SerialPort.setPortName(name); SerialPort.setBaudRate(QSerialPort::Baud115200); //设置数据位数 SerialPort.setDataBits(QSerialPort::Data8); // 设置校验位 //SerialPort->setParity(QSerialPort::NoParity); //设置奇偶校验 SerialPort.setParity(QSerialPort::NoParity); // 设置流控制 SerialPort.setFlowControl(QSerialPort::NoFlowControl); //设置停止位 SerialPort.setStopBits(QSerialPort::OneStop); qDebug() << "Application path:" << name; // 打开串口 if(SerialPort.open(QIODevice::ReadWrite)) { // 设置波特率 //qDebug() <<SerialPort.waitForBytesWritten(3000); //SerialPort.close(); } //打开串口 else { QMessageBox::about(NULL, "提示", "串口无法打开\r\n不存在或已被占用"); return; }
I am using qt C++ to refactor the dfu master station, currently I have a problem, that is, I want to communicate with 52840 simulated com but failed, I initialize, you see this is correct, I try to initialize the send command 0x06,0x01,0x0c after successful sending DFU did not respond, I want to know what's wrong. Thank you
