pm_device_action_run gives MPU FAULT if bme280 ID is bad (0x00)
In my project I have a BME280 that starts OFF, and I interface with SPI.
The system then turns the power supply and the bme280 is powered.
At this stage the bme280 needs to be configurated, with the devicetree and .conf configurations.
To do this, I call pm_device_action_run(dev_bme, PM_DEVICE_ACTION_RESUME) to run the static int bme280_chip_init(const struct device *dev) internally.
Before passing to PM_DEVICE_ACTION_RESUME I also placed it into PM_DEVICE_ACTION_SUSPEND and then into PM_DEVICE_ACTION_RESUME.
/* main.c - Application main entry point */
 * Copyright (c) 2015-2016 Intel Corporation
#include <zephyr/types.h>
#include <stddef.h>
#include <zephyr/sys/util.h>
#include <zephyr/pm/device_runtime.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/device.h>
#include <zephyr/drivers/sensor.h>
#include <zephyr/pm/device.h>
#include <zephyr/drivers/adc.h>
#include <math.h>
LOG_MODULE_REGISTER(Log_Main, LOG_LEVEL_DBG);
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
#define BEACON_ALL_SENSOR_TESTING 1
#define DT_SPEC_AND_COMMA(node_id, prop, idx) \
	ADC_DT_SPEC_GET_BY_IDX(node_id, idx),
 * Get a device structure from a devicetree node with compatible
 * "bosch,bme280". (If there are multiple, just pick one.)
static const struct device *get_bme280_device(void)
	const struct device *const dev = DEVICE_DT_GET_ANY(bosch_bme280);
	if (dev == NULL) {
		/* No such node, or the node does not have status "okay". */
		printk("\nError: no device found.\n");
		return NULL;
	// if (!device_is_ready(dev)) {
	// 	printk("\nError: Device \"%s\" is not ready; "
	// 	       "check the driver initialization logs for errors.\n",
	// 	       dev->name);
	// 	return NULL;
	printk("Found device \"%s\", getting sensor data\n", dev->name);
	return dev;
static const struct device *get_lis2_device(void)
	const struct device *const sensor = DEVICE_DT_GET_ANY(st_lis2dh);
	if (sensor == NULL) {
		printf("No device found\n");
		return 0;
	if (!device_is_ready(sensor)) {
		printf("Device %s is not ready\n", sensor->name);
		return 0;
	printk("Found device \"%s\", getting sensor data\n", sensor->name);
	return sensor;
 * Set Advertisement data. Based on the Eddystone specification:
 * https://github.com/google/eddystone/blob/master/protocol-specification.md
 * https://github.com/google/eddystone/tree/master/eddystone-url
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_NO_BREDR)
	// BT_DATA_BYTES(BT_DATA_UUID16_ALL, 0xaa, 0xfe), //, 0x6E, 0x2A, 0x6F, 0x2A, 0x6D, 0x2A),
	// BT_DATA_BYTES(BT_DATA_SVC_DATA16,
	// 	      0xaa, 0xfe, /* Eddystone UUID */
	// 	      0x10, /* Eddystone-URL frame type */
	// 	      0x00, /* Calibrated Tx power at 0m */
	// 	      0x00, /* URL Scheme Prefix http://www. */
	// 	      'z', 'e', 'p', 'h', 'y', 'r',
	// 	      'p', 'r', 'o', 'j', 'e', 'c', 't',
	// 	      0x08) /* .org */
/* Set Scan Response data */
static struct bt_data sd[] = {
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static void bt_ready(int err)
	char addr_s[BT_ADDR_LE_STR_LEN];
	bt_addr_le_t addr = {0};
	size_t count = 1;
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	/* Start advertising */
	err = bt_le_adv_start(BT_LE_ADV_PARAM(BT_LE_ADV_OPT_USE_IDENTITY, 0x07D0, 0x07FD, NULL), ad, ARRAY_SIZE(ad),
			      sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	/* For connectable advertising you would use
	 * bt_le_oob_get_local().  For non-connectable non-identity
	 * advertising an non-resolvable private address is used;
	 * there is no API to retrieve that.
