nrf52832 central and peripheral string send issue
hi destiny98 i also working on sending string from peripheral to central but central device not able to receive it and show the same message every time, here i attach code snippet, please guide me to resolve this issue.
another thing is that i am use ble_app_hrs_c for central device and ble_app_hrs for peripheral device and make modification in it as i need, here i attach my both code also.
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
 * @brief Heart Rate Service Sample Application main file.
 * This file contains the source code for a sample application using the Heart Rate service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
//=========================================Modify Peripheral Code=================================================================
#include "app_error.h"
#include "app_timer.h"
#include "ble.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
#include "ble_dis.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_hrs.h"
#include "ble_srv_common.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdm.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "sensorsim.h"
#include <stdint.h>
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME "PR_007"                    /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300                    /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG 1  /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81                              /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100                             /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT 1                         /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL APP_TIMER_TICKS(1000) /**< Heart rate measurement interval (ticks). */
#define MIN_HEART_RATE 140                             /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE 300                             /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT 10                        /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL APP_TIMER_TICKS(300) /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL 100                       /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL 500                       /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT 1                   /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL APP_TIMER_TICKS(5000) /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(400, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(650, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY 0                                    /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)   /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define LESC_DEBUG_MODE 0 /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND 1                               /**< Perform bonding. */
#define SEC_PARAM_MITM 0                               /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 1                               /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS 0                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0                                /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16                      /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_HRS_DEF(m_hrs);                       /**< Heart rate service instance. */
BLE_BAS_DEF(m_bas);                       /**< Structure used to identify the battery service. */
NRF_BLE_GATT_DEF(m_gatt);                 /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                   /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);       /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id);        /**< Battery timer. */
APP_TIMER_DEF(m_heart_rate_timer_id);     /**< Heart rate measurement timer. */
APP_TIMER_DEF(m_rr_interval_timer_id);    /**< RR interval timer. */
APP_TIMER_DEF(m_sensor_contact_timer_id); /**< Sensor contact detected timer. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static bool m_rr_interval_enabled = true;                /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t m_battery_sim_cfg;         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;     /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t m_heart_rate_sim_cfg;      /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state;  /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t m_rr_interval_sim_cfg;     /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state; /**< RR Interval sensor simulator state. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
        {BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}};
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void) {
  ret_code_t err_code;
  NRF_LOG_INFO("Erase bonds!");
  err_code = pm_peers_delete();
void advertising_start(bool erase_bonds) {
  if (erase_bonds == true) {
    delete_bonds();
    // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
  } else {
    err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const *p_evt) {
  pm_handler_on_pm_evt(p_evt);
  pm_handler_disconnect_on_sec_failure(p_evt);
  pm_handler_flash_clean(p_evt);
  switch (p_evt->evt_id) {
    advertising_start(false);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void) {
  uint8_t battery_level;
  battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
  err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
  if ((err_code != NRF_SUCCESS) &&
      (err_code != NRF_ERROR_INVALID_STATE) &&
      (err_code != NRF_ERROR_BUSY) &&
      (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)) {
    APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void *p_context) {
  UNUSED_PARAMETER(p_context);
  battery_level_update();
/**@brief Function for handling the Heart rate measurement timer timeout.
 * @details This function will be called each time the heart rate measurement timer expires.
 *          It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(void *p_context) {
  char message[] = "hello slave";
  uint16_t length = strlen(message);
  ble_gatts_hvx_params_t hvx_params = {
      .handle = m_hrs.hrm_handles.value_handle, // Use the correct value handle
      .type = BLE_GATT_HVX_NOTIFICATION,        // Notification type
      .offset = 0,
      .p_len = &length,             // Pointer to message length
      .p_data = (uint8_t *)message, // Pointer to the message data
  err_code = sd_ble_gatts_hvx(m_conn_handle, &hvx_params);
  if (err_code == NRF_SUCCESS) {
    NRF_LOG_INFO("Message sent: %s", message);
  } else {
    NRF_LOG_ERROR("Failed to send message: 0x%x", err_code);
/**@brief Function for handling the RR interval timer timeout.
