Is there any guides or easy way to make the Azure IoT Sample work with the Thingy91 or e.g. Icarus IoT v2?
you can just follow the documentation here. The thingy91 is not in the supported list, but it should still work I believe.
No, it fails when building for the Thingy91 and Icarus IoT V2. Builds and work fine on nRF9161DK.
I am also unable to paste code/ build output in this editor, or just past the text in the editor. Uploading files also fails.
If trying to paste into code the "ok" button doesn't respond. (responds if writing simple short text), or I get "An error occurred. Please try again or contact your administrator." on "reply" I've tried Chrome and Edge. This also happens using other computer. Can't find any administrator contact on page.
Neso said:I am also unable to paste code/ build output in this editor, or just past the text in the editor. Uploading files also fails.
Thanks for reporting! I have forwarded to the admin but most likely not solution until after Christmas break.
Neso said:it fails when building for the Thingy91 and Icarus IoT V2. Builds and work fine on nRF9161DK
Do you have a cloud solution where e.g. google drive where you can store the text file with the error output, and that you can share with us using the shares link?
Øyvind
Could you try to add the .txt file to a .zip file? This should work
-Øyvind
Still unable to upload files or text.
