nrf52832 central and peripheral string send issue
hi destiny98 i also working on sending string from peripheral to central but central device not able to receive it and show the same message every time, here i attach code snippet, please guide me to resolve this issue.
another thing is that i am use ble_app_hrs_c for central device and ble_app_hrs for peripheral device and make modification in it as i need, here i attach my both code also.
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
 * @brief Heart Rate Service Sample Application main file.
 * This file contains the source code for a sample application using the Heart Rate service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
//=========================================Modify Peripheral Code=================================================================
#include "app_error.h"
#include "app_timer.h"
#include "ble.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
#include "ble_dis.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_hrs.h"
#include "ble_srv_common.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdm.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "sensorsim.h"
#include <stdint.h>
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME "PR_007"                    /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300                    /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG 1  /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81                              /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100                             /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT 1                         /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL APP_TIMER_TICKS(1000) /**< Heart rate measurement interval (ticks). */
#define MIN_HEART_RATE 140                             /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE 300                             /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT 10                        /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL APP_TIMER_TICKS(300) /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL 100                       /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL 500                       /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT 1                   /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL APP_TIMER_TICKS(5000) /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(400, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(650, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY 0                                    /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)   /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define LESC_DEBUG_MODE 0 /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND 1                               /**< Perform bonding. */
#define SEC_PARAM_MITM 0                               /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 1                               /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS 0                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0                                /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16                      /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_HRS_DEF(m_hrs);                       /**< Heart rate service instance. */
BLE_BAS_DEF(m_bas);                       /**< Structure used to identify the battery service. */
NRF_BLE_GATT_DEF(m_gatt);                 /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                   /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);       /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id);        /**< Battery timer. */
APP_TIMER_DEF(m_heart_rate_timer_id);     /**< Heart rate measurement timer. */
APP_TIMER_DEF(m_rr_interval_timer_id);    /**< RR interval timer. */
APP_TIMER_DEF(m_sensor_contact_timer_id); /**< Sensor contact detected timer. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static bool m_rr_interval_enabled = true;                /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t m_battery_sim_cfg;         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;     /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t m_heart_rate_sim_cfg;      /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state;  /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t m_rr_interval_sim_cfg;     /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state; /**< RR Interval sensor simulator state. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
        {BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}};
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void) {
  ret_code_t err_code;
  NRF_LOG_INFO("Erase bonds!");
  err_code = pm_peers_delete();
void advertising_start(bool erase_bonds) {
  if (erase_bonds == true) {
    delete_bonds();
    // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
  } else {
    err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const *p_evt) {
  pm_handler_on_pm_evt(p_evt);
  pm_handler_disconnect_on_sec_failure(p_evt);
  pm_handler_flash_clean(p_evt);
  switch (p_evt->evt_id) {
    advertising_start(false);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void) {
  uint8_t battery_level;
  battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
  err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
  if ((err_code != NRF_SUCCESS) &&
      (err_code != NRF_ERROR_INVALID_STATE) &&
      (err_code != NRF_ERROR_BUSY) &&
      (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)) {
    APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void *p_context) {
  UNUSED_PARAMETER(p_context);
  battery_level_update();
/**@brief Function for handling the Heart rate measurement timer timeout.
 * @details This function will be called each time the heart rate measurement timer expires.
 *          It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(void *p_context) {
  char message[] = "hello slave";
  uint16_t length = strlen(message);
  ble_gatts_hvx_params_t hvx_params = {
      .handle = m_hrs.hrm_handles.value_handle, // Use the correct value handle
      .type = BLE_GATT_HVX_NOTIFICATION,        // Notification type
      .offset = 0,
      .p_len = &length,             // Pointer to message length
      .p_data = (uint8_t *)message, // Pointer to the message data
  err_code = sd_ble_gatts_hvx(m_conn_handle, &hvx_params);
  if (err_code == NRF_SUCCESS) {
    NRF_LOG_INFO("Message sent: %s", message);
  } else {
    NRF_LOG_ERROR("Failed to send message: 0x%x", err_code);
/**@brief Function for handling the RR interval timer timeout.
 * @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(void *p_context) {
  if (m_rr_interval_enabled) {
    uint16_t rr_interval;
    rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
        &m_rr_interval_sim_cfg);
    ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer timeout.
