I have to develop a BLE peripheral, that communicates larger amounts of data over L2CAP. Establishing the channel between central and peripheral works. I'm able to receive two SDUs and send two SDUs, until I find the application reproducible in a crashing situation.
In `zephyr/subsystem/bluetooth/l2cap.c`, I added a `manual` breakpoint (the if statement) in `struct net_buf *l2cap_data_pull(...)` after the currently transmitted `pdu` is pulled out of the `tx_queue` of the current connection:
/* Leave the PDU buffer in the queue until we have sent all its
* fragments.
* For SDUs we do the same, we keep it in the queue until all the
* segments have been sent, adding the PDU headers just-in-time.
struct net_buf *pdu = k_fifo_peek_head(&lechan->tx_queue);
if ( (char*)pdu - (char*)0 < 0x1000 )
__asm__("BKPT");
/* We don't have anything to send for the current channel. We could
* however have something to send on another channel that is attached to
The resulting `pdu` is somewhere located in the flash memory (0x4a), which is clearly not a valid value. I know, that there are millions of ways to shoot one self in the foot, in a multithreaded memory unsafe environment. I've created already some guard buffers around my buffer pool, but that does not changed the error situation. In the error case, the `tx_queue` looks "reasonable", while the head looks quite suspicious:
(gdb) p/x lechan->tx_queue
$2 = {_queue = {data_q = {head = 0x200370b0, tail = 0x200370e0}, lock = {thread_cpu = 0x0}, wait_q = {waitq = {{head = 0x200024fc,
next = 0x200024fc}, {tail = 0x200024fc, prev = 0x200024fc}}}, poll_events = {{head = 0x20002504, next = 0x20002504}, {tail = 0x20002504,
prev = 0x20002504}}}}
(gdb) p/x *(struct net_buf *)0x200370b0
$3 = {node = {next = 0x3414d}, frags = 0x4a, ref = 0x1, flags = 0x0, pool_id = 0x9, user_data_size = 0x0, {{data = 0x2003812d, len = 0xb,
size = 0x1014, __buf = 0x20038124}, b = {data = 0x2003812d, len = 0xb, size = 0x1014, __buf = 0x20038124}},
Is this code on the transmission side looking ok?
assert( data.size() <= CONFIG_MQTT_SN_LIB_MAX_PAYLOAD_SIZE );
net_buf * const buf = net_buf_alloc_fixed(
&mqtt_sn_messages_over_l2cap, K_FOREVER);
if ( !buf )
return 0;
net_buf_reserve(buf, BT_L2CAP_SDU_CHAN_SEND_RESERVE);
net_buf_add_mem(buf, data.data(), data.size());
const int rc = bt_l2cap_chan_send(l2cap_channel_, buf);
if (rc < 0) {
net_buf_unref(buf);
return 0;
assert( rc == 0 || rc == -ENOTCONN );
return data.size();
That's how the buffer pool is defined:
NET_BUF_POOL_FIXED_DEFINE(
CONFIG_MQTT_SN_LIB_MAX_PUBLISH,
CONFIG_MQTT_SN_LIB_MAX_PAYLOAD_SIZE + mqtt_sn_max_publish_overhead + BT_L2CAP_SDU_CHAN_SEND_RESERVE,
0, NULL);
best regards
Torsten