 * @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(void *p_context) {
  if (m_rr_interval_enabled) {
    uint16_t rr_interval;
    rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
        &m_rr_interval_sim_cfg);
    ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer timeout.
 * @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(void *p_context) {
  static bool sensor_contact_detected = false;
  sensor_contact_detected = !sensor_contact_detected;
  ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void) {
  // Initialize timer module.
  err_code = app_timer_init();
  // Create timers.
  err_code = app_timer_create(&m_battery_timer_id,
      APP_TIMER_MODE_REPEATED,
      battery_level_meas_timeout_handler);
  err_code = app_timer_create(&m_heart_rate_timer_id,
      heart_rate_meas_timeout_handler);
  err_code = app_timer_create(&m_rr_interval_timer_id,
      rr_interval_timeout_handler);
  err_code = app_timer_create(&m_sensor_contact_timer_id,
      sensor_contact_detected_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
static void gap_params_init(void) {
  ble_gap_conn_params_t gap_conn_params;
      (const uint8_t *)DEVICE_NAME,
      strlen(DEVICE_NAME));
  err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
  gap_conn_params.slave_latency = SLAVE_LATENCY;
  gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt) {
  if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED) {
    NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
        p_evt->conn_handle,
        p_evt->params.att_mtu_effective);
  ble_hrs_on_gatt_evt(&m_hrs, p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void) {
  ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
static void nrf_qwr_error_handler(uint32_t nrf_error) {
  APP_ERROR_HANDLER(nrf_error);
 * @details Initialize the Heart Rate, Battery and Device Information services.
static void services_init(void) {
  ble_hrs_init_t hrs_init;
  ble_bas_init_t bas_init;
  ble_dis_init_t dis_init;
  uint8_t body_sensor_location;
  // Initialize Heart Rate Service.
  body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
  memset(&hrs_init, 0, sizeof(hrs_init));
  hrs_init.evt_handler = NULL;
  hrs_init.is_sensor_contact_supported = false;
  hrs_init.p_body_sensor_location = &body_sensor_location;
  // Here the sec level for the Heart Rate Service can be changed/increased.
  hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
  hrs_init.bsl_rd_sec = SEC_OPEN;
  err_code = ble_hrs_init(&m_hrs, &hrs_init);
  // Initialize Battery Service.
  memset(&bas_init, 0, sizeof(bas_init));
  bas_init.evt_handler = NULL;
  bas_init.support_notification = true;
  bas_init.p_report_ref = NULL;
  bas_init.initial_batt_level = 100;
  // Here the sec level for the Battery Service can be changed/increased.
  bas_init.bl_rd_sec = SEC_OPEN;
  bas_init.bl_cccd_wr_sec = SEC_OPEN;
  bas_init.bl_report_rd_sec = SEC_OPEN;
  err_code = ble_bas_init(&m_bas, &bas_init);
  // Initialize Device Information Service.
  memset(&dis_init, 0, sizeof(dis_init));
  ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
  dis_init.dis_char_rd_sec = SEC_OPEN;
  err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void) {
  m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
  m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
  m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
  m_battery_sim_cfg.start_at_max = true;
  sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
  m_heart_rate_sim_cfg.min = MIN_HEART_RATE;
  m_heart_rate_sim_cfg.max = MAX_HEART_RATE;
  m_heart_rate_sim_cfg.incr = HEART_RATE_INCREMENT;
  m_heart_rate_sim_cfg.start_at_max = false;
  sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
  m_rr_interval_sim_cfg.min = MIN_RR_INTERVAL;
  m_rr_interval_sim_cfg.max = MAX_RR_INTERVAL;
  m_rr_interval_sim_cfg.incr = RR_INTERVAL_INCREMENT;
  m_rr_interval_sim_cfg.start_at_max = false;
  sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void) {
  // Start application timers.