 * @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(void *p_context) {
  static bool sensor_contact_detected = false;
  sensor_contact_detected = !sensor_contact_detected;
  ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void) {
  // Initialize timer module.
  err_code = app_timer_init();
  // Create timers.
  err_code = app_timer_create(&m_battery_timer_id,
      APP_TIMER_MODE_REPEATED,
      battery_level_meas_timeout_handler);
  err_code = app_timer_create(&m_heart_rate_timer_id,
      heart_rate_meas_timeout_handler);
  err_code = app_timer_create(&m_rr_interval_timer_id,
      rr_interval_timeout_handler);
  err_code = app_timer_create(&m_sensor_contact_timer_id,
      sensor_contact_detected_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
static void gap_params_init(void) {
  ble_gap_conn_params_t gap_conn_params;
      (const uint8_t *)DEVICE_NAME,
      strlen(DEVICE_NAME));
  err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
  gap_conn_params.slave_latency = SLAVE_LATENCY;
  gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt) {
  if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED) {
    NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
        p_evt->conn_handle,
        p_evt->params.att_mtu_effective);
  ble_hrs_on_gatt_evt(&m_hrs, p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void) {
  ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
static void nrf_qwr_error_handler(uint32_t nrf_error) {
  APP_ERROR_HANDLER(nrf_error);
 * @details Initialize the Heart Rate, Battery and Device Information services.
static void services_init(void) {
  ble_hrs_init_t hrs_init;
  ble_bas_init_t bas_init;
  ble_dis_init_t dis_init;
  uint8_t body_sensor_location;
  // Initialize Heart Rate Service.
  body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
  memset(&hrs_init, 0, sizeof(hrs_init));
  hrs_init.evt_handler = NULL;
  hrs_init.is_sensor_contact_supported = false;
  hrs_init.p_body_sensor_location = &body_sensor_location;
  // Here the sec level for the Heart Rate Service can be changed/increased.
  hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
  hrs_init.bsl_rd_sec = SEC_OPEN;
  err_code = ble_hrs_init(&m_hrs, &hrs_init);
  // Initialize Battery Service.
  memset(&bas_init, 0, sizeof(bas_init));
  bas_init.evt_handler = NULL;
  bas_init.support_notification = true;
  bas_init.p_report_ref = NULL;
  bas_init.initial_batt_level = 100;
  // Here the sec level for the Battery Service can be changed/increased.
  bas_init.bl_rd_sec = SEC_OPEN;
  bas_init.bl_cccd_wr_sec = SEC_OPEN;
  bas_init.bl_report_rd_sec = SEC_OPEN;
  err_code = ble_bas_init(&m_bas, &bas_init);
  // Initialize Device Information Service.
  memset(&dis_init, 0, sizeof(dis_init));
  ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
  dis_init.dis_char_rd_sec = SEC_OPEN;
  err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void) {
  m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
  m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
  m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
  m_battery_sim_cfg.start_at_max = true;
  sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
  m_heart_rate_sim_cfg.min = MIN_HEART_RATE;
  m_heart_rate_sim_cfg.max = MAX_HEART_RATE;
  m_heart_rate_sim_cfg.incr = HEART_RATE_INCREMENT;
  m_heart_rate_sim_cfg.start_at_max = false;
  sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
  m_rr_interval_sim_cfg.min = MIN_RR_INTERVAL;
  m_rr_interval_sim_cfg.max = MAX_RR_INTERVAL;
  m_rr_interval_sim_cfg.incr = RR_INTERVAL_INCREMENT;
  m_rr_interval_sim_cfg.start_at_max = false;
  sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void) {
  // Start application timers.
