Hi
I would like to use DeviceTree in VS code. The VS code had installed "nRF Connect for VS Code Extension Pack" and tools chain.
But I can't see any file in "DEVICETREE VISUAL EDITOR".
What is missing? Is it not yet install? If yes, please let me know how to install it.
I know it is very simple for you, but I need your hint to fix it. Please share your advise with me.
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
"platform": {
"os": "win32",
"osVersion": "Windows 10 Pro N",
"osKernel": "10.0.19045",
"vscode": "1.96.2",
"electron": "32.2.6",
"node": "v20.18.1"
"system": {
"date": "2024-12-24T05:04:40.059Z",
"vscodeRoot": "c:\\Users\\Owner\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
"vscodeUptime": "00:00:44",
"osUptime": "03:17:48",
"cpu": "AMD Ryzen 5 5600G with Radeon Graphics"
"workspace": {
"name": "test02",
"workspaceFile": null,
"folders": [
"c:\\Users\\Owner\\Documents\\nRF\\test02"
"sdks": [
"version": "v2.9.0",
"path": "c:\\ncs\\v2.9.0"
"activeBuild": "c:\\Users\\Owner\\Documents\\nRF\\test02\\build",
"apps": [
"workspace": "c:\\Users\\Owner\\Documents\\nRF\\test02",
"uri": "c:\\Users\\Owner\\Documents\\nRF\\test02",
"buildConfigurations": [
"id": "c:\\Users\\Owner\\Documents\\nRF\\test02\\build",
"name": "build",
"boardId": "nrf52_sparkfun/nrf52832",
"type": "Sysbuild",
"isChild": false,
"isStale": false,
"taskBindings": {
"build": [],
"pristineBuild": [],
"flash": [],
"eraseAndFlash": []
"sdk": "c:\\ncs\\v2.9.0",
"toolchain": "nRF Connect SDK Toolchain v2.9.0"
"toolchains": [
"version": "2.9.0",
"path": "c:\\ncs\\toolchains\\b620d30767"
"connectedDevices": [
"serialNumber": "000268002086"
"tools": {
"C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.17.0",
"C:\\Program Files\\SEGGER\\JLink_V794l\\JLink.exe": "7.94l",
"C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.2",
"C:\\ncs\\toolchains\\b620d30767\\cmake": "3.21.0",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\Scripts\\west.exe": "1.2.0",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\python.exe": "3.12.4",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\ninja.exe": "1.10.2",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\gperf.exe": "3.1",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\dtc.exe": "1.4.7",
"C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\gn.exe": "2202",
"C:\\ncs\\toolchains\\b620d30767\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
"arm-gdbPath": "c:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
"riscv-gdbPath": "C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
"nrfutil": {
"nrfutil-device": {
"version": "2.7.2",
"binPath": "c:\\Users\\Owner\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device",
"jlinkInfo": {
"description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
"expectedVersion": {
"version": "JLink_V7.94i",
"versionFormat": "string"
"name": "JlinkARM",
"version": "JLink_V7.94l",
"nrfutil-toolchain-manager": {
"version": "0.14.4",
"binPath": "c:\\Users\\Owner\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
"environment": {
"westEnv": {
"HOME": "C:\\Users\\Owner",
"HOMEDRIVE": "C:",
"HOMEPATH": "\\Users\\Owner",
"PATH": "C:\\ncs\\toolchains\\b620d30767;C:\\ncs\\toolchains\\b620d30767\\mingw64\\bin;C:\\ncs\\toolchains\\b620d30767\\bin;C:\\ncs\\toolchains\\b620d30767\\opt\\bin;C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\b620d30767\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\Owner\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\Owner\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Owner\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
"ZEPHYR_BASE": "c:\\ncs\\v2.9.0\\zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\b620d30767\\opt\\zephyr-sdk",
"PYTHONPATH": "C:\\ncs\\toolchains\\b620d30767\\opt\\bin;C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\Lib;C:\\ncs\\toolchains\\b620d30767\\opt\\bin\\Lib\\site-packages"
"inherited": {
"HOMEDRIVE": "C:",
"Path": "C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\Owner\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Owner\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
"PATH": "C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\Owner\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Owner\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
"terminal": {
"defaultProfile": null
"config": {
"topdir": "",
"toolchain": {
"path": ""
"ozonePath": "",
"applications": [],
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"buildTerminal": {
"condensedProgress": true
"debugging": {
"flash": true,
"bindings": {},
"justMyCode": false
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": false,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask",
"terminalProfile": {
"shell": null
"terminalMode": "character"
"extensions": {
"internal": {
"version": "2024.12.55",
"path": "c:\\Users\\Owner\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.12.55-win32-x64",
"isActive": true
"version": "2024.9.14",
"path": "c:\\Users\\Owner\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
"isActive": true
"version": "2024.12.15",
"path": "c:\\Users\\Owner\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.12.15",
"isActive": true
"version": "2024.12.13",
"path": "c:\\Users\\Owner\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.12.13",
"isActive": true
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": "1.22.11",
"ms-vscode.js-debug": "1.96.0",
"twxs.cmake": "0.0.17"
