Audio distorted when BLE is connected
Hello, we have an android/iOS app on a phone that is connected to my button (nRF51) and to a Bluetooth headset. The app is a kind of walkie talkie that transmit mono audio every time you press the button. What is happen is that if the button is not connected the audio is ok, if the button is connected most of the time the audio is distorted!!! As soon as you turn off the button connection the audio is good again. We did many test and if you don't use the Bluetooth headset but the audio came out directly from the phone , there is no problem. Only if you have both headset and button connected you have the problem!!! There is something I can do? It is really the BLE button connection to use the Bluetooth bandwidth and make the audio distorted? Can I optimize something on my button?
thx
Enrico
  • Does this happen on both iOS and Android? What is the connection interval you are using? (Sound like a scheduler issue on the phone you are testing with).
  • Yes, this happen with both devices, MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) MAX_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS)
  • What exactly does this button do? does it only send an on/off signal? Or do you also send audio data from the peripheral/button?
    I have done some tests with BLE and audio on iOS. Normally I don't have problems with audio. But if I move away from the phone with the headset so I'm close to loosing the connection I get some distortion, and might end up loosing the ble connection. However, I haven't seen your problem before.
    Note that I don't think iOs will accept connection parameter request between 7.5 and 15 ms.
  • Hi, the parameters are corrects, because i have seen them on bluetooth guidelines of iOs...
    "If Bluetooth Low Energy HID is one of the connected services of an accessory, connection interval down to 11.25 ms may be accepted by the Apple product" .(developer.apple.com/.../BluetoothDesignGuidelines.pdf) page 22.. And I am able to connect with all iOs devices...
    This button can (raise and decrease volume);
    when i push the button I send notification at mine custom service and characteristic (0x01); when i release the button i send notification at mine custom service and characteristic (0x02).
    Is not a problem of distance, because the 3 devices are less then one meter distance.
    The problem has not a logic, is randomly.
    Sometimes when i open audio the "audio" is perfect, sometimes is very distorced.
    What connection interval do you suggest to use?
    What type of headset are you using? What type of phone, software and application are you using?
    Thanks for the time and the help Regands Enrico
  • iOS usually wouldn't accept a connection parameter request where min = 7.5 and max = 15, I would expect that these requests are rejected (you would still be connected, but running on slower conn events). Regardless you don't need this fast interval for a button implementation. I would suggest trying something closer to 100 ms to see if the distortion is still there. I don't think the user would notice that delay for a button press. The faster interval is mostly needed if you send multiple button presses e.g. typing.
1 2 3
