Testing the RADIO TEXT example on 52811.
1. 52811 is not a supported target - so I must select all targets then the unsupported dts (nrf52840/nrf52811)
2. I add a Build, with the included prj.conf, optimize for size and use sysbuild.
3. Build and Debug.
4. Code Halts at:
\brief Set Base Priority
\details Assigns the given value to the Base Priority register.
\param [in] basePri Base Priority value to set
__STATIC_FORCEINLINE void __set_BASEPRI(uint32_t basePri)
__ASM volatile ("MSR basepri, %0" : : "r" (basePri) : "memory");
with stack as shown:
This is the first halt - thus it may be the first opportunity after booting to halt code.
after run and later pause:
The break is always here:
The main problem is that I am unable to get a break on this line in main.c
The hardware is based on the design files here:
https://www.nordicsemi.com/Products/nRF52811/Download#infotabs
Download nRF52811 CAAA Reference Layout v1.0 [ZIP]
Now I have updated the pjr.conf as follows:
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_PRINTK=y
CONFIG_ASSERT=n
#CONFIG_ASSERT=n
# Console
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
CONFIG_CONSOLE=y
CONFIG_RTT_CONSOLE=y
#CONFIG_STDOUT_CONSOLE=y
#RC LF Clock
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON=y
CONFIG_HEAP_MEM_POOL_SIZE=1024
CONFIG_BT=n
# Enable the NUS service
#CONFIG_BT_NUS=y
# Enable bonding
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# Drivers and peripherals
CONFIG_I2C=n
CONFIG_WATCHDOG=n
CONFIG_SPI=n
CONFIG_GPIO=y
# Power management
# Interrupts
CONFIG_DYNAMIC_INTERRUPTS=n
CONFIG_IRQ_OFFLOAD=n
# Memory protection
CONFIG_THREAD_STACK_INFO=n
CONFIG_THREAD_CUSTOM_DATA=n
CONFIG_FPU=n
# Boot
CONFIG_NCS_BOOT_BANNER=n
CONFIG_BOOT_BANNER=n
CONFIG_BOOT_DELAY=0
# Build
#CONFIG_SIZE_OPTIMIZATIONS=y
# ARM
CONFIG_ARM_MPU=n
# In order to correctly tune the stack sizes for the threads the following
# Configurations can enabled to print the current use:
#CONFIG_THREAD_NAME=y
#CONFIG_THREAD_ANALYZER=y
#CONFIG_THREAD_ANALYZER_AUTO=y
#CONFIG_THREAD_ANALYZER_RUN_UNLOCKED=y
#CONFIG_THREAD_ANALYZER_USE_PRINTK=y
#CONFIG_CONSOLE=y
#CONFIG_UART_CONSOLE=y
#CONFIG_SERIAL=y
#CONFIG_PRINTK=y
# Example output of thread analyzer
#SDC RX : unused 800 usage 224 / 1024 (21 %)
#BT ECC : unused 216 usage 888 / 1104 (80 %)
#BT RX : unused 1736 usage 464 / 2200 (21 %)
#BT TX : unused 1008 usage 528 / 1536 (34 %)
#ble_write_thread_id : unused 688 usage 336 / 1024 (32 %)
#sysworkq : unused 1912 usage 136 / 2048 (6 %)
#MPSL signal : unused 928 usage 96 / 1024 (9 %)
#idle 00 : unused 224 usage 96 / 320 (30 %)
#main : unused 568 usage 456 / 1024 (44 %)
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=536
CONFIG_MPSL_WORK_STACK_SIZE=256
CONFIG_MAIN_STACK_SIZE=464
CONFIG_IDLE_STACK_SIZE=128
CONFIG_ISR_STACK_SIZE=524
#CONFIG_BT_NUS_THREAD_STACK_SIZE=428
# Disable features not needed
CONFIG_TIMESLICING=n
CONFIG_COMMON_LIBC_MALLOC=n
# Disable Bluetooth features not needed
CONFIG_BT_DEBUG_NONE=y
CONFIG_BT_ASSERT=n
CONFIG_BT_DATA_LEN_UPDATE=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_GATT_CACHING=n
CONFIG_BT_GATT_SERVICE_CHANGED=n
CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=n
CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
CONFIG_BT_HCI_VS=n
# Disable Bluetooth controller features not needed
CONFIG_BT_CTLR_PRIVACY=n
CONFIG_BT_CTLR_PHY_2M=n
# Copyright (c) 2020 Nordic Semiconductor
CONFIG_CONSOLE_HANDLER=y
CONFIG_SHELL=y
CONFIG_DYNAMIC_INTERRUPTS=y
CONFIG_NRFX_TIMER0=y
CONFIG_CLOCK_CONTROL=y
CONFIG_ENTROPY_GENERATOR=y
CONFIG_NRF_SECURITY=y
CONFIG_FEM_AL_LIB=y
CONFIG_PICOLIBC_IO_FLOAT=y
This compiles, loads, and runs to a break in main.
After I stop (disconnect the debugger)
I can connect RTT, and I get the expected Console Out.
So My Issue is: How do I type commands across the RTT link?
On my screen, I am unable to type or send commands in RTT terminal within Visual Code (After Connected Devices - > connect RTT)