	bt_id_get(&addr, &count);
	bt_addr_le_to_str(&addr, addr_s, sizeof(addr_s));
	printk("Beacon started, advertising as %s\n", addr_s);
static const uint16_t RTD_0 = 1000;
static const uint16_t RTD_100 = 1385;
static const uint16_t ResBridge = 845;
	int err;
	LOG_INF("Starting Beacon Demo\n");
	/* Initialize the Bluetooth Subsystem */
	err = bt_enable(bt_ready);
	if (err) {
		LOG_ERR("Bluetooth init failed (err %d)\n", err);
    printk("DONE\n");
    //sens_power_mosfet
    const struct gpio_dt_spec mosfet = GPIO_DT_SPEC_GET(DT_NODELABEL(sens_power_mosfet), gpios);
    err = gpio_pin_configure_dt(&mosfet, GPIO_OUTPUT_INACTIVE);
    if (err != 0) {
        LOG_ERR("Function 'gpio_pin_configure_dt' for 'mosfet' pin err code: %d", err);
        return err;
    err = gpio_pin_set_dt(&mosfet, 1);
    if (err != 0) {
        LOG_ERR("Function 'gpio_pin_set_dt' for 'RLed' pin err code: %d", err);
        return err;
    k_sleep(K_SECONDS(1));
    const struct device *dev_bme = get_bme280_device();
	// if (dev_bme == NULL) {
	// 	return 0;
    err = pm_device_action_run(dev_bme, PM_DEVICE_ACTION_SUSPEND);
    if(err){
        LOG_ERR("BME device pm OFF failed: %d", err);
        return 0;
    err = pm_device_action_run(dev_bme, PM_DEVICE_ACTION_RESUME);
    if(err){
        LOG_ERR("BME device pm RESUME failed: %d", err);
        return 0;
    const struct device *dev_lis = get_lis2_device();
    struct sensor_value temp, press, humidity, accelx, accely, accelz;
    uint32_t count = 0;
    while (1) {
        #if BEACON_ALL_SENSOR_TESTING
            sensor_sample_fetch(dev_bme);
            sensor_channel_get(dev_bme, SENSOR_CHAN_AMBIENT_TEMP, &temp);
            sensor_channel_get(dev_bme, SENSOR_CHAN_PRESS, &press);
            sensor_channel_get(dev_bme, SENSOR_CHAN_HUMIDITY, &humidity);
            printk("temp: %d.%06d; press: %d.%06d; humidity: %d.%06d\n",
                    temp.val1, temp.val2, press.val1, press.val2,
                    humidity.val1, humidity.val2);
            int32_t tempaux = (temp.val1 * 100 + temp.val2 / 10000);
            int32_t humaux = (humidity.val1 * 100 + humidity.val2 / 10000);
            int32_t pressaux = (press.val1 * 100 + press.val2 / 10000);
            //printk("tempaux: %d\n", tempaux);
            sensor_sample_fetch(dev_lis);
            sensor_channel_get(dev_lis, SENSOR_CHAN_ACCEL_X, &accelx);
            sensor_channel_get(dev_lis, SENSOR_CHAN_ACCEL_Y, &accely);
            sensor_channel_get(dev_lis, SENSOR_CHAN_ACCEL_Z, &accelz);
            printk("accelx: %d.%06d; accely: %d.%06d; accelz: %d.%06d\n",
                    accelx.val1, accelx.val2, accely.val1, accely.val2,
                    accelz.val1, accelz.val2);
            int32_t accelxaux = (accelx.val1 * 100 + accelx.val2 / 10000);
