I just ported your AWS IoT for MQTT from this repository.
If I keep IPv6 enabled, I can get the address information without any problem. However, if I disable IPv6, the result is not null, but the application crashes at if (addr->ai_family == AF_INET6)
and gets stuck. So any opinion to work aroud.
Zephyr:
revision: v4.0-branch
Nrf:
revision: v2.9-branch
[00:00:57.088,000] <err> os: ***** USAGE FAULT ***** [00:00:57.088,000] <err> os: Unaligned memory access [00:00:57.088,000] <err> os: r0/a1: 0x00000011 r1/a2: 0x00000000 r2/a3: 0x00000012 [00:00:57.088,000] <err> os: r3/a4: 0x20007fa0 r12/ip: 0x00000317 r14/lr: 0x080567d1 [00:00:57.088,000] <err> os: xpsr: 0x21000000 [00:00:57.088,000] <err> os: s[ 0]: 0x00000301 s[ 1]: 0x00000010 s[ 2]: 0x00000000 s[ 3]: 0x2008d5f4 [00:00:57.088,000] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x080ab79b s[ 6]: 0x00000000 s[ 7]: 0x00000000 [00:00:57.088,000] <err> os: s[ 8]: 0x00000000 s[ 9]: 0x44554b2b s[10]: 0x43525f50 s[11]: 0x22203a56 [00:00:57.088,000] <err> os: s[12]: 0x312e3031 s[13]: 0x312e3530 s[14]: 0x35322e36 s[15]: 0x352c2234 [00:00:57.088,000] <err> os: fpscr: 0x00000033 [00:00:57.088,000] <err> os: Faulting instruction address (r15/pc): 0x080567d0 [00:00:57.088,000] <err> os: >>> ZEPHYR FATAL ERROR 31: Unknown error on CPU 0 [00:00:57.088,000] <err> os: Current thread: 0x20013218 (sysworkq) [00:00:57.329,000] <err> os: Halting system
static int broker_init(struct sockaddr_storage *broker, struct mqtt_helper_conn_params *conn_params) { int err; struct addrinfo *result; struct addrinfo *addr; struct addrinfo hints = { .ai_socktype = SOCK_STREAM }; char addr_str[NET_IPV6_ADDR_LEN]; printk("%d %s\n", __LINE__, __func__); if (sizeof(CONFIG_MQTT_HELPER_STATIC_IP_ADDRESS) > 1) { conn_params->hostname.ptr = CONFIG_MQTT_HELPER_STATIC_IP_ADDRESS; LOG_DBG("Using static IP address: %s", CONFIG_MQTT_HELPER_STATIC_IP_ADDRESS); } else { LOG_DBG("Resolving IP address for %s", conn_params->hostname.ptr); } err = getaddrinfo(conn_params->hostname.ptr, NULL, &hints, &result); if (err) { LOG_ERR("getaddrinfo() failed, error %d", err); return -err; } printk("%d %s\n", __LINE__, __func__); addr = result; printk("%d %s\n", __LINE__, __func__); while (addr != NULL) { printk("%d %s\n", __LINE__, __func__); if (addr->ai_family == AF_INET6) { printk("%d %s\n", __LINE__, __func__); struct sockaddr_in6 *broker6 = ((struct sockaddr_in6 *)broker); net_ipaddr_copy(&broker6->sin6_addr, &((struct sockaddr_in6 *)addr->ai_addr)->sin6_addr); broker6->sin6_family = addr->ai_family; broker6->sin6_port = htons(CONFIG_MQTT_HELPER_PORT); inet_ntop(addr->ai_family, &broker6->sin6_addr, addr_str, sizeof(addr_str)); LOG_DBG("IPv6 Address found %s (%s)", addr_str, net_family2str(addr->ai_family)); break; } else if (addr->ai_family == AF_INET) { printk("%d %s\n", __LINE__, __func__); struct sockaddr_in *broker4 = ((struct sockaddr_in *)broker); net_ipaddr_copy(&broker4->sin_addr, &((struct sockaddr_in *)addr->ai_addr)->sin_addr); broker4->sin_family = addr->ai_family; broker4->sin_port = htons(CONFIG_MQTT_HELPER_PORT); inet_ntop(addr->ai_family, &broker4->sin_addr, addr_str, sizeof(addr_str)); LOG_DBG("IPv4 Address found %s (%s)", addr_str, net_family2str(addr->ai_family)); break; } else { LOG_DBG("Unknown address family %d", (unsigned int)addr->ai_family); } printk("%d %s\n", __LINE__, __func__); addr = addr->ai_next; } freeaddrinfo(result); return err; }
