nRF9151 udp sample 5µA current consumption
Hi
I have tried to reproduce the 2.7µA current consumption stated in the datasheet. This webinar shows that the UDP sample reaches 2.7µA on the nRF9160 evaluation kit. However, on my evaluation kit I get 5µA average consumption. I can open the sim current jumper without any change in current, so the sim card should be shut off.
Do you have any ideas what could cause the additional ~2.3µA?
Kind regards
Samuel
Parents Reply
  • Hi Samuel,
    According to the chip designer, the previously reported values are within the “normal” variation range. For early A0A samples of the nRF9151, PSM floor current variations of up to 4.5 µA may occur in worst-case scenarios.
    Later versions of the nRF9151 exhibit less variation, and the worst-case scenarios seen in early samples should no longer exist. However, some variation above the typical 2.7 µA value specified in the datasheet can still be observed. It is important to note that unit-to-unit variation in this value is expected and inherent.
    Charlie
