Hi Support Team
My nRF52 DK can not be programmed and recovered. Below is the log from VS Code terminal. Thanks.
Hi Support Team
Were you able to recover the same device previously?
I can think of following regarding this:
1) When using the VS Code, it should show a small action window in the bottom write to confirm that you want to recover the device.
2) It shows that it tried to recover for more than 30 seconds and then failed. Can you make sure everything is correct with the device? Any jumpers / switches changed or modified? Any modifications done for the power measurements?
3) Can you try to check with nrfjprog or nrfutils?
4) Use --log to enable logging for the operation