  // err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
  // APP_ERROR_CHECK(err_code);
  err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
  err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
  err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
  if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
/**@brief Function for handling a Connection Parameters error.
static void conn_params_error_handler(uint32_t nrf_error) {
static void conn_params_init(void) {
  cp_init.p_conn_params = NULL;
  cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
  cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
  cp_init.start_on_notify_cccd_handle = m_hrs.hrm_handles.cccd_handle;
  cp_init.disconnect_on_fail = false;
  cp_init.evt_handler = on_conn_params_evt;
  cp_init.error_handler = conn_params_error_handler;
static void sleep_mode_enter(void) {
  // Prepare wakeup buttons.
static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
  switch (ble_adv_evt) {
  case BLE_ADV_EVT_FAST:
    NRF_LOG_INFO("Fast advertising.");
  case BLE_ADV_EVT_IDLE:
    sleep_mode_enter();
static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
  switch (p_ble_evt->header.evt_id) {
  case BLE_GAP_EVT_CONNECTED:
    // NRF_LOG_INFO("Connected.");
    NRF_LOG_INFO("Connected. Hello_I_am_Central_Device!!");
    err_code = pm_conn_secure(p_ble_evt->evt.gap_evt.conn_handle, false);
    if (err_code != NRF_ERROR_BUSY) {
    NRF_LOG_INFO("Disconnected, reason %d.",
        p_ble_evt->evt.gap_evt.params.disconnected.reason);
  case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
    ble_gap_phys_t const phys =
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
  } break;
  case BLE_GATTC_EVT_TIMEOUT:
  case BLE_GATTS_EVT_TIMEOUT:
    NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
  case BLE_GAP_EVT_AUTH_KEY_REQUEST:
    NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
  case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
    NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
  case BLE_GAP_EVT_AUTH_STATUS:
    NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
        p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
        p_ble_evt->evt.gap_evt.params.auth_status.bonded,
        p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
        *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
        *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
    // No implementation needed.
static void ble_stack_init(void) {
  uint32_t ram_start = 0;
  // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
void bsp_event_handler(bsp_event_t event) {
  switch (event) {
  case BSP_EVENT_SLEEP:
    sleep_mode_enter();
  case BSP_EVENT_DISCONNECT:
    if (err_code != NRF_ERROR_INVALID_STATE) {
  case BSP_EVENT_WHITELIST_OFF:
    // if (m_conn_handle == BLE_CONN_HANDLE_INVALID)
    if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
      NRF_LOG_WARNING("Invalid connection handle. Cannot send message.");
      return;
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void) {
  err_code = pm_init();
  sec_param.bond = SEC_PARAM_BOND;
  sec_param.mitm = SEC_PARAM_MITM;
  sec_param.lesc = SEC_PARAM_LESC;
  sec_param.keypress = SEC_PARAM_KEYPRESS;
  sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
  sec_param.oob = SEC_PARAM_OOB;
  sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
  sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
  sec_param.kdist_own.enc = 1;
  sec_param.kdist_own.id = 1;
  sec_param.kdist_peer.enc = 1;
  sec_param.kdist_peer.id = 1;
static void advertising_init(void) {
  ble_advertising_init_t init;
  init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
  init.advdata.include_appearance = true;
  init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
  init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
  init.advdata.uuids_complete.p_uuids = m_adv_uuids;
  init.config.ble_adv_fast_enabled = true;
  init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
static void buttons_leds_init(bool *p_erase_bonds) {
  bsp_event_t startup_event;
  err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void) {
static void power_management_init(void) {
static void idle_state_handle(void) {
  err_code = nrf_ble_lesc_request_handler();
  if (NRF_LOG_PROCESS() == false) {
    nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
int main(void) {
  bool erase_bonds;
  // Initialize.
  log_init();
  timers_init();
  power_management_init();
  ble_stack_init();
  gap_params_init();
  gatt_init();
  advertising_init();
  services_init();
  sensor_simulator_init();
  conn_params_init();
  peer_manager_init();
  // Start execution.
