Unable to Flash Blinky Sketch
Using Visual Studio Code as IDE with installed nrf SDK v2.9.0 on MacOS Sequoia 15.2
Terminal reads -
* Executing task: nRF Connect: Build: blinky/blinky (active)
Building blinky
west build --build-dir /Users/<UserID>/nrfworkspace/blinky/build_1/blinky /Users/<UserID>/nrfworkspace/blinky
ninja: no work to do.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Flash: blinky/blinky (active)
Flashing blinky to Blooper
west flash -d /Users/<UserID>/nrfworkspace/blinky/build_1/blinky --skip-rebuild --dev-id XXXXXXXX --erase
-- west flash: using runner nrfutil
-- runners.nrfutil: mass erase requested
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Flashing file: /Users/<UserID>/nrfworkspace/blinky/build_1/merged.hex
Usage: nrfutil [OPTIONS] COMMAND [ARGS]...
Try 'nrfutil --help' for help.
Error: no such option: --json
-- runners.nrfutil: Board with serial number XXXXXXXX flashed successfully.
How to get around this ?
    This indicates that the board is flashed. Can you let me know if the blinky application is running or not on the DK?
    Is the --json option listed when invoking "nrfutil -h" in an nRF Connect terminal? For example, the output I get for nrfutil v7.13.0 from the nRF Connect terminal in VS Code is below.
    PS C:\ncs\v2.9.0> nrfutil -h
    nrfutil
    Usage:
        nrfutil [+MODIFIER] [OPTIONS] [SUBCOMMAND]
    Options:
          --log-level <LOG_LEVEL>    Set the maximum log level [env: NRFUTIL_LOG=] [possible values: off, error, warn, info, debug, trace]
          --log-output <LOG_OUTPUT>  Set log output type: --log-output=stdout --log-output=file ... [possible values: file, stdout]
          --json                     Print output in a JSON Lines format
          --json-pretty              Print output as formatted JSON
          --skip-overhead            Skip all message overhead when in JSON output mode, outputting only the data part of "info" messages and ignoring the rest
          --changelog                Print the latest changelog entry
          --changelog-full           Print the full changelog
      -V, --version
          --help-extended            Show comprehensive documentation
          --license                  Show license information for in-built dependencies
          --detect-proxy             Invoke libproxy's 'proxy' utility program to retrieve proxy server info and use it
      -h, --help                     Print help (see more with '--help')
    Built-in nrfutil commands (see installed commands with `list`):
      help             Show comprehensive documentation
      install          Download and install nrfutil commands
      upgrade          Upgrade nrfutil commands to the latest version
      uninstall        Uninstall nrfutil commands [aliases: remove]
      prepare-offline  Prepare local package and resource repositories for offline installs of nrfutil commands
      search           Search for installable nrfutil commands in the package index
      list             List installed nrfutil commands
      self-upgrade     Upgrades the nrfutil core functionality to the latest version
      config           Interact with the main nrfutil configuration
    To see which version of nrfutil you have installed, run "nrfutil --version".
    Maria
  • No, it seems the board finished flashing but the hex file is never actually uploaded. It seems to me that something is wrong here -
     % nrfutil -h
    Error: no such option: -h
     % nrfutil --help
    Options:
      -v, --verbose            Increase verbosity of output. Can be specified more
                               than once (up to -v -v -v -v).
      -o, --output <filename>  Log output to file
      --help                   Show this message and exit.
    Commands:
      dfu       Perform a Device Firmware Update over serial, BLE, Thread, Zigbee
                or ANT transport given a DFU package (zip file).
      keys      Generate and display private and public keys.
      pkg       Display or generate a DFU package (zip file).
      settings  Generate and display Bootloader DFU settings.
      version   Display nrfutil version.
      zigbee    Zigbee-related commands and utilities.
     % nrfutil --version
    Error: no such option: --version
     % nrfutil version
    nrfutil version 5.2.0
  • I realised that I had a wrong version of nrfutil and needed to upgrade to the latest. I downloaded the file from here - NRF Util
    I followed the instruction on the page to also download commands such as 'nrf5sdk-tools' and 'device'.
    The version of pyYaml also needed upgrading to get 'west' working again.
    I needed another problem fixing in the meantime as I also had a version of nrfjprog which had some permission issue and could only be operated by sudo. I downgraded the utility to 10.24.0.  With this also handled all the boards can now be flashed normally.
  • Thank you for sharing your solution!
    Maria
