\opt\bin\lib\site-packages (from -r E:/ncs/v2.8.0/modules/lib/matter/scripts/setup/requirements.nrfconnect.txt (line 1)) (4.23.0)
Requirement already satisfied: cbor2>=5.4.3 in e:\ncs\toolchains\2d382dcd92\opt\bin\lib\site-packages (from -r E:/ncs/v2.8.0/modules/lib/matter/scripts/setup/requirements.nrfconnect.txt (line 2)) (5.4.6)
Requirement already satisfied: ecdsa>=0.18.0 in e:\ncs\toolchains\2d382dcd92\opt\bin\lib\site-packages (from -r E:/ncs/v2.8.0/modules/lib/matter/scripts/setup/requirements.nrfconnect.txt (line 3)) (0.19.0)
Collecting qrcode==7.4.2 (from -r E:/ncs/v2.8.0/modules/lib/matter/scripts/setup/requirements.nrfconnect.txt (line 4))
Using cached qrcode-7.4.2-py3-none-any.whl.metadata (17 kB)
Collecting bitarray==2.6.0 (from -r E:/ncs/v2.8.0/modules/lib/matter/scripts/setup/requirements.nrfconnect.txt (line 5))
Using cached bitarray-2.6.0.tar.gz (102 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
[notice] A new release of pip is available: 24.2 -> 24.3.1
[notice] To update, run: python.exe -m pip install --upgrade pip
ERROR: Exception:
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\cli\base_command.py", line 105, in _run_wrapper
status = _inner_run()
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\cli\base_command.py", line 96, in _inner_run
return self.run(options, args)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\cli\req_command.py", line 67, in wrapper
return func(self, options, args)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\commands\install.py", line 379, in run
requirement_set = resolver.resolve(
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\resolver.py", line 95, in resolve
result = self._result = resolver.resolve(
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 546, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 397, in resolve
self._add_to_criteria(self.state.criteria, r, parent=None)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 173, in _add_to_criteria
if not criterion.candidates:
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_vendor\resolvelib\structs.py", line 156, in __bool__
return bool(self._sequence)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 174, in __bool__
return any(self)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 162, in <genexpr>
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 53, in _iter_built
candidate = func()
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\factory.py", line 186, in _make_candidate_from_link
base: Optional[BaseCandidate] = self._make_base_candidate_from_link(
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\factory.py", line 232, in _make_base_candidate_from_link
self._link_candidate_cache[link] = LinkCandidate(
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 303, in __init__
super().__init__(
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 158, in __init__
self.dist = self._prepare()
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 235, in _prepare
dist = self._prepare_distribution()
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 314, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\operations\prepare.py", line 527, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\operations\prepare.py", line 642, in _prepare_linked_requirement
dist = _get_prepared_distribution(
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\operations\prepare.py", line 72, in _get_prepared_distribution
abstract_dist.prepare_distribution_metadata(
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\distributions\sdist.py", line 56, in prepare_distribution_metadata
self._install_build_reqs(finder)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\distributions\sdist.py", line 126, in _install_build_reqs
build_reqs = self._get_build_requires_wheel()
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\distributions\sdist.py", line 103, in _get_build_requires_wheel
return backend.get_requires_for_build_wheel()
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\utils\misc.py", line 706, in get_requires_for_build_wheel
return super().get_requires_for_build_wheel(config_settings=cs)
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_vendor\pyproject_hooks\_impl.py", line 166, in get_requires_for_build_wheel
return self._call_hook('get_requires_for_build_wheel', {
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_vendor\pyproject_hooks\_impl.py", line 321, in _call_hook
raise BackendUnavailable(data.get('traceback', ''))
pip._vendor.pyproject_hooks._impl.BackendUnavailable: Traceback (most recent call last):
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 77, in _build_backend
obj = import_module(mod_path)
File "importlib\__init__.py", line 90, in import_module
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1310, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-t6zfd8nn\overlay\Lib\site-packages\setuptools\__init__.py", line 27, in <module>
from .dist import Distribution
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-t6zfd8nn\overlay\Lib\site-packages\setuptools\dist.py", line 19, in <module>
from . import (
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-t6zfd8nn\overlay\Lib\site-packages\setuptools\_entry_points.py", line 6, in <module>
from jaraco.text import yield_lines
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-t6zfd8nn\overlay\Lib\site-packages\setuptools\_vendor\jaraco\text\__init__.py", line 12, in <module>
from jaraco.context import ExceptionTrap
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-t6zfd8nn\overlay\Lib\site-packages\setuptools\_vendor\jaraco\context.py", line 11, in <module>
import urllib.request
File "urllib\request.py", line 88, in <module>
File "http\client.py", line 71, in <module>
File "email\parser.py", line 12, in <module>
File "email\feedparser.py", line 27, in <module>
File "email\_policybase.py", line 9, in <module>
File "email\utils.py", line 29, in <module>
File "socket.py", line 52, in <module>
ModuleNotFoundError: No module named '_socket'
PS E:\ncs\v2.8.0\modules\lib\matter> python.exe -m pip install --upgrade pip
Requirement already satisfied: pip in e:\ncs\toolchains\2d382dcd92\opt\bin\lib\site-packages (24.2)
Collecting pip
Using cached pip-24.3.1-py3-none-any.whl.metadata (3.7 kB)
Using cached pip-24.3.1-py3-none-any.whl (1.8 MB)
Installing collected packages: pip
Attempting uninstall: pip
Found existing installation: pip 24.2
Uninstalling pip-24.2:
Successfully uninstalled pip-24.2
Successfully installed pip-24.3.1
ERROR: Exception:
return any(self)
candidate = func()
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\factory.py", line 187, in _make_candidate_from_link
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\factory.py", line 233, in _make_base_candidate_from_link
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 304, in __init__
super().__init__(
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 159, in __init__
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 236, in _prepare
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 315, in _prepare_distribution
File "E:\ncs\toolchains\2d382dcd92\opt\bin\Lib\site-packages\pip\_internal\utils\misc.py", line 701, in get_requires_for_build_wheel
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-8i4su42r\overlay\Lib\site-packages\setuptools\__init__.py", line 27, in <module>
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-8i4su42r\overlay\Lib\site-packages\setuptools\dist.py", line 19, in <module>
from . import (
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-8i4su42r\overlay\Lib\site-packages\setuptools\_entry_points.py", line 6, in <module>
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-8i4su42r\overlay\Lib\site-packages\setuptools\_vendor\jaraco\text\__init__.py", line 12, in <module>
File "C:\Users\17546\AppData\Local\Temp\pip-build-env-8i4su42r\overlay\Lib\site-packages\setuptools\_vendor\jaraco\context.py", line 11, in <module>
