Does Zephyr have a turnkey / drop-in solution for communicating between two processors via UART?
I am currently working through the nRF Connect SDK Intermediate training in preparation for an upcoming project. Said project will require communication between two physically separate processors over UART. Specifically, a nRF91 modem and a nRF52 BLE module.
From my research, it doesn't seem that Zephyr has a drop-in driver to facilitate communication between processors via UART, unless I am overlooking it?
Ideally, it would be as simple as enabling the driver, defining your UART pins, and defining the maximum payload size. The low level hardware and protocol framing would be handled by the driver. The message types and corresponding message payloads would be defined by the developer on the application layer. A callback function would return a pointer to the received payload (message) and payload size. Parsing and processing the message would be left to the application developer.
Does something like this not already exist? I would be surprised if not since it is such a common use case and given that Zephyr is meant to be a plug-and-play OS it seems. For reference, I have created my own version of this on FreeRTOS for the nRF52840.
I have seen SLIP, but this seems to only handle the framing layer.
Edit: If an existing solution does exist , it doesn't necessarily have to be UART based, but could be transport agnostic.
Derek
    I may be a bit late to the party, but you mentioned:
    So are those the two things that you want to communicate with eachother? In that case, there are samples in the nRF Connect SDK (NCS) showing how to do this. I don't know exactly what you intend to do, but if you aim to have the main application running on an nRF91's application core, communicate with the modem core, and use the nRF52 as a BLE device, then we have samples doing this. One of these is the NCS\nrf\applications\connectivity_bridge (particularly meant to be running on an Thingy91). This utilizes the onboard nRF52840 as a BLE device (running the ncs\zephyr\samples\bluetooth\hci_uart sample)
    Edvin
  • Hey Edvin, after reviewing these examples, it looks like you are still required to hook everything together in software. It also looks like the ncs\zephyr\samples\bluetooth\hci_uart sample uses the H:4 HCI transport protocol which has no error checking (CRC for example).
    Based on this, it doesn't look like an adequate, robust, and generic drop-in solution with error checking exists for Zephyr in regard to communication between two MCU's using a UART.
    I guess I will just write my own modular solution that I can easily port to other Zephyr projects.
  • I'd like to add that I have a pending PR for COBS in upstream Zephyr. https://github.com/zephyrproject-rtos/zephyr/pull/83072 I hope to use this to create a more full featured RPC method as you requested--seems like it would be useful for a lot of people.
    Helmut Lord
  • Hey Helmut,
    I am sure many people would find that useful! My concern with RPC is the overhead though since it seems to spawn a new thread for every message received / processed. See my comments and concerns about RPC above.
    In the meantime, I will close those ticket since it doesn't seem a lightweight and robust solution already exists.
    Derek
