pairing fail with ncs 2.8.0
hello Nordic
we are working with nrf52832 and nrf 52840 .. migrated to ncs2.7.0 lately and now migrating to ncs 2.8.0 (at the moment building without sysbuild)
we did not change anything in the pairing mechanism but suddenly it seems to stop working
i first get the 'bt_conn_cb'  callback of " .security_changed" which inside it i get that  'bt_conn_get_security(const struct bt_conn *conn)  returns with value = 2 which indicates pairing
but right after that i get another  'bt_conn_auth_info_cb' callback of " .pairing_failed" followed by the first callback .. indicating a fail
i get this print (from ncs) " bt_smp: pairing failed (peer reason 0x3) "
any idea what has changed ?
and what does peer reason 3 means ?
hope to read you soon
best regards
Ziv
  • Hi Ziv,
    I assume the reason you print is an bt_security_err instance (which you get in the pairing_failed callback). And then, reason 3 is BT_SECURITY_ERR_OOB_NOT_AVAILABLE. That is not an error I would expect unless you are doing OOB pairing?
  • Hi Einar
    in this callback i actually print reason 4 ->  BT_SECURITY_ERR_AUTH_REQUIREMENT (still wonder why, and now i know it also happens sometimes with ncs 2.7.0, but we did not had this issue before)
    we are not doing out of band pair.
    the peer reason 3 is a print that exist in the ncs itself
    (v2.8.0/zephyr/subsys/bluetooth/host/smp.c , line 1299 and/or line 3811
    (v2.7.0/zephyr/subsys/bluetooth/host/smp.c , line 1236 and/or line 3733
    any idea what this '3' error is or why i get  BT_SECURITY_ERR_AUTH_REQUIREMENT ?
    best regards
    Ziv
  • Hi Ziv,
    Ah, yes - I missed that. As you get BT_SECURITY_ERR_AUTH_REQUIREMENT I wonder if there is allready an existing bond with the peer? If so, the bond needs to be deleted, or you need to allow re-pairing by adding CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y and CONFIG_BT_ID_UNPAIR_MATCHING_BONDS=y. This means that bonds can be replaced without specific actions, which is often the desiered behaviour, but not always.
  • Hi Einar
    not sure i follow, because we pair once and then save the generated keys in flash for next pairing,  not to go through the process every time. i don't think we deliberately unpair, and we do not use multiple ble identities (.. the only scenario that could be is that a device connects with 2 different nodes and has to pair with each one separately and another scenario that is not yet active is pairing with 2 different adaptores on the same node).
    .. so by deleting the bond it will mean that the key generation will take place in every connection ?
    can you elaborate a bit on why it is desired and in what ,example ,case can this be undesired ?
    and also is this something that was added or changed in ncs 2.7.0 or 2.8.0 that cause this issue to arise for us now ?
    and last but not least .. when added the configs you mentioned to prj.conf i get a different err from my callback implementation for pairing failed -> reason is BT_SECURITY_ERR_UNSPECIFIED .. any ideas what i am doing wrong ?
    best regards
    Ziv
  • Hi Ziv,
    I should have specified better. You can only bond once with the same peer. If allready bonded, the bonding information (key etc) is re-used every time. However, if the peer device lost the bonding information for some reason (typically a user deleted it on a phone or similar), the old bond information is no longer valid. In this case, bonding again is not allowed, as a bond allready exist. I am wondering if that is what has happened here? If so, and i fyou want to allow bondign again even if a bond exist (to gracefully handle the case where the peer device no longer has the bond), you need to explicitly allow it.
    For usability reasons, you often want to be able to bond again with a device you have an existing bond with, if the bond has been deleted (deliberately or not) on that device without explicitly deletign that bond first. For many products this is in practice a requierment. However, this also opens up the possability that an attacker can spoof the address of another device and replace it's bond, which is why it is not allowed by default.
    No, there has not been significant changes on this part. But this is a common issue that we often see when testing, if a bond is deleted during that process. But it seems you are seeing a different issue.
    Can you debug and see where exactly the BT_SECURITY_ERR_UNSPECIFIED comes from? It is not much used, so a simple way to do it could be to set a breakpoint on all lines with "return BT_SECURITY_ERR_UNSPECIFIED;" in the code.
    Einar