  NRF_LOG_INFO("Heart Rate Sensor example started.");
  application_timers_start();
  advertising_start(erase_bonds);
  // Enter main loop.
  for (;;) {
    idle_state_handle();
 * @brief BLE Heart Rate Collector application main file.
 * This file contains the source code for a sample heart rate collector.
//====================================================Central Modify Code========================================================
#include "app_util.h"
#include "ble.h"
#include "ble_bas_c.h"
#include "ble_db_discovery.h"
#include "ble_hrs_c.h"
#include "fds.h"
#include "nrf_ble_scan.h"
#include "nrf_fstorage.h"
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#define APP_SOC_OBSERVER_PRIO 1 /**< Applications' SoC observer priority. You shouldn't need to modify this value. */
#define SEC_PARAM_MIN_KEY_SIZE 7                       /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE 16                      /**< Maximum encryption key size in octets. */
#define SCAN_DURATION_WITELIST 3000 /**< Duration of the scanning in units of 10 milliseconds. */
//#define TARGET_UUID                 BLE_UUID_HEART_RATE_SERVICE         /**< Target device uuid that application is looking for. */
#define CUSTOM_SERVICE_UUID 0x03, 0xB8, 0x0E, 0x5A, 0xED, 0xE8, 0x4B, 0x33, 0xA7, 0x51, 0x6C, 0xE3, 0x4E, 0xC4, 0xC7, 0x00
#define CUSTOM_CHARACTERISTIC_UUID 0x77, 0x72, 0xE5, 0xDB, 0x38, 0x68, 0x41, 0x12, 0xA1, 0xA9, 0xF2, 0x66, 0x9D, 0x10, 0x6B, 0xF3
// The descriptor UUID 0x2902 is a 16-bit UUID for the Client Characteristic Configuration Descriptor
#define CCCD_UUID 0x2902
// Define the target UUID as your custom service UUID
#define TARGET_UUID CUSTOM_SERVICE_UUID
static ble_uuid128_t custom_service_uuid = {
    .uuid128 = {CUSTOM_SERVICE_UUID}};
static ble_uuid128_t custom_characteristic_uuid = {
    .uuid128 = {CUSTOM_CHARACTERISTIC_UUID}};
// The CCCD UUID is already defined in the SDK, you can use BLE_UUID_DESCRIPTOR_CLIENT_CHAR_CONFIG
/**@brief Macro to unpack 16bit unsigned UUID from octet stream. */
#define UUID16_EXTRACT(DST, SRC) \
  do {                           \
    (*(DST)) = (SRC)[1];         \
    (*(DST)) <<= 8;              \
    (*(DST)) |= (SRC)[0];        \
  } while (0)
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
    NRF_SDH_BLE_CENTRAL_LINK_COUNT,
    NRF_BLE_GQ_QUEUE_SIZE);
BLE_HRS_C_DEF(m_hrs_c);          /**< Structure used to identify the heart rate client module. */
BLE_BAS_C_DEF(m_bas_c);          /**< Structure used to identify the Battery Service client module. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);        /**< Scanning module instance. */
static uint16_t m_conn_handle;           /**< Current connection handle. */
static bool m_whitelist_disabled;        /**< True if whitelist has been temporarily disabled. */
static bool m_memory_access_in_progress; /**< Flag to keep track of ongoing operations on persistent memory. */
/**< Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_param =
        .active = 0x01,
#if (NRF_SD_BLE_API_VERSION > 7)
        .interval_us = NRF_BLE_SCAN_SCAN_INTERVAL * UNIT_0_625_MS,
        .window_us = NRF_BLE_SCAN_SCAN_WINDOW * UNIT_0_625_MS,
#else
        .interval = NRF_BLE_SCAN_SCAN_INTERVAL,
        .window = NRF_BLE_SCAN_SCAN_WINDOW,
#endif // (NRF_SD_BLE_API_VERSION > 7)
        .filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
        .timeout = SCAN_DURATION_WITELIST,
        .scan_phys = BLE_GAP_PHY_1MBPS,
/**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
 *  if these are set to empty strings, the UUIDs defined below will be used
static char const m_target_periph_name[] = "PR_007"; /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
static bool is_connect_per_addr = false;             /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
static ble_gap_addr_t const m_target_periph_addr =
        /* Possible values for addr_type:
           BLE_GAP_ADDR_TYPE_PUBLIC,
           BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
           BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
           BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
        .addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
        .addr = {0x8D, 0xFE, 0x23, 0x86, 0x77, 0xD9}};
static void scan_start(void);
/**@brief Function for asserts in the SoftDevice.
