How can I minimize operating current as lower as possible?
Hello~
I am developing nrf52840 with zephyr ncs tool chain v2.7.0 and SDK v2.6.1.
Our hadware is very simple, just a power IC, a nrf52840 and a G-sensor.
Our pre-production PCB average current is 600uA when normal operating. We want to minimize it to around 120uA (This is the estimate current value we get from here:  Online Power Profiler for Bluetooth LE  )
When normal operation, without scan, with advertising and sleep 100 ms in main loop. And we  turned on ADC, I2C also.
And when normal operation, G-sensor is off.
We turn on DCDC also.
This is our Device tree, we had turned off all unused function blocks.
    zephyr,user {
        io-channels = <&adc 0>;
    // redefine button pins
    // Left :   buttonL
    // Right :  buttonR
    // Up:      buttonU
    // Down :   buttonD
    // PWR  :   buttonP
    buttons {
        compatible = "gpio-keys";
        debounce-interval-ms = <200>;
        buttonL: button_0 {
            gpios = <&gpio0 26 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            label = "Left button switch 1";
            zephyr,code = <INPUT_KEY_0>;
        buttonR: button_1 {
            gpios = <&gpio0 27 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            label = "Right button switch 2";
            zephyr,code = <INPUT_KEY_1>;
        buttonU: button_2 {
            gpios = <&gpio0 6 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            label = "Up button switch 3";
            zephyr,code = <INPUT_KEY_2>;
        buttonP: button_3 {        // the middle one
            gpios = <&gpio0 7 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            label = "Down button switch 4";
            zephyr,code = <INPUT_KEY_3>;
        buttonB: button_4 {        // the bottom one
            gpios = <&gpio0 5 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
            label = "Power button switch 5";
            zephyr,code = <INPUT_KEY_5>;
    leds {
		compatible = "gpio-leds";
		led0: led_0 {
			gpios = <&gpio1 4 GPIO_ACTIVE_LOW>;
			label = "Red LED 0";
		led1: led_1 {
			gpios = <&gpio1 7 GPIO_ACTIVE_LOW>;
			label = "Green LED 1";
		led2: led_2 {
			gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
			label = "Blue LED 2";
    aliases {
        btn0 = &buttonL;
        btn1 = &buttonR;
        btn2 = &buttonU;
        btn3 = &buttonP;
		btn4 = &buttonB;
    gpio-inputs
        gsensor_int: gsensor_int {
            gpios = <&gpio0 11 (GPIO_ACTIVE_HIGH)>;
            label = "g-sensor interrupt";
            zephyr,code = <INPUT_KEY_6>;
    gpio-outputs
        adc_en: adc_en {
            gpios = <&gpio0 3 GPIO_ACTIVE_HIGH>;
            label = "ADC enable";
&adc {
       #address-cells = <1>;
       #size-cells = <0>;
       status= "okay";
       channel@0 {
           reg= <0>;
           zephyr,gain = "ADC_GAIN_1_6";
           zephyr,reference = "ADC_REF_INTERNAL";
           zephyr,acquisition-time = <ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 10)>; //<ADC_ACQ_TIME_DEFAULT> : 10us
           zephyr,input-positive = <NRF_SAADC_AIN2>; // P0.04
           zephyr,resolution = <12>;
           zephyr,oversampling = <8>;
&i2c0 {
	status = "okay";
	clock-frequency = <100000>;
    pinctrl-0 = <&i2c0_default>;
	pinctrl-1 = <&i2c0_sleep>;
    zephyr,concat-buf-size = <64>;
    zephyr,flash-buf-max-size = <64>;
	/*Gsensor:Gsensor@50 {
        compatible = "i2c-device";
		label = "i2c Gsensor addr 0x50";
		reg = <0x50>;
&pinctrl {
    i2c0_default: i2c0_default {
        group1 {
            psels = <NRF_PSEL(TWIM_SDA, 0, 12)>,
                <NRF_PSEL(TWIM_SCL, 0, 13)>;
    i2c0_sleep: i2c0_sleep {
		group1 {
			low-power-enable;
    // reserve form mp debug
    uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 29)>,
				<NRF_PSEL(UART_RTS, 0, 8)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 0, 30)>,
				<NRF_PSEL(UART_CTS, 0, 7)>;
			bias-pull-up;
	uart0_sleep: uart0_sleep {
		group1 {
				<NRF_PSEL(UART_RTS, 0, 8)>,
			low-power-enable;
//uart0 confict with button3,4
&uart0 {
    status="disabled";
&uart1 {
    status="disabled";
&pwm0 {
    status="disabled";
&i2c1 {
    status="disabled";
&spi0 {
    status="disabled";
&spi1 {
    status="disabled";
&qspi {
    status="disabled";
&spi3 {
    status="disabled";
&ieee802154 {
    status="disabled";
&usbd {
    status="disabled";
&power {
    status = "okay";
&clock {
    status = "okay";
&acl {
    status = "disabled";
&cryptocell {
    status = "okay";
&temp {
&nfct {
&wdt {
This is power management settings in our project:
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
CONFIG_POWEROFF=y
CONFIG_PM_CPU_OPS=y
CONFIG_BOARD_ENABLE_DCDC=y
Do you have any ideas on "how to minimize operating current to 120 uA " ?
  • Hi~
    About questions:
    1. Did you try to load the 'system_on_current_meas_test.hex' I included in the *.zip?
    Ans: No, out engineer told me, they modify main.c to two projects. one is all sleep, the other is all on.
    2. Does this include the current going into the sensor?
    Ans: Since G-sensor is not activated, what I can tell is "G-sensor has power supply, but not activated."
  • I'm afraid this doesn't really help us troubleshoot the problem. I still don't know if the current measurement setup is able to correctly measure the sleep current of the chip, how much current the sensor will draw in this state, how your FW is configured, etc. Have you tried measuring the sleep current yourself with a ampmeter? And what is the expected idle current for the g-sensor in the state it is in?
  • Hi~
    About your questions:
    1. Have you tried measuring the sleep current yourself with a ampmeter?
    NO, job of measuring current is done by our hardware partner.
    2. And what is the expected idle current for the g-sensor in the state it is in?
    It's around 36 uA according to it's datasheet.
    But huge thanks for your help, I think we have to measure current by ourself first.
