Is there any guides or easy way to make the Azure IoT Sample work with the Thingy91 or e.g. Icarus IoT v2?
Neso said:Edit: I see now you have including options for the nrf9151dk_nrd9151_ns. I'm trying to get the nrf9160 (Thingy91 and Icarus IoT) to work. Is there any difference on options to include?
These are settings that are the same on all boards. I tested on my side without issues, expect for the need of an external flash.
So I was finally able to build for the Icarus IoT board. Still fails on connect, but do to faulty certificate. Tried rebuilding, but it suddenly fails all the time even if no changes have been made (Reverted from Git) How can that be? About to abandon nrf at this point. Help seriously needed..
Here's my latest fail.
[184/189] Linking C executable zephyr\zephyr_pre0.elf FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map C:/ncs/Nrf_Projects/azure_iot_hub/Supremebuild/mcuboot/zephyr/zephyr_pre0.map cmd.exe /C "cd . && C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -Os -DNDEBUG -gdwarf-4 -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=C:/ncs/Nrf_Projects/azure_iot_hub/Supremebuild/mcuboot/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/soc/soc/nrf9160/libsoc__nordic.a zephyr/boards/actinius/icarus/actinius_common/libboards__actinius__common.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -LC:/ncs/Nrf_Projects/azure_iot_hub/Supremebuild/mcuboot/zephyr zephyr/arch/common/libisr_tables.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -fuse-ld=bfd -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie C:/ncs/v2.9.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a C:/ncs/v2.9.0/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a -L"c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main+fp/hard" -lc -lgcc && cmd.exe /C "cd /D C:\ncs\Nrf_Projects\azure_iot_hub\Supremebuild\mcuboot\zephyr && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe -E true"" c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_0_config+0x0): undefined reference to `__device_dts_ord_117' collect2.exe: error: ld returned 1 exit status ninja: build stopped: subcommand failed. [15/20] Generating ../dfu_application.zip FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build C:/ncs/Nrf_Projects/azure_iot_hub/Supremebuild/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build cmd.exe /C "cd /D C:\ncs\Nrf_Projects\azure_iot_hub\Supremebuild\mcuboot && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe --build ." ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' --build C:/ncs/Nrf_Projects/azure_iot_hub/Supremebuild * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