            int32_t accelyaux = (accely.val1 * 100 + accely.val2 / 10000);
            int32_t accelzaux = (accelz.val1 * 100 + accelz.val2 / 10000);
            uint8_t checkMem = 0;
            int16_t RTDTempInt = 0;
            struct bt_data ad_aux[] = {
                BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_NO_BREDR),
                BT_DATA_BYTES(BT_DATA_UUID16_ALL, 0xE5, 0xFE),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0x6E, 0x2A, (uint8_t)(tempaux & 0xFF), (uint8_t)(tempaux >> 8)),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0x6E, 0x2A, (uint8_t)(RTDTempInt & 0xFF), (uint8_t)(RTDTempInt >> 8)),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0x6F, 0x2A, (uint8_t)(humaux & 0xFF), (uint8_t)(humaux >> 8)),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0xEB, 0x2A, (uint8_t)count)
            struct bt_data sd_aux[] = {
                //BT_DATA_BYTES(BT_DATA_UUID16_ALL, 0x2A, 0x6E), // 0x015, 0x03, 0x0543),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0x6D, 0x2A, (uint8_t)(pressaux & 0xFF), (uint8_t)(pressaux >> 8)),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0x13, 0x27, (uint8_t)(accelxaux & 0xFF), (uint8_t)(accelxaux >> 8)),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0x13, 0x27, (uint8_t)(accelyaux & 0xFF), (uint8_t)(accelyaux >> 8)),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0x13, 0x27, (uint8_t)(accelzaux & 0xFF), (uint8_t)(accelzaux >> 8)),
                BT_DATA_BYTES(BT_DATA_SVC_DATA16, 0xEB, 0x2A, checkMem)
            bt_le_adv_update_data(ad_aux, ARRAY_SIZE(ad_aux), sd_aux, ARRAY_SIZE(sd_aux));
            count++;
        #endif // BEACON_ALL_SENSOR_TESTING
        k_sleep(K_SECONDS(10));
	return 0;
This is my config:
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_DEVICE_NAME="Test beacon" #Test beacon
#CONFIG_BT_CTLR_TX_PWR_PLUS_4=y
# CONFIG_BT_CTLR_TX_PWR_PLUS_3=y
CONFIG_BT_CTLR_TX_PWR_0=y
#CONFIG_BT_CTLR_TX_PWR_MINUS_4=y
#CONFIG_BT_CTLR_TX_PWR_MINUS_8=y
#CONFIG_BT_CTLR_TX_PWR_MINUS_12=y
#CONFIG_BT_CTLR_TX_PWR_MINUS_16=y
#CONFIG_BT_CTLR_TX_PWR_MINUS_20=y
#CONFIG_BT_CTLR_TX_PWR_MINUS_40=y
CONFIG_SENSOR_LOG_LEVEL_DBG=y
CONFIG_MAIN_STACK_SIZE=16384
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_ISR_STACK_SIZE=4096
#CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
This is the error:
*** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
[00:00:00.004,272] <inf> Log_Main: main: Starting Beacon Demo
[00:00:00.004,394] <inf> bt_sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                            d6 da c7 ae 08 db 72 6f  2a a3 26 49 2a 4d a8 b3 |......ro *.&I*M..
                                            98 0e 07 7f                                      |....