  // err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
  // APP_ERROR_CHECK(err_code);
  err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
  err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
  err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
  if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
/**@brief Function for handling a Connection Parameters error.
static void conn_params_error_handler(uint32_t nrf_error) {
static void conn_params_init(void) {
  cp_init.p_conn_params = NULL;
  cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
  cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
  cp_init.start_on_notify_cccd_handle = m_hrs.hrm_handles.cccd_handle;
  cp_init.disconnect_on_fail = false;
  cp_init.evt_handler = on_conn_params_evt;
  cp_init.error_handler = conn_params_error_handler;
static void sleep_mode_enter(void) {
  // Prepare wakeup buttons.
static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
  switch (ble_adv_evt) {
  case BLE_ADV_EVT_FAST:
    NRF_LOG_INFO("Fast advertising.");
  case BLE_ADV_EVT_IDLE:
    sleep_mode_enter();
static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
  switch (p_ble_evt->header.evt_id) {
  case BLE_GAP_EVT_CONNECTED:
    // NRF_LOG_INFO("Connected.");
    NRF_LOG_INFO("Connected. Hello_I_am_Central_Device!!");
    err_code = pm_conn_secure(p_ble_evt->evt.gap_evt.conn_handle, false);
    if (err_code != NRF_ERROR_BUSY) {
    NRF_LOG_INFO("Disconnected, reason %d.",
        p_ble_evt->evt.gap_evt.params.disconnected.reason);
  case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
    ble_gap_phys_t const phys =
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
  } break;
  case BLE_GATTC_EVT_TIMEOUT:
  case BLE_GATTS_EVT_TIMEOUT:
    NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
  case BLE_GAP_EVT_AUTH_KEY_REQUEST:
    NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
  case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
    NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
  case BLE_GAP_EVT_AUTH_STATUS:
    NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
        p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
        p_ble_evt->evt.gap_evt.params.auth_status.bonded,
        p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
        *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
        *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
    // No implementation needed.
static void ble_stack_init(void) {
  uint32_t ram_start = 0;
  // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
void bsp_event_handler(bsp_event_t event) {
  switch (event) {
  case BSP_EVENT_SLEEP:
    sleep_mode_enter();
  case BSP_EVENT_DISCONNECT:
    if (err_code != NRF_ERROR_INVALID_STATE) {
  case BSP_EVENT_WHITELIST_OFF:
    // if (m_conn_handle == BLE_CONN_HANDLE_INVALID)
    if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
      NRF_LOG_WARNING("Invalid connection handle. Cannot send message.");
      return;
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void) {
  err_code = pm_init();
  sec_param.bond = SEC_PARAM_BOND;
  sec_param.mitm = SEC_PARAM_MITM;
  sec_param.lesc = SEC_PARAM_LESC;
  sec_param.keypress = SEC_PARAM_KEYPRESS;
  sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
  sec_param.oob = SEC_PARAM_OOB;
  sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
  sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
  sec_param.kdist_own.enc = 1;
  sec_param.kdist_own.id = 1;
  sec_param.kdist_peer.enc = 1;
  sec_param.kdist_peer.id = 1;
static void advertising_init(void) {
  ble_advertising_init_t init;
  init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
  init.advdata.include_appearance = true;
  init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
  init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
  init.advdata.uuids_complete.p_uuids = m_adv_uuids;
  init.config.ble_adv_fast_enabled = true;
  init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
static void buttons_leds_init(bool *p_erase_bonds) {
  bsp_event_t startup_event;
  err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void) {
static void power_management_init(void) {
static void idle_state_handle(void) {
  err_code = nrf_ble_lesc_request_handler();
  if (NRF_LOG_PROCESS() == false) {
    nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
int main(void) {
  bool erase_bonds;
  // Initialize.
  log_init();
  timers_init();
  power_management_init();
  ble_stack_init();
  gap_params_init();
  gatt_init();
  advertising_init();
  services_init();
  sensor_simulator_init();
  conn_params_init();
  peer_manager_init();
  // Start execution.
  NRF_LOG_INFO("Heart Rate Sensor example started.");
  application_timers_start();
  advertising_start(erase_bonds);
  // Enter main loop.
  for (;;) {
    idle_state_handle();
 * @brief BLE Heart Rate Collector application main file.
 * This file contains the source code for a sample heart rate collector.
