Hello everyone!
I'm working with the nRF52840 microcontroller and I wanted to get a bluetooth antenna and since I know that the whole RF thing is very complicated, I was thinking about trying several antennas to see which one works best in my design.
My questions are the following:
+ To maintain an impedance of 50 ohms, how can I make the correct calculation of the track size? I have previously adapted the following guide:
devzone.nordicsemi.com/.../general-pcb-design-guidelines-for-nrf52-series
+ I have assumed the following, if I route the antenna on the top layer, the next layer should be GND for a good return, so should I place ground vias around the RF path?
+ I'm testing the following antennas: one on a PCB (with the same length as the evaluation kit), another on a chip (2450AT18D0100E) and I've also put the MM8130-2600RA2 connector to test another one just in case, is what I'm doing correct?
Finally, to select these antennas I use 0R resistors, but I understand that not all of them work the same at 2.4GHz, could you recommend one?
Thank you very much in advance