 * @param[in] p_file_name  File name of the failing ASSERT call.
  app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Heart Rate Service Client and Battery Service Client errors.
static void service_error_handler(uint32_t nrf_error) {
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t *p_evt) {
  ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
  ble_bas_on_db_disc_evt(&m_bas_c, p_evt);
    // Bonds are deleted. Start scanning.
    scan_start();
 * @brief Function for shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event) {
  switch (event) {
  case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
  return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
  ble_gap_evt_t const *p_gap_evt = &p_ble_evt->evt.gap_evt;
  case BLE_GAP_EVT_CONNECTED: {
    // Discover peer's services.
    err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
    if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT) {
      scan_start();
  } break;
  case BLE_GAP_EVT_DISCONNECTED: {
    NRF_LOG_INFO("Disconnected, reason 0x%x.",
        p_gap_evt->params.disconnected.reason);
      scan_start();
  } break;
  case BLE_GAP_EVT_TIMEOUT: {
    if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN) {
      NRF_LOG_INFO("Connection Request timed out.");
  } break;
  case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
    // Accepting parameters requested by peer.
    err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
        &p_gap_evt->params.conn_param_update_request.conn_params);
  } break;
/**@brief SoftDevice SoC event handler.
 * @param[in]   evt_id      SoC event.
 * @param[in]   p_context   Context.
static void soc_evt_handler(uint32_t evt_id, void *p_context) {
  switch (evt_id) {
  case NRF_EVT_FLASH_OPERATION_SUCCESS:
    /* fall through */
  case NRF_EVT_FLASH_OPERATION_ERROR:
    if (m_memory_access_in_progress) {
      m_memory_access_in_progress = false;
      scan_start();
  ble_uuid_t uuid;
  uint8_t uuid_type;
  // Add the custom service UUID to the BLE stack's table
  sd_ble_uuid_vs_add(&custom_service_uuid, &uuid_type);
  // Set up the UUID structure
  uuid.type = uuid_type;
  uuid.uuid = 0; // The least significant 16 bits of the UUID
  // Use this UUID structure when scanning for or connecting to your custom service
  // Register handlers for BLE and SoC events.
  NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
/** @brief Clear bonding information from persistent storage
/**@brief Function for disabling the use of whitelist for scanning.
static void whitelist_disable(void) {
  if (!m_whitelist_disabled) {
    NRF_LOG_INFO("Whitelist temporarily disabled.");
    m_whitelist_disabled = true;
    nrf_ble_scan_stop();
    scan_start();
  switch (event) {
    nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    whitelist_disable();
/**@brief Heart Rate Collector Handler.
static void hrs_c_evt_handler(ble_hrs_c_t *p_hrs_c, ble_hrs_c_evt_t *p_hrs_c_evt) {
  switch (p_hrs_c_evt->evt_type) {
  case BLE_HRS_C_EVT_HRM_NOTIFICATION: {
    uint8_t *data = (uint8_t *)p_hrs_c_evt->params.hrm.rr_intervals;
    uint16_t length = p_hrs_c_evt->params.hrm.rr_intervals_cnt;
    if (length > 0) {
      char message[20];
      memcpy(message, data, length);
      message[length] = '\0'; // Null-terminate the string
      NRF_LOG_INFO("Received message: %s", message);
    } else {
      NRF_LOG_WARNING("Invalid message length: %d", length);
  } break;
    NRF_LOG_INFO("Unhandled HRS client event: %d", p_hrs_c_evt->evt_type);
/**@brief Battery level Collector Handler.