//====================================================Central Modify Code========================================================
#include "app_util.h"
#include "ble.h"
#include "ble_bas_c.h"
#include "ble_db_discovery.h"
#include "ble_hrs_c.h"
#include "fds.h"
#include "nrf_ble_scan.h"
#include "nrf_fstorage.h"
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#define APP_SOC_OBSERVER_PRIO 1 /**< Applications' SoC observer priority. You shouldn't need to modify this value. */
#define SEC_PARAM_MIN_KEY_SIZE 7                       /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE 16                      /**< Maximum encryption key size in octets. */
#define SCAN_DURATION_WITELIST 3000 /**< Duration of the scanning in units of 10 milliseconds. */
//#define TARGET_UUID                 BLE_UUID_HEART_RATE_SERVICE         /**< Target device uuid that application is looking for. */
#define CUSTOM_SERVICE_UUID 0x03, 0xB8, 0x0E, 0x5A, 0xED, 0xE8, 0x4B, 0x33, 0xA7, 0x51, 0x6C, 0xE3, 0x4E, 0xC4, 0xC7, 0x00
#define CUSTOM_CHARACTERISTIC_UUID 0x77, 0x72, 0xE5, 0xDB, 0x38, 0x68, 0x41, 0x12, 0xA1, 0xA9, 0xF2, 0x66, 0x9D, 0x10, 0x6B, 0xF3
// The descriptor UUID 0x2902 is a 16-bit UUID for the Client Characteristic Configuration Descriptor
#define CCCD_UUID 0x2902
// Define the target UUID as your custom service UUID
#define TARGET_UUID CUSTOM_SERVICE_UUID
static ble_uuid128_t custom_service_uuid = {
    .uuid128 = {CUSTOM_SERVICE_UUID}};
static ble_uuid128_t custom_characteristic_uuid = {
    .uuid128 = {CUSTOM_CHARACTERISTIC_UUID}};
// The CCCD UUID is already defined in the SDK, you can use BLE_UUID_DESCRIPTOR_CLIENT_CHAR_CONFIG
/**@brief Macro to unpack 16bit unsigned UUID from octet stream. */
#define UUID16_EXTRACT(DST, SRC) \
  do {                           \
    (*(DST)) = (SRC)[1];         \
    (*(DST)) <<= 8;              \
    (*(DST)) |= (SRC)[0];        \
  } while (0)
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
    NRF_SDH_BLE_CENTRAL_LINK_COUNT,
    NRF_BLE_GQ_QUEUE_SIZE);
BLE_HRS_C_DEF(m_hrs_c);          /**< Structure used to identify the heart rate client module. */
BLE_BAS_C_DEF(m_bas_c);          /**< Structure used to identify the Battery Service client module. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);        /**< Scanning module instance. */
static uint16_t m_conn_handle;           /**< Current connection handle. */
static bool m_whitelist_disabled;        /**< True if whitelist has been temporarily disabled. */
static bool m_memory_access_in_progress; /**< Flag to keep track of ongoing operations on persistent memory. */
/**< Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_param =
        .active = 0x01,
#if (NRF_SD_BLE_API_VERSION > 7)
        .interval_us = NRF_BLE_SCAN_SCAN_INTERVAL * UNIT_0_625_MS,
        .window_us = NRF_BLE_SCAN_SCAN_WINDOW * UNIT_0_625_MS,
#else
        .interval = NRF_BLE_SCAN_SCAN_INTERVAL,
        .window = NRF_BLE_SCAN_SCAN_WINDOW,
#endif // (NRF_SD_BLE_API_VERSION > 7)
        .filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
        .timeout = SCAN_DURATION_WITELIST,
        .scan_phys = BLE_GAP_PHY_1MBPS,
/**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
 *  if these are set to empty strings, the UUIDs defined below will be used
static char const m_target_periph_name[] = "PR_007"; /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
static bool is_connect_per_addr = false;             /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
static ble_gap_addr_t const m_target_periph_addr =
        /* Possible values for addr_type:
           BLE_GAP_ADDR_TYPE_PUBLIC,
           BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
           BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
           BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
        .addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
        .addr = {0x8D, 0xFE, 0x23, 0x86, 0x77, 0xD9}};
static void scan_start(void);
/**@brief Function for asserts in the SoftDevice.