[00:00:00.006,286] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.006,317] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
[00:00:00.006,378] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 214.51162 Build 1926957230
[00:00:00.007,232] <inf> bt_hci_core: bt_dev_show_info: Identity: E9:04:F6:A4:59:5D (random)
[00:00:00.007,263] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.4 (0x0d) revision 0x11fb, manufacturer 0x0059
[00:00:00.007,293] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.4 (0x0d) subver 0x11fb
Beacon started, advertising as E9:04:F6:A4:59:5D (random)
DONE
Found device "bme280@0", getting sensor data
[00:00:02.008,636] <dbg> BME280: bme280_chip_init: bad chip id 0x0
[36:16:02.036,315] <err> os: mem_manage_fault: ***** MPU FAULT *****
[36:16:02.078,552] <err> os: mem_manage_fault:   Data Access Violation
[36:16:02.085,937] <err> os: mem_manage_fault:   MMFAR Address: 0x20002bc0
[36:16:02.093,688] <err> os: esf_dump: r0/a1:  0x40004000  r1/a2:  0x20002528  r2/a3:  0x200024ff
[36:16:02.103,485] <err> os: esf_dump: r3/a4:  0x000006c1 r12/ip:  0x00000000 r14/lr:  0x00017881
[36:16:02.113,281] <err> os: esf_dump:  xpsr:  0x81003814
[36:16:02.119,537] <err> os: esf_dump: Faulting instruction address (r15/pc): 0x00017820
[36:16:02.128,570] <err> os: z_fatal_error: >>> ZEPHYR FATAL ERROR 19: Unknown error on CPU 0
[36:16:02.138,000] <err> os: z_fatal_error: Fault during interrupt handling
[36:16:02.145,935] <err> os: z_fatal_error: Current thread: 0x200016e8 (unknown)
[36:16:02.154,205] <err> os: k_sys_fatal_error_handler: Halting system
My problem is that the MPU FAULT only happens when the while is ran as is. If a sensor_channel_get(...) function or the ble function are commented the MPU FAULT no longer appears.
This lead me to believe that it was a lack of main stack but i also increased that.
    Sorry for the late reply.
    The SPI doesn't have DMA, which handles your queues/buffers without the need of the CPU. Therefore, in most cases, the SPIM driver is preferred.
    If you say that the nrfx_spi_xfer() finishes too quickly, it may be that it is not blocking, and hence only queues the transaction. Then your application goes on to the next SPI xfer before the first one finishes, messing up the data flow. Although I can't find any documentation of it, I believe I have heard something like the SPI driver is deprecated, and you should use the SPIM driver instead, as it has no disadvantages compared to the SPI driver.
    So I believe the case is that since the SPI driver is not blocking, other drivers may not wait for a transaction to finish before calling the next transaction, causing the next transaction to return an error.
    TheLittleFish said:
    nrfx_spi_xfer() function in spi_nrfx_spi.c is finishing too quickly.
    Indeed. It will finish/return before the transaction is complete, looking at the source code:
        if (p_cb->transfer_in_progress)
            err_code = NRFX_ERROR_BUSY;
            NRFX_LOG_WARNING("Function: %s, error code: %s.",
                             __func__,
                             NRFX_LOG_ERROR_STRING_GET(err_code));
            return err_code;
    So if it is not a problem, I suggest you use the SPIM driver. Since this uses DMA, it is capable of handling the buffer, adding to it instead of trying to hijack it.
    Edvin
  • Ok I shall do that.
    But in relation to this statement:
    The DevZone academy intermediate course show that for the nrf52 dk (nrf52832) the SPI module is the indicated to use because of the errata 58. This might need fixing.
    https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-5-serial-peripheral-interface-spi/topic/exercise-1-10/
  • Reopening since after further testing found that the BME280 drivers are not compatible with the SPIM for the nRF52832.
    This is due to them not complying with workarround 58, of 1 byte transfers.
    My only chance now is altering the PCB layout and hopping for the best with the normal SPI. I guess.
    Will know tomorrow.
  • After testing the new layout works.
    In it the BME280 starts ON and its power is not controllable.
    Meaning its directly connected to the battery.
    Summarizing.
    The BME280 zephyr drivers are has of now ready to handle the hardware SPIM problem 58 of the nRF52832.
    The work around developed (SPI) works in normal situations.
    However, in some edge cases like the one in this thread it may fail inexplicably.
    So, the solutions is that when developing with the nRF52832's SPI either:
    - Try to avoid hardware complications, especially with the power of the BME280 (this is what i did)
    - If this are necessary, make the BME280 start ON (this seams to work for me)
    A less useful solutions is to alter the SoC, for example, to the new nRF54 line (not sponsored).
