Antenna Configuration for nRF9151-DK Board
Dear Support Team,
In the project, I'm working on thingy91:nrf9160 board. Our test case scenario is to connect to cellular network(NB-IoT) and acquire GPS fix for which we are following the steps as mentioned below:
1. Initialize the modem library
2. Register to network and connect to mobile network (NB-IoT)
3. Acquire GPS fixe using A-GPS services (i.e. from nrf-cloud) using external antenna
4. After GPS is acquired de-initialize the modem library and unregister from mobile network
5. Enter into sleep mode using k_sleep functionality for time being consider device stay in sleep state for 30min
6. Device wakes up from sleep after defined time interval and continues the cycle from step-1 onwards
We have successfully implemented the above test scenario on the Thingy:91 (nRF9160) board. Thus, resulting in achieving consistent network connectivity and GPS performance.
Below are the relevant configurations from our prj.conf file, used for the Thingy:91 with an external GNSS antenna and the onboard LTE antenna:
# LTE Link Control
CONFIG_LTE_LINK_CONTROL=y
# For using NbIoT network
CONFIG_LTE_MODE_PREFERENCE_NBIOT=y
#Disable this config to use the onboard antenna
CONFIG_MODEM_ANTENNA_GNSS_EXTERNAL=y
CONFIG_MODEM_ANTENNA_AT_MAGPIO="AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586"
CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0"
We are now porting the firmware to the nRF9151-DK board. However, when using the same configuration as prj.conf for external GNSS antenna and onboard LTE antenna, the DK board connects to NB-IoT network for first 3-4 times and then doesn't connect to cellular network even if we:
1. Turn off and then turn on the DK board.
2. Plug out/in the USB cable.
3. Flash the same firmware onto the board.
The nrf9151 DK board only connects back to NB-IoT network if same SIM which was inserted on thingy91:nrf9160 and which connects to NB-IoT mobile network is inserted on nrf9151 DK board.
We understand that the Thingy:91 uses a single antenna time-shared between GNSS and cellular network(NB-IoT), whereas the nRF9151-DK has separate antennas for GNSS and cellular network. So for thingy91 we were setting the MAGPIO for using GNSS and cellular network on time sharing basis.
thingy91-9160 GNSS and LTE antenna
nrf9151 DK GNSS and LTE antenna
Could you please advise on the necessary configuration changes required for the nRF9151-DK to ensure consistent NB-IoT connectivity?
Do let me know if you require any further information to guide me regarding the above query.
Best Regards,
Mahima
  • K board connects to NB-IoT network for first 3-4 times and then doesn't connect to cellular network even if we:
    It only works if you use the same SIM as you did for the Thingy91 project, but any SIM work the frist few times?
    Jonathan
  • For any SIM it works for the first few times only. The same is for the SIM used for thingy91 project, it works first few times and later stops working.
    On the nRF9160 DK board, if the SIM stops connecting to the NB-IoT network and is then inserted into a Thingy:91 board, it connects successfully. Interestingly, when the same SIM is reinserted into the DK board afterward, it starts connecting to the mobile network again.
    In the thingy91 since the antenna is shared between GNSS and Mobile Network (MN), the MAGPIO pin settings are configured along with enabling the external antenna. The configurations from prj.conf are as follows:
    Do we need to configure these setting for nrf9151 DK board as well? If yes, what MAGPIO pin configurations should be applied to optimize the antenna for efficient NB-IoT and GPS performance?
    Additionally, one more observation is that the thingy91 connects to the MN within few seconds (~15-20sec), whereas the DK board takes significantly longer (i.e. over 90sec) in scenarios when NB-IoT is connected.
  • Can you share what error you gett or a modem trace here.
    From your explanation and the details shared I am not able to make see a obvious issue here.
    Can you provide a modem trace for us so that we can investigate what is happening here step by step?
    Jonathan