 * @param[in] p_file_name  File name of the failing ASSERT call.
  app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Heart Rate Service Client and Battery Service Client errors.
static void service_error_handler(uint32_t nrf_error) {
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t *p_evt) {
  ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
  ble_bas_on_db_disc_evt(&m_bas_c, p_evt);
    // Bonds are deleted. Start scanning.
    scan_start();
 * @brief Function for shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event) {
  switch (event) {
  case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
  return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
  ble_gap_evt_t const *p_gap_evt = &p_ble_evt->evt.gap_evt;
  case BLE_GAP_EVT_CONNECTED: {
    // Discover peer's services.
    err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
    if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT) {
      scan_start();
  } break;
  case BLE_GAP_EVT_DISCONNECTED: {
    NRF_LOG_INFO("Disconnected, reason 0x%x.",
        p_gap_evt->params.disconnected.reason);
      scan_start();
  } break;
  case BLE_GAP_EVT_TIMEOUT: {
    if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN) {
      NRF_LOG_INFO("Connection Request timed out.");
  } break;
  case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
    // Accepting parameters requested by peer.
    err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
        &p_gap_evt->params.conn_param_update_request.conn_params);
  } break;
/**@brief SoftDevice SoC event handler.
 * @param[in]   evt_id      SoC event.
 * @param[in]   p_context   Context.
static void soc_evt_handler(uint32_t evt_id, void *p_context) {
  switch (evt_id) {
  case NRF_EVT_FLASH_OPERATION_SUCCESS:
    /* fall through */
  case NRF_EVT_FLASH_OPERATION_ERROR:
    if (m_memory_access_in_progress) {
      m_memory_access_in_progress = false;
      scan_start();
  ble_uuid_t uuid;
  uint8_t uuid_type;
  // Add the custom service UUID to the BLE stack's table
  sd_ble_uuid_vs_add(&custom_service_uuid, &uuid_type);
  // Set up the UUID structure
  uuid.type = uuid_type;
  uuid.uuid = 0; // The least significant 16 bits of the UUID
  // Use this UUID structure when scanning for or connecting to your custom service
  // Register handlers for BLE and SoC events.
  NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
/** @brief Clear bonding information from persistent storage
/**@brief Function for disabling the use of whitelist for scanning.
static void whitelist_disable(void) {
  if (!m_whitelist_disabled) {
    NRF_LOG_INFO("Whitelist temporarily disabled.");
    m_whitelist_disabled = true;
    nrf_ble_scan_stop();
    scan_start();
  switch (event) {
    nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    whitelist_disable();
/**@brief Heart Rate Collector Handler.
static void hrs_c_evt_handler(ble_hrs_c_t *p_hrs_c, ble_hrs_c_evt_t *p_hrs_c_evt) {
  switch (p_hrs_c_evt->evt_type) {
  case BLE_HRS_C_EVT_HRM_NOTIFICATION: {
    uint8_t *data = (uint8_t *)p_hrs_c_evt->params.hrm.rr_intervals;
    uint16_t length = p_hrs_c_evt->params.hrm.rr_intervals_cnt;
    if (length > 0) {
      char message[20];
      memcpy(message, data, length);
      message[length] = '\0'; // Null-terminate the string
      NRF_LOG_INFO("Received message: %s", message);
    } else {
      NRF_LOG_WARNING("Invalid message length: %d", length);
  } break;
    NRF_LOG_INFO("Unhandled HRS client event: %d", p_hrs_c_evt->evt_type);
/**@brief Battery level Collector Handler.
// static void bas_c_evt_handler(ble_bas_c_t * p_bas_c, ble_bas_c_evt_t * p_bas_c_evt)
//     ret_code_t err_code;
//    switch (p_bas_c_evt->evt_type)
//        case BLE_BAS_C_EVT_DISCOVERY_COMPLETE:
//            err_code = ble_bas_c_handles_assign(p_bas_c,
//                                                p_bas_c_evt->conn_handle,
//                                                &p_bas_c_evt->params.bas_db);
//            // Battery service discovered. Enable notification of Battery Level.
//            NRF_LOG_DEBUG("Battery Service discovered. Reading battery level.");
//            err_code = ble_bas_c_bl_read(p_bas_c);
//            NRF_LOG_DEBUG("Enabling Battery Level Notification.");
//            err_code = ble_bas_c_bl_notif_enable(p_bas_c);
//        } break;
//        case BLE_BAS_C_EVT_BATT_NOTIFICATION:
//            //NRF_LOG_INFO("Battery Level received %d %%.", p_bas_c_evt->params.battery_level);
//            NRF_LOG_INFO("HELLO_CENTRAL_I_AM_PERIPHERAL_PR_007");
//            break;
//        case BLE_BAS_C_EVT_BATT_READ_RESP:
//            //NRF_LOG_INFO("Battery Level Read as %d %%.", p_bas_c_evt->params.battery_level);
//            break;
//        default:
//            break;
 * @brief Heart rate collector initialization.
static void hrs_c_init(void) {
  ble_hrs_c_init_t hrs_c_init_obj;
  hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
  hrs_c_init_obj.error_handler = service_error_handler;
  hrs_c_init_obj.p_gatt_queue = &m_ble_gatt_queue;
  ret_code_t err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
 * @brief Battery level collector initialization.
