Im using custom board carring nrf52820,and i want enable UART to contact with another mcu,this is the Schematic.
NCS V2.6.0.I take Peripherial_uart to Peripherial_hid_keyboard,and it can work in nrf52833DK,but can't in my custom board.
it contants RX,TX,CTS and RTS,and i think my configuration is matched.But cannot rec data sent from UART via PC like this.
and my prj.conf is here.I am not sure where the question is.Can u help pls?
# # Copyright (c) 2019 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_BT=y CONFIG_BT_DEBUG_LOG=y CONFIG_BT_MAX_CONN=1 CONFIG_BT_MAX_PAIRED=1 CONFIG_BT_SMP=y CONFIG_BT_L2CAP_TX_BUF_COUNT=5 CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="iDPRT_SCANNER" CONFIG_BT_DEVICE_APPEARANCE=961 CONFIG_BT_BAS=y CONFIG_BT_HIDS=y CONFIG_BT_HIDS_MAX_CLIENT_COUNT=1 CONFIG_BT_HIDS_DEFAULT_PERM_RW_ENCRYPT=y CONFIG_BT_GATT_UUID16_POOL_SIZE=40 CONFIG_BT_GATT_CHRC_POOL_SIZE=20 CONFIG_BT_CONN_CTX=y CONFIG_BT_DIS=y CONFIG_BT_DIS_PNP=y CONFIG_BT_DIS_MANUF="NordicSemiconductor" CONFIG_BT_DIS_PNP_VID_SRC=2 CONFIG_BT_DIS_PNP_VID=0x1915 CONFIG_BT_DIS_PNP_PID=0xEEEF CONFIG_BT_DIS_PNP_VER=0x0100 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_BT_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y #CONFIG_NVS=y CONFIG_SETTINGS=y # Enable DK LED and Buttons library #CONFIG_DK_LIBRARY=y # Enable the UART driver CONFIG_SERIAL=y CONFIG_UART_ASYNC_API=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_0_ASYNC=y CONFIG_UART_0_INTERRUPT_DRIVEN=n CONFIG_NRFX_UARTE0=y CONFIG_GPIO=y CONFIG_PINCTRL=y #CONFIG_NET_SHELL=n # Make sure printk is printing to the UART console CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y CONFIG_HEAP_MEM_POOL_SIZE=2048 # This example requires more stack CONFIG_MAIN_STACK_SIZE=2048 # Config logger CONFIG_LOG=y CONFIG_USE_SEGGER_RTT=n CONFIG_LOG_BACKEND_RTT=y CONFIG_LOG_BACKEND_UART=n CONFIG_LOG_PRINTK=n # CONFIG_LOG_MODE_IMMEDIATE=y #CONFIG_ASSERT=y # CONFIG_BT_DEVICE_NAME_DYNAMIC CONFIG_BT_DEVICE_NAME_DYNAMIC=y #param lock #CONFIG_PRIORITY_CEILING=y #=========start===================# #不包括外部 32k 晶振,则可以通过添加以下内容来改用内部 32k RC 振荡器: CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y #设计不包括DC-DC组件(下图红色框选部分),则可以通过添加以下内容来设置禁用 DCDC: CONFIG_BOARD_ENABLE_DCDC=n CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n #=====end======# #=================FAE=== decrease RAM usage======================# #CONFIG FROM # Disable Bluetooth features not needed CONFIG_BT_DEBUG_NONE=n CONFIG_BT_ASSERT=n CONFIG_BT_DATA_LEN_UPDATE=n CONFIG_BT_PHY_UPDATE=n CONFIG_BT_GATT_CACHING=n CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=n CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=n CONFIG_BT_HCI_VS_EXT=y # Disable Bluetooth controller features not needed CONFIG_BT_CTLR_PRIVACY=n CONFIG_BT_CTLR_PHY_2M=n # Disable features not needed CONFIG_TIMESLICING=n CONFIG_COMMON_LIBC_MALLOC=n #CONFIG_ASSERT=n # ARM CONFIG_ARM_MPU=n # Memory protection CONFIG_THREAD_STACK_INFO=y CONFIG_THREAD_CUSTOM_DATA=n CONFIG_FPU=n # Interrupts CONFIG_DYNAMIC_INTERRUPTS=n CONFIG_IRQ_OFFLOAD=n # Drivers and peripherals CONFIG_I2C=n CONFIG_WATCHDOG=n CONFIG_SPI=n
Best regards.