// static void bas_c_evt_handler(ble_bas_c_t * p_bas_c, ble_bas_c_evt_t * p_bas_c_evt)
//     ret_code_t err_code;
//    switch (p_bas_c_evt->evt_type)
//        case BLE_BAS_C_EVT_DISCOVERY_COMPLETE:
//            err_code = ble_bas_c_handles_assign(p_bas_c,
//                                                p_bas_c_evt->conn_handle,
//                                                &p_bas_c_evt->params.bas_db);
//            // Battery service discovered. Enable notification of Battery Level.
//            NRF_LOG_DEBUG("Battery Service discovered. Reading battery level.");
//            err_code = ble_bas_c_bl_read(p_bas_c);
//            NRF_LOG_DEBUG("Enabling Battery Level Notification.");
//            err_code = ble_bas_c_bl_notif_enable(p_bas_c);
//        } break;
//        case BLE_BAS_C_EVT_BATT_NOTIFICATION:
//            //NRF_LOG_INFO("Battery Level received %d %%.", p_bas_c_evt->params.battery_level);
//            NRF_LOG_INFO("HELLO_CENTRAL_I_AM_PERIPHERAL_PR_007");
//            break;
//        case BLE_BAS_C_EVT_BATT_READ_RESP:
//            //NRF_LOG_INFO("Battery Level Read as %d %%.", p_bas_c_evt->params.battery_level);
//            break;
//        default:
//            break;
 * @brief Heart rate collector initialization.
static void hrs_c_init(void) {
  ble_hrs_c_init_t hrs_c_init_obj;
  hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
  hrs_c_init_obj.error_handler = service_error_handler;
  hrs_c_init_obj.p_gatt_queue = &m_ble_gatt_queue;
  ret_code_t err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
 * @brief Battery level collector initialization.
// static void bas_c_init(void)
//     ble_bas_c_init_t bas_c_init_obj;
//    bas_c_init_obj.evt_handler   = bas_c_evt_handler;
//    bas_c_init_obj.error_handler = service_error_handler;
//    bas_c_init_obj.p_gatt_queue  = &m_ble_gatt_queue;
//    ret_code_t err_code = ble_bas_c_init(&m_bas_c, &bas_c_init_obj);
 * @brief Database discovery collector initialization.
static void db_discovery_init(void) {
  ble_db_discovery_init_t db_init;
  memset(&db_init, 0, sizeof(db_init));
  db_init.evt_handler = db_disc_handler;
  db_init.p_gatt_queue = &m_ble_gatt_queue;
  ret_code_t err_code = ble_db_discovery_init(&db_init);
/**@brief Retrieve a list of peer manager peer IDs.
 * @param[inout] p_peers   The buffer where to store the list of peer IDs.
 * @param[inout] p_size    In: The size of the @p p_peers buffer.
 *                         Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t *p_peers, uint32_t *p_size) {
  pm_peer_id_t peer_id;
  uint32_t peers_to_copy;
  peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ? *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
  peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
  *p_size = 0;
  while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--)) {
    p_peers[(*p_size)++] = peer_id;
    peer_id = pm_next_peer_id_get(peer_id);
static void whitelist_load() {
  ret_code_t ret;
  pm_peer_id_t peers[8];
  uint32_t peer_cnt;
  memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
  peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
  // Load all peers from flash and whitelist them.
  peer_list_get(peers, &peer_cnt);
  ret = pm_whitelist_set(peers, peer_cnt);
  APP_ERROR_CHECK(ret);
  // Setup the device identies list.