// static void bas_c_init(void)
//     ble_bas_c_init_t bas_c_init_obj;
//    bas_c_init_obj.evt_handler   = bas_c_evt_handler;
//    bas_c_init_obj.error_handler = service_error_handler;
//    bas_c_init_obj.p_gatt_queue  = &m_ble_gatt_queue;
//    ret_code_t err_code = ble_bas_c_init(&m_bas_c, &bas_c_init_obj);
 * @brief Database discovery collector initialization.
static void db_discovery_init(void) {
  ble_db_discovery_init_t db_init;
  memset(&db_init, 0, sizeof(db_init));
  db_init.evt_handler = db_disc_handler;
  db_init.p_gatt_queue = &m_ble_gatt_queue;
  ret_code_t err_code = ble_db_discovery_init(&db_init);
/**@brief Retrieve a list of peer manager peer IDs.
 * @param[inout] p_peers   The buffer where to store the list of peer IDs.
 * @param[inout] p_size    In: The size of the @p p_peers buffer.
 *                         Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t *p_peers, uint32_t *p_size) {
  pm_peer_id_t peer_id;
  uint32_t peers_to_copy;
  peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ? *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
  peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
  *p_size = 0;
  while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--)) {
    p_peers[(*p_size)++] = peer_id;
    peer_id = pm_next_peer_id_get(peer_id);
static void whitelist_load() {
  ret_code_t ret;
  pm_peer_id_t peers[8];
  uint32_t peer_cnt;
  memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
  peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
  // Load all peers from flash and whitelist them.
  peer_list_get(peers, &peer_cnt);
  ret = pm_whitelist_set(peers, peer_cnt);
  APP_ERROR_CHECK(ret);
  // Setup the device identies list.
  // Some SoftDevices do not support this feature.
  ret = pm_device_identities_list_set(peers, peer_cnt);
  if (ret != NRF_ERROR_NOT_SUPPORTED) {
static void on_whitelist_req(void) {
  // Whitelist buffers.
  ble_gap_addr_t whitelist_addrs[8];
  ble_gap_irk_t whitelist_irks[8];
  memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
  memset(whitelist_irks, 0x00, sizeof(whitelist_irks));
  uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
  uint32_t irk_cnt = (sizeof(whitelist_irks) / sizeof(ble_gap_irk_t));
  // Reload the whitelist and whitelist all peers.
  whitelist_load();
  // Get the whitelist previously set using pm_whitelist_set().
  err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
      whitelist_irks, &irk_cnt);
  if (((addr_cnt == 0) && (irk_cnt == 0)) ||
      (m_whitelist_disabled)) {
    // Don't use whitelist.
    err_code = nrf_ble_scan_params_set(&m_scan, NULL);
/**@brief Function to start scanning.
static void scan_start(void) {
  if (nrf_fstorage_is_busy(NULL)) {
    m_memory_access_in_progress = true;
    return;
  NRF_LOG_INFO("Starting scan.");
  err_code = nrf_ble_scan_start(&m_scan);
  err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for initializing the power management module. */
  case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED: {
        p_evt->conn_handle,
  } break;
  case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED: {
    NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
        p_evt->conn_handle,
        p_evt->params.data_length);
  } break;
static void scan_evt_handler(scan_evt_t const *p_scan_evt) {
  switch (p_scan_evt->scan_evt_id) {
  case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST: {
    on_whitelist_req();
    m_whitelist_disabled = false;
  } break;
  case NRF_BLE_SCAN_EVT_CONNECTING_ERROR: {
    err_code = p_scan_evt->params.connecting_err.err_code;
  } break;
  case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT: {
    NRF_LOG_INFO("Scan timed out.");
    scan_start();
  } break;
  case NRF_BLE_SCAN_EVT_FILTER_MATCH:
  case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
/**@brief Function for initializing the timer.
