sd_power_dcdc_mode_set behavior
Other than setting the DCDC_MODE_PIN, what else does the sd_power_dcdc_mode_set() do?
I'm seeing an issue where I have a GPS peripheral on UART that is seeing about 10dB less RSSI when I use the sd_power API.
If I use GPIO to control DCDC_MODE_PIN, I don't see the 10dB loss, and BLE still works.
I cannot explain this behavior at all, but I have a repeatable way to replicate this issue.
Trying to understand what exactly goes on in sd_power_dcdc_mode_set().
I don't see any links to detailed documentation when I search for that function call.
Any help is appreciated.
  • The switching mode DCDC can produce a lot more noise in the circuitry compared to the linear regulator, and a GPS antenna would be sensitive to that. Read: You have a self inflicted EMI problem.
    You could have a nordic employee look at your layout in a private ticket.
    I would try using an RF can like you see on many NRF modules (its the small metal cover over the BTLE chip and DCDC inductors).
    No idea why you mention a GPIO here, the sd_power_dcdc_mode_set() does not care about any GPIOs AFAIK.
  • Thanks Turbo J. I was afraid this would be the case.
    Regarding GPIOs - There is something misleading on the schematic.
    P1.14 is labeled as DCDC_MODE and I assumed it was coupled to the switcher.
    (I'm new to the project)
    Regarding the can, they used the BT840x module, so it is canned.
    I will take your advice and create a ticket. Thanks!
