I am seeing a problem identical to what's described in this question. I'm using SDK version 10.
My timers work fine for a while, but then suddenly and seemingly at random all timers expire the instant they are started. Sometimes it goes away and the timers work again, but sometimes the only fix seems to be a restart.
I've seen two suggested solutions. One is to add a delay or a call to rtc1_compare0_set
in compare_reg_update; I'm on SDK 10 and both solutions are already there:
rtc1_compare0_set(rtc1_counter_get()); // this should prevent CC to fire again in the background while the code is in RTC-ISR
nrf_delay_us(MAX_RTC_TASKS_DELAY);
timer_timeouts_check_sched();
The only other solution I've found on the forum is to have a dummy timer that is always running. It's recommended in this answer.
Sadly, I do already have a dummy timer always running—I've been using it to force the RTC to stay on so I can use it for timekeeping.
Are there any other known problems or solutions with app_timer? I'm running out of ideas. Thanks!