static void timer_init(void) {
/**@brief Function for initialization scanning and setting filters.
static void scan_init(void) {
  nrf_ble_scan_init_t init_scan;
  ble_uuid_t uuid;
  uint8_t uuid_type;
  memset(&init_scan, 0, sizeof(init_scan));
  init_scan.p_scan_param = &m_scan_param;
  init_scan.connect_if_match = true;
  init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
  err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
  // ble_uuid_t uuid =
  //     .uuid = TARGET_UUID,
  //     .type = BLE_UUID_TYPE_BLE,
  err_code = nrf_ble_scan_filter_set(&m_scan,
      SCAN_UUID_FILTER,
      &uuid);
  if (strlen(m_target_periph_name) != 0) {
        SCAN_NAME_FILTER,
        m_target_periph_name);
  if (is_connect_per_addr) {
        SCAN_ADDR_FILTER,
        m_target_periph_addr.addr);
  err_code = nrf_ble_scan_filters_enable(&m_scan,
      NRF_BLE_SCAN_ALL_FILTER,
      false);
 * @details Handle any pending log operation(s), then sleep until the next event occurs.
  NRF_LOG_FLUSH();
  nrf_pwr_mgmt_run();
/**@brief Function for starting a scan, or instead trigger it from peer manager (after
 *        deleting bonds).
 * @param[in] p_erase_bonds Pointer to a bool to determine if bonds will be deleted before scanning.
void scanning_start(bool *p_erase_bonds) {
  // Start scanning for peripherals and initiate connection
  // with devices that advertise GATT Service UUID.
  if (*p_erase_bonds == true) {
    // Scan is started by the PM_EVT_PEERS_DELETE_SUCCEEDED event.
    delete_bonds();
  } else {
    scan_start();
int main(void) {
  bool erase_bonds;
  // Initialize.
  log_init();
  timer_init();
  ble_stack_init();
  gatt_init();
  db_discovery_init();
  hrs_c_init();
  // bas_c_init();
  scan_init();
  // Start execution.
  NRF_LOG_INFO("Heart Rate collector example started.");
  scanning_start(&erase_bonds);
  // Enter main loop.
  for (;;) {
if (length > 0) {
char message[20];
} else {
} break;
  • Yes Hung Bui,
    firstly i try code without changes and i connect peripheral with mobile application and peripheral is able to receives data and able to show that data on serial monitor, but when i try to send data peripheral to mobile application via serial monitor it's not sending or mobile application not receives that string.
    after that i am with 1 central and 1 peripheral device but in this case peripheral not able to receives data as well as when it send data central not receives the data.
    Please guide me to made bi directional communication bridge between central and peripheral device.
    Note: I am use 2 nrf52832 device, SDK version 17.0.2 and segger version is 5.42a
    You may need to press enter before you can send. Or it need to hit the maximum data length.
    Please try to step in the code and debug. It's not a black box. You need to find the place where the data is sent from the peripheral and figure out why it's not called.
     switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
  • Thanks for reply Hung Bui,
    Currently when my peripheral device send data it receives by central device but issue in when central device send data the peripheral device not receives the data.
    i apply debugging logs and try different approach but peripheral not receives the data which send by central device.
    when i do same thing with mobile application as central device then it's works but for two nrf52832 device it's not works bi-directional.
    please guide me to complete this issue.
    here i attach central side and peripheral side code snippets.
    //Central Side:
    static void ble_nus_chars_received_uart_print(uint8_t *p_data, uint16_t data_len) {
      ret_code_t ret_val;
      NRF_LOG_DEBUG("Receiving data.");
      printf("Receiving data.\r\n");
      NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
      for (uint32_t i = 0; i < data_len; i++) {
        do {
          ret_val = app_uart_put(p_data[i]);
          if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY)) {
            NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
            printf("app_uart_put failed for index\r\n");
            APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
      if (p_data[data_len - 1] == '\r') {
        while (app_uart_put('\n') == NRF_ERROR_BUSY)
      if (ECHOBACK_BLE_UART_DATA) {
        ret_code_t err_code = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
        if (err_code != NRF_SUCCESS) {
          NRF_LOG_ERROR("Failed to echo back data: 0x%x", err_code);
        // Send data back to the peripheral.
