Hi all,
I wanted to enable read/write protection for MCUBOOT partition in my firmware from the application and encountered a strange problem. The build (build system - default, device nrf9160, SDK v2.7.0) for nrf9160dk_nrf9160_ns with MCUBOOT(child image) and TFM results with error:
CMake Error at C:/ncs/v2.7.0/nrf/lib/fprotect/CMakeLists.txt:15 (message): No fprotect backend selected.
My research showed that the device tree for NS board has no SPU, ficr and uicr peripherals (why??). And if I try to add these peripherals in a device tree overlay file I get following compilation errors:
In file included from C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain.h:50, from C:/ncs/v2.7.0/zephyr/include/zephyr/kernel_includes.h:23, from C:/ncs/v2.7.0/zephyr/include/zephyr/kernel.h:17, from C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:7: C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:176:20: error: 'NRF_FICR' undeclared here (not in a function); did you mean 'NRF_FICR_S'? 176 | CHECK_DT_REG(ficr, NRF_FICR); | ^~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:87:51: note: in definition of macro 'BUILD_ASSERT' 87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG) | ^~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET' 69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET' 64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code) | ^~~~~~~~~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE' 59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1' 180 | Z_COND_CODE_1(_flag, _if_1_code, _else_code) | ^~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:378:23: note: in expansion of macro 'COND_CODE_1' 378 | #define UTIL_OR(a, b) COND_CODE_1(UTIL_BOOL(a), (a), (b)) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:101:17: note: in expansion of macro 'UTIL_OR' 101 | UTIL_OR(UTIL_NOT(DT_REG_HAS_IDX(DT_NODELABEL(lbl), 0)), \ | ^~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:176:1: note: in expansion of macro 'CHECK_DT_REG' 176 | CHECK_DT_REG(ficr, NRF_FICR); | ^~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:102:25: error: expression in static assertion is not an integer 102 | (DT_REG_ADDR(DT_NODELABEL(lbl)) == (uint32_t)(mdk_addr)))) | ^ C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:87:51: note: in definition of macro 'BUILD_ASSERT' 87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG) | ^~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET' 69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET' 64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code) | ^~~~~~~~~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE' 59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1' 180 | Z_COND_CODE_1(_flag, _if_1_code, _else_code) | ^~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:378:23: note: in expansion of macro 'COND_CODE_1' 378 | #define UTIL_OR(a, b) COND_CODE_1(UTIL_BOOL(a), (a), (b)) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:101:17: note: in expansion of macro 'UTIL_OR' 101 | UTIL_OR(UTIL_NOT(DT_REG_HAS_IDX(DT_NODELABEL(lbl), 0)), \ | ^~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:176:1: note: in expansion of macro 'CHECK_DT_REG' 176 | CHECK_DT_REG(ficr, NRF_FICR); | ^~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:275:19: error: 'NRF_SPU' undeclared here (not in a function); did you mean 'NRF_FPU'? 275 | CHECK_DT_REG(spu, NRF_SPU); | ^~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:87:51: note: in definition of macro 'BUILD_ASSERT' 87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG) | ^~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET' 69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET' 64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code) | ^~~~~~~~~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE' 59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1' 180 | Z_COND_CODE_1(_flag, _if_1_code, _else_code) | ^~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:378:23: note: in expansion of macro 'COND_CODE_1' 378 | #define UTIL_OR(a, b) COND_CODE_1(UTIL_BOOL(a), (a), (b)) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:101:17: note: in expansion of macro 'UTIL_OR' 101 | UTIL_OR(UTIL_NOT(DT_REG_HAS_IDX(DT_NODELABEL(lbl), 0)), \ | ^~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:275:1: note: in expansion of macro 'CHECK_DT_REG' 275 | CHECK_DT_REG(spu, NRF_SPU); | ^~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:102:25: error: expression in static assertion is not an integer 102 | (DT_REG_ADDR(DT_NODELABEL(lbl)) == (uint32_t)(mdk_addr)))) | ^ C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:87:51: note: in definition of macro 'BUILD_ASSERT' 87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG) | ^~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET' 69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET' 64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code) | ^~~~~~~~~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE' 59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1' 180 | Z_COND_CODE_1(_flag, _if_1_code, _else_code) | ^~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:378:23: note: in expansion of macro 'COND_CODE_1' 378 | #define UTIL_OR(a, b) COND_CODE_1(UTIL_BOOL(a), (a), (b)) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:101:17: note: in expansion of macro 'UTIL_OR' 101 | UTIL_OR(UTIL_NOT(DT_REG_HAS_IDX(DT_NODELABEL(lbl), 0)), \ | ^~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:275:1: note: in expansion of macro 'CHECK_DT_REG' 275 | CHECK_DT_REG(spu, NRF_SPU); | ^~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:326:20: error: 'NRF_UICR' undeclared here (not in a function); did you mean 'NRF_UICR_S'? 326 | CHECK_DT_REG(uicr, NRF_UICR); | ^~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:87:51: note: in definition of macro 'BUILD_ASSERT' 87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG) | ^~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET' 69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET' 64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code) | ^~~~~~~~~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE' 59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1' 180 | Z_COND_CODE_1(_flag, _if_1_code, _else_code) | ^~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:378:23: note: in expansion of macro 'COND_CODE_1' 378 | #define UTIL_OR(a, b) COND_CODE_1(UTIL_BOOL(a), (a), (b)) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:101:17: note: in expansion of macro 'UTIL_OR' 101 | UTIL_OR(UTIL_NOT(DT_REG_HAS_IDX(DT_NODELABEL(lbl), 0)), \ | ^~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:326:1: note: in expansion of macro 'CHECK_DT_REG' 326 | CHECK_DT_REG(uicr, NRF_UICR); | ^~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:102:25: error: expression in static assertion is not an integer 102 | (DT_REG_ADDR(DT_NODELABEL(lbl)) == (uint32_t)(mdk_addr)))) | ^ C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:87:51: note: in definition of macro 'BUILD_ASSERT' 87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG) | ^~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET' 69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET' 64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code) | ^~~~~~~~~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE' 59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1' 180 | Z_COND_CODE_1(_flag, _if_1_code, _else_code) | ^~~~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/include/zephyr/sys/util_macro.h:378:23: note: in expansion of macro 'COND_CODE_1' 378 | #define UTIL_OR(a, b) COND_CODE_1(UTIL_BOOL(a), (a), (b)) | ^~~~~~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:101:17: note: in expansion of macro 'UTIL_OR' 101 | UTIL_OR(UTIL_NOT(DT_REG_HAS_IDX(DT_NODELABEL(lbl), 0)), \ | ^~~~~~~ C:/ncs/v2.7.0/zephyr/soc/nordic/validate_base_addresses.c:326:1: note: in expansion of macro 'CHECK_DT_REG' 326 | CHECK_DT_REG(uicr, NRF_UICR); | ^~~~~~~~~~~~
Are there any examples of how to apply readout flash protection in nrf9160 ns builds?
Best regards, Valerii
