Got stuck with the getting nrf54h20 started guide with `NotAvailableBecauseProtection` error
Following the getting nrf54h20 started guide - https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/device_guides/working_with_nrf/nrf54h/ug_nrf54h20_gs.html#ug-nrf54h20-gs
I got stuck after the UICR flashing step - it seems there a readback protection. I've tried to erase the UICR but with no success. How do I continue?
~/dev/nrf54h20 » nrfutil device recover
X Failed to recover 1050855131, [jlink] RECOVER_FAILED
Error: One or more recover tasks failed:
* 1050855131: [jlink] RECOVER_FAILED, code: Nrfjlink
~/dev/nrf54h20 » nrfutil device erase --all
X Failed to erase 1050855131, [jlink] The operation is unavailable due to readback protection
Error: One or more erase tasks failed:
* 1050855131: [jlink] The operation is unavailable due to readback protection, code: NotAvailableBecauseProtection
The operation was unavailable for some of the devices because they had readback protection enabled. These devices might be possible to unlock using the `recover` subcommand. See `nrfutil device recover --help` for more information.
nrfutil Version:  7.13.0 (8289424 2024-07-01)
Installed nrfutil tools:
* completion 1.5.0
* device 2.4.6 Work with Nordic Semiconductor devices
* nrf5sdk-tools 1.1.0 nRF5 SDK tools that were available in nRF Util 6
* toolchain-manager 0.15.0 Manage and use toolchains for nRF Connect SDK
Found 4 installed command(s)
  • Updating that I've tried to use the nrf Connect Desktop Programmer App, yet it complain as well:
    19:46:46.005 Initialising nrfutil module: device
    19:46:46.639 Using nrfutil-device core version: 7.13.0
    19:46:46.857 Using nrfutil-device version: 2.1.1
    19:46:46.857 Using nrf-device-lib version: 0.17.5
    19:46:46.857 Using nrfjprog DLL version: 10.24.0
    19:46:46.857 Using JLink version: JLink_V7.94e
    19:47:41.804 Getting serialport options from persistent store 001050855131.pc-nrfconnect-programmer
    19:47:41.806 Getting serialport options from persistent store 001050855131.pc-nrfconnect-programmer
    19:47:49.787 Error: Failed with exit code 1. Failed to device info one or more devices: * 1050855131: [jlink] UNKNOWN_DEVICE, code: Nrfjlink. Message: Operation device-info failed, [jlink] UNKNOWN_DEVICE.
    19:47:49.788 Using nrfutil device to communicate with target via JLink
    19:47:51.945 Reading readback protection status for Application core
    19:47:51.945 Reading readback protection status for Application core 0%
    19:47:51.947 Reading readback protection status for Application core 100%
    19:47:51.947 Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    19:47:51.948 Reading readback protection status for Application core completed
    19:47:54.116 Loading core information for Application core
    19:47:54.116 Loading core information for Application core 0%
    19:47:54.120 Loading core information for Application core 100%
    19:47:54.120 Loading core information for Application core completed
    19:47:54.120 Reading memory for Application core
    19:47:54.121 Reading memory for Application core 0%
    19:47:54.973 Error: Failed with exit code 1. One or more batch tasks failed: - [jlink] NOT_AVAILABLE_BECAUSE_TRUST_ZONE, code: Nrfjlink. Message: Bath task fw-read failed, [jlink] NOT_AVAILABLE_BECAUSE_TRUST_ZONE.
    19:47:54.973 Error: Failed with exit code 1. One or more batch tasks failed: - [jlink] NOT_AVAILABLE_BECAUSE_TRUST_ZONE, code: Nrfjlink. Message: Batch task fw-read failed, [jlink] NOT_AVAILABLE_BECAUSE_TRUST_ZONE.
    19:48:33.954 Recovering Application core
    19:48:33.955 Recovering Application core 0%
    19:48:34.021 Failed "recovering application core". Error: code: 9, description: Nrfjlink, message: Batch task recover failed, [jlink] RECOVER_FAILED
    19:48:34.098 Error: Failed with exit code 1. One or more batch tasks failed: - [jlink] RECOVER_FAILED, code: Nrfjlink. Message: Batch task recover failed, [jlink] RECOVER_FAILED.
    19:48:48.268 Reading memory for Application core
    19:48:48.269 Reading memory for Application core 0%
    19:48:49.144 Error: Failed with exit code 1. One or more batch tasks failed: - [jlink] NOT_AVAILABLE_BECAUSE_TRUST_ZONE, code: Nrfjlink. Message: Batch task fw-read failed, [jlink] NOT_AVAILABLE_BECAUSE_TRUST_ZONE
  • Updating that even when I try to reprogram with the UICR, it failed:
    ➜ Downloads nrfjprog --program /home/gbrandwine/Downloads/bicr.hex --chiperase (dev-odeaks/gbrandwine)
    [error] [ Client] - Encountered error -93: Command erase_file executed for 691 milliseconds with result -93
    [error] [haltium] - Can't check security mapping of peripheral @0x5201E000 with coprocessor APPLICATION without secure debugging available.
    [error] [haltium] - Failed while erasing device. -93: Exception encountered while enabling coprocessor
    [error] [ Worker] - Exception encountered while enabling coprocessor
    ERROR: Access to the selected address is blocked by the SPU.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    Thank you for the updated information. I will have to run this by our nRF54 team. I don't think it is supposed to behave like that. What application did you previously program into the nRF54H20? Was it the hello world application, which is explained in the guide?
    Edvin
  • Hey, thanks for answering quickly.
    No programs were previously installed. I used it straight out of the box.
    I got stuck immediately after step 1:
    Successfully flashing the BICR hex
     (https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/device_guides/working_with_nrf/nrf54h/ug_nrf54h20_gs.html#programming_the_bicr)
  • Can you please take a picture of what your DK looks like? I am particularly interested in what it says on the white sticker, but also the rest of the kit. I need this information to send it to our developers to check if there may be some compatibility issues.
    Edvin