        do {
          ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
            NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
            printf("Failed sending NUS message. Error\r\n");
    void uart_event_handle(app_uart_evt_t *p_event) {
      static uint16_t index = 0;
      uint32_t ret_val;
      switch (p_event->evt_type) {
      /**@snippet [Handling data from UART] */
        index++;
            (index >= (m_ble_nus_max_data_len))) {
          printf("Ready to send data over BLE NUS\r\n");
          do {
            ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
            if ((ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES)) {
            printf("Failed to send data!!\r\n");
          } while (ret_val == NRF_ERROR_RESOURCES);
          index = 0;
        NRF_LOG_ERROR("Communication error occurred while handling UART.");
        printf("Communication error occurred while handling UART.\r\n");
      case APP_UART_FIFO_ERROR:
        NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
        printf("Error occurred in FIFO module used by UART.\r\n");
    static void ble_nus_c_evt_handler(ble_nus_c_t *p_ble_nus_c, ble_nus_c_evt_t const *p_ble_nus_evt) {
      switch (p_ble_nus_evt->evt_type) {
      case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
        NRF_LOG_INFO("Discovery complete.");
        printf("Discovery complete.\r\n");
        err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
        err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
        NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        printf("Connected to device with Nordic UART Service.\r\n");
      case BLE_NUS_C_EVT_NUS_TX_EVT:
        ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
      case BLE_NUS_C_EVT_DISCONNECTED:
        NRF_LOG_INFO("Disconnected.");
        printf("Disconnected.\r\n");
        scan_start();
    //Peripheral side:
    static void nus_data_handler(ble_nus_evt_t *p_evt) {
      memset(BLEDataBuff, 0, sizeof(BLEDataBuff));
      if (p_evt->type == BLE_NUS_EVT_RX_DATA) {
        uint32_t err_code;
        uint32_t ResponseCode = 0;
        char TempData[64];
        printf("Received data from BLE NUS. Writing data on UART.\r\n");
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++) {
          BLEDataBuff[i] = (p_evt->params.rx_data.p_data[i]);
        printf("\nBLEDataBuff : %s\n ", BLEDataBuff);
    void send_data_via_nus(float X, float Y, ble_nus_t nus_service) {
      uint8_t data[8];
      memcpy(data, &X, sizeof(X));
      memcpy(data + sizeof(X), &Y, sizeof(Y));
      uint16_t length = sizeof(X) + sizeof(Y);
      err_code = ble_nus_data_send(&m_nus, data, &length, m_conn_handle);
      if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND)) {
    void uart_handler(app_uart_evt_t *p_event) {
      if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR) {
        printf("entered in uart communication error\n");
      } else if (p_event->evt_type == APP_UART_FIFO_ERROR) {
        printf("entered in uart fifo error\n ");
      else if (p_event->evt_type == APP_UART_DATA_READY) {
        UNUSED_VARIABLE(app_uart_get(&uart_receive[UartDataCount++]));
        printf("uart : %s\n", uart_receive);
    int main(void) {
      bool erase_bonds;
      uart_init();
      log_init();
      timers_init();
      ble_stack_init();
      gap_params_init();
      gatt_init();
      services_init();
      advertising_init();
      conn_params_init();
      advertising_start();
      uint16_t length;
      while (1) {
        if (strlen(uart_receive)) {
          printf("uart_receive : %s\n", uart_receive);
          length = strlen(uart_receive);
          ble_nus_data_send(&m_nus, uart_receive, &length, m_conn_handle);
          memset(uart_receive, 0, sizeof(uart_receive));
          UartDataCount = 0;
        nrf_delay_ms(1000);
     code
    Have you verified the central has sent back the data ?
    I would suggest to use the BLE sniffer. You can learn how to use the sniffer here.
    We need to see if the central actually send it over the air.
  • yes,
    central has sent back the data.
    see the log messages:
    Rec:(13:22:09)BLE UART central example started.
    ATT MTU exchange completed.
    Ble NUS max data length set to 0xF4(244)
    Discovery complete.
    Rec:(13:22:20)Receiving data.
    1
    Send:(13:22:23) 7
    Rec:(13:22:23)uart : 7
    when central send integer 7 and it send back successfully.
    but peripheral not receives the same data.
