Hay.
I am Working on positioning.
I want to use AoA and Nordic Distance Measurement library.
What SoC do you recommend?
Hay.
Have you tried using the AI? It's really good at finding similar questions and suggesting answers from previous replies.
Hi
For Direction Finding (AOA) Only the nRF52833 and nRF5340 is supported. And the nRF5340 is the one with the largest amount of RAM/Flash, which might be a hurdle when combining applications like Mike@PebbleStack points out here. Additionally, you would indeed have to switch between the two as you can't run ranging with DM simultaneously as you do an AOA ranging.
It is indeed also worth checking out the channel sounding which is new, and within the Bluetooth specification, although it is only supported by the nRF54L15.
Is there a specific reason you will need both Direction Finding and Distance Measurement for your ranging application?
Simon
Thanks.
Of course.
1. Between tags and locators
We want to know the presence of tags approaching from a specific direction. This can be achieved with one locator.
2. When multiple locators are placed
By knowing the distance between locators, the position of the locator can be identified. This is effective when the locator moves.
We dream of a more advanced system than you can imagine. To achieve this, we need to combine each function.
Even if each function can be realized individually, the dream will not come true.
We would like your cooperation in making our dream come true.
Hi
Please indulge me then. Try explaining what you're planning on doing, and in what terms you need the two to work at the same time? Since the nRF5340 only has one radio, so doing two different operations at the same exact time won't be doable. But switching between them should be.
Please let me know what I can do to help you, and I'll do my best! Note that the holiday season is inbound in Norway, so delays in replies must be expected until the 2nd of January.
Happy Holidays!
Simon
OK.Thanks.
Our goal is to use a completely cordless mesh network to measure positioning and collect sensor information.
Each device is battery-powered.
They can be placed anywhere (within the range where mesh communication is possible).
First, the distance between each device is measured to determine the location of the placed device.
There is also a special device (multi-antenna) that is placed at the entrance to the gate.
To tags approaching the gate from a specific direction, information according to the direction (including the distance from the gate) is sent
Then, when a certain distance is reached, an instruction is issued to stop.
This is the system we want to realize. (Specific objectives will not be described as they are confidential.)
