nRF Connect SDK v2.8.0 - Experimental option for multiple domains causes flashing issues on Thingy:53, resulting in bt_hci_driver failure
I have a Thingy:53 sensor hub application (extended the Nordic Thingy53 Sensor Hub blog to include IAQ sensor)  built under NCS v2.7.0 that runs fine.
When rebuilding the same application under NCS v2.8.0 without any code or build changes, the build is successful with no Bluetooth driver issues. However, when flashed to Thingy:53 I get the following errors.
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
00> rtt:~$ [00:00:00.007,934] <inf> BH1749: BH1749 initialized
00> rtt:~$ *** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
00> rtt:~$ *** Using Zephyr OS v3.7.99-0bc3393fb112 ***
00> rtt:~$ [00:00:00.035,430] <inf> main: main
00> rtt:~$ [00:00:00.035,491] <inf> main: Zephyr RTOS: 3.7.99
00>
00> rtt:~$ [00:00:00.035,491] <inf> main: thingy53
00> rtt:~$ Starting Sensor Hub application
00> rtt:~$ [00:00:01.036,773] <err> bt_hci_driver: Endpoint binding failed with -11
00> rtt:~$ [00:00:01.036,804] <err> bt_hci_core: HCI driver open failed (-11)
00> rtt:~$ Bluetooth init failed (err -11)
00> rtt:~$ rtt:~$
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
In nRF Connect for VSCode, I noticed the following for NCS v.2.8.0 flashing stage.
"WARNING: Specifying runner options for multiple domains is experimental.
If problems are experienced, please specify a single domain using '--domain <domain>'"
The above warning doesn't exist in previous NCS version.
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
Flashing build_vsc_ncs280/thingy53_ns to <jlink sn masked>
west flash -d /Volumes/QuarrkD/Current_Dev_IoT/2024_dev/thingy53_projects/thingy53_sensor_hub_v3/build_vsc_ncs280/thingy53_ns --skip-rebuild --dev-id 801017276
-- west flash: using runner nrfjprog
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: /Volumes/QuarrkD/Current_Dev_IoT/2024_dev/thingy53_projects/thingy53_sensor_hub_v3/build_vsc_ncs280/thingy53_ns/merged_CPUNET.hex
[ #################### ] 2.565s | Erase file - Done erasing
[ #################### ] 0.308s | Program file - Done programming
[ #################### ] 0.302s | Verify file - Done verifying
Applying pin reset.
-- runners.nrfjprog: Board with serial number <jlink sn masked> flashed successfully.
-- runners.nrfjprog: Flashing file: /Volumes/QuarrkD/Current_Dev_IoT/2024_dev/thingy53_projects/thingy53_sensor_hub_v3/build_vsc_ncs280/thingy53_ns/merged.hex
[ #################### ] 11.471s | Erase file - Done erasing
[ #################### ] 2.648s | Program file - Done programming
[ #################### ] 2.734s | Verify file - Done verifying
Applying pin reset.
The above flashing with the experimental multiple domains appears to cause Bluetooth driver issues, possibly as there is a build step for 'empty_net_core".
To verify that the application domain thingy53_sensor_hub_v3 built correctly for the NCS v2.8.0 build, after flashing the application with NCS v2.7.0 build, I flashed only the NCS v2.8.0 thingy53_sensor_hub_v3 domain from a command line session.
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
[16/18] cd /Volumes/QuarrkD/Current_Dev_IoT/2024_dev/thingy...toolchains/15b490767d/Cellar/cmake/3.21.0/bin/cmake -E true
Using board <masked>
[ #################### ] 11.087s | Erase file - Done erasing
[ #################### ] 2.667s | Program file - Done programming
[ #################### ] 2.748s | Verify file - Done verifying
Applying pin reset.
-- runners.nrfjprog: Board with serial number <masked> flashed successfully.
After above, the Thingy:53 application ran fine. There was no bt_hci_driver endpoint binding failure and Bluetooth initialized correctlyas shown below.
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
00> rtt:~$ [00:00:00.007,873] <inf> BH1749: BH1749 initialized
00> rtt:~$ [00:00:00.035,369] <inf> main: main
00> rtt:~$ [00:00:00.035,430] <inf> main: Zephyr RTOS: 3.7.99
00>
00> rtt:~$ [00:00:00.035,430] <inf> main: thingy53
00> rtt:~$ [00:00:00.051,422] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
00> rtt:~$ [00:00:00.051,452] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
00> rtt:~$ [00:00:00.051,483] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 214.51162 Build 1926957230
00> rtt:~$ [00:00:00.053,710] <inf> bt_hci_core: Identity: C3:A6:C8:C4:25:42 (random)
00> rtt:~$ [00:00:00.053,741] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x21fb, manufacturer 0x0059
00> rtt:~$ [00:00:00.053,771] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x21fb
00> rtt:~$ Bluetooth initialized
00> rtt:~$ Advertising successfully started
00> rtt:~$ rtt:~$
In the nRF Connect SDK for VSCode IDE, How can I disable the experimental runner options for multiple domain introduced in NCS v2.8.0 so that it is the same as in NCS v2.7.0?
If the above is not possible, What is the recommended fix in this instance for NCS v2.8.0 when building with nRF Connect SDK?  Thank you.
Ravi
