I am trying to implement the following: I have a mesh node built using the Sensor Server example for publishing temperature data. I want one relay node to transmit the temperature data to another node, which is not within the radio range of the first node. This second node is built using the Sensor Client model. My question is: how do I implement the relay feature, which code should I use for that, and what changes need to be made?