  // Some SoftDevices do not support this feature.
  ret = pm_device_identities_list_set(peers, peer_cnt);
  if (ret != NRF_ERROR_NOT_SUPPORTED) {
static void on_whitelist_req(void) {
  // Whitelist buffers.
  ble_gap_addr_t whitelist_addrs[8];
  ble_gap_irk_t whitelist_irks[8];
  memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
  memset(whitelist_irks, 0x00, sizeof(whitelist_irks));
  uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
  uint32_t irk_cnt = (sizeof(whitelist_irks) / sizeof(ble_gap_irk_t));
  // Reload the whitelist and whitelist all peers.
  whitelist_load();
  // Get the whitelist previously set using pm_whitelist_set().
  err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
      whitelist_irks, &irk_cnt);
  if (((addr_cnt == 0) && (irk_cnt == 0)) ||
      (m_whitelist_disabled)) {
    // Don't use whitelist.
    err_code = nrf_ble_scan_params_set(&m_scan, NULL);
/**@brief Function to start scanning.
static void scan_start(void) {
  if (nrf_fstorage_is_busy(NULL)) {
    m_memory_access_in_progress = true;
    return;
  NRF_LOG_INFO("Starting scan.");
  err_code = nrf_ble_scan_start(&m_scan);
  err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for initializing the power management module. */
  case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED: {
        p_evt->conn_handle,
  } break;
  case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED: {
    NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
        p_evt->conn_handle,
        p_evt->params.data_length);
  } break;
static void scan_evt_handler(scan_evt_t const *p_scan_evt) {
  switch (p_scan_evt->scan_evt_id) {
  case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST: {
    on_whitelist_req();
    m_whitelist_disabled = false;
  } break;
  case NRF_BLE_SCAN_EVT_CONNECTING_ERROR: {
    err_code = p_scan_evt->params.connecting_err.err_code;
  } break;
  case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT: {
    NRF_LOG_INFO("Scan timed out.");
    scan_start();
  } break;
  case NRF_BLE_SCAN_EVT_FILTER_MATCH:
  case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
/**@brief Function for initializing the timer.
static void timer_init(void) {
/**@brief Function for initialization scanning and setting filters.
static void scan_init(void) {
  nrf_ble_scan_init_t init_scan;
  ble_uuid_t uuid;
  uint8_t uuid_type;
  memset(&init_scan, 0, sizeof(init_scan));
  init_scan.p_scan_param = &m_scan_param;
  init_scan.connect_if_match = true;
  init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
  err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
  // ble_uuid_t uuid =
  //     .uuid = TARGET_UUID,
  //     .type = BLE_UUID_TYPE_BLE,
  err_code = nrf_ble_scan_filter_set(&m_scan,
      SCAN_UUID_FILTER,
      &uuid);
  if (strlen(m_target_periph_name) != 0) {
        SCAN_NAME_FILTER,
        m_target_periph_name);
  if (is_connect_per_addr) {
        SCAN_ADDR_FILTER,
        m_target_periph_addr.addr);
  err_code = nrf_ble_scan_filters_enable(&m_scan,
      NRF_BLE_SCAN_ALL_FILTER,
      false);
 * @details Handle any pending log operation(s), then sleep until the next event occurs.
  NRF_LOG_FLUSH();
  nrf_pwr_mgmt_run();
/**@brief Function for starting a scan, or instead trigger it from peer manager (after
 *        deleting bonds).
 * @param[in] p_erase_bonds Pointer to a bool to determine if bonds will be deleted before scanning.
void scanning_start(bool *p_erase_bonds) {
  // Start scanning for peripherals and initiate connection
  // with devices that advertise GATT Service UUID.
  if (*p_erase_bonds == true) {
    // Scan is started by the PM_EVT_PEERS_DELETE_SUCCEEDED event.
    delete_bonds();
  } else {
    scan_start();
int main(void) {
  bool erase_bonds;
  // Initialize.
  log_init();
  timer_init();
  ble_stack_init();
  gatt_init();
  db_discovery_init();
  hrs_c_init();
  // bas_c_init();
  scan_init();
  // Start execution.
  NRF_LOG_INFO("Heart Rate collector example started.");
  scanning_start(&erase_bonds);
  // Enter main loop.
  for (;;) {
if (length > 0) {
char message[20];
} else {
} break;
