Trouble Connecting to nRF5340 via nRFConnect Extension (WSL Environment)
Hi all,
I've been using the nRFConnect extension without any issues, successfully connecting to my nRF5340 board via JLink, flashing firmware, and receiving printed messages using the RTT extension. However, I encountered a problem today: I can no longer connect or upload firmware to the board.
Here’s the error message I received:
FATAL ERROR: command exited with status 33: nrfjprog --recover -f NRF53 --coprocessor CP_NETWORK --snr 260116832
I use WSL and rely on tools like USBPID to enable USB connections from my hardware to the Linux environment. In my debugging attempts, I searched for similar issues and encountered this thread. Following its suggestions, I tested the RTT connection, and while the RTT interface connected, it didn’t function as expected.
These are the screenshots of what I got from the Jlinkexe and RTTClient:
I couldn't find any similar issues in this forum and wanted to know if this was a known issue or how to troubleshoot and get more information about the source of the problem itself. Thank you in advance for any help!
    I haven't tested using the linux version of nrfjprog, jlinkexe etc. in WSL with USBPID. Instead when using WSL I have replaced the executables for nrfjprog and JLinkExe in /usr/bin with scripts that instead use the windows versions of the tools from within WSL. This has the benefit of not needing to pass the USB device over to the linux environment to connect to them.
    Here's the scripts for replacing nrfjprog and JLinkExe with the windows tools:
    /usr/bin/JLinkExe:
    #!/bin/bash
    ARGS=("$@")
    JLINKEXE='/mnt/c/Program Files/SEGGER/JLink/JLink.exe'
    WSLROOT='\\wsl$\Ubuntu'
    for IDX in ${!ARGS[*]}; do
            ARG=${ARGS[$IDX]}
            case "$ARG" in
                    if [ -e "$ARG" ]; then
                            NEW=$(wslpath -aw "$ARG" 2>/dev/null) || \
                            NEW="$WSLROOT"$(readlink -f "$ARG" | sed 's@/@\\@g')
                            ARGS[$IDX]=$NEW
                    fi
            esac
    done
    exec "$JLINKEXE" "${ARGS[@]}"
    /usr/bin/nrfjprog:
    #!/bin/bash
    ARGS=("$@")
    NRFJPROG='/mnt/c/Program Files/Nordic Semiconductor/nrf-command-line-tools/bin/nrfjprog.exe'
            ARG=${ARGS[$IDX]}
            case "$ARG" in
                            ARGS[$IDX]=$NEW
                    fi
            esac
    done
    exec "$NRFJPROG" "${ARGS[@]}"
    The scrips need to be set as a executable using chmod +x /usr/bin/nrfjprog /usr/bin/JLinkExe
    I also recommend to rename the existing executables before replacing them, incase you need to revert the changes.
    It should be possible to do the same for other CLI tools, but these are the only ones I have tested.
    This approach requires nRF-Command-Line-Tools and SEGGER JLink to be installed on the host windows system.
    Bendik
  • Hi Bendik,
    Thank you for your quick response!
    Before changing the WSL configuration, I tested the Windows version of the SEGGER JLink and nRF Command Line Tools to check if the connection with the device was possible.
    I tested JLink separately, and similar to WSL, I couldn’t connect to the device using either JTAG or SWD. (See attached images.)
    To rule out potential configuration issues, I attempted to upload firmware to the board using the command line tools but encountered the same problem.
    The respective log file is attached here.
    [2025-Jan-07 10:39:48] [debug] --------------------------------------------------------------------------------
    [2025-Jan-07 10:39:48] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --reset --log
    [2025-Jan-07 10:39:48] [debug] nrfjprog version 10.24.2 external
    [2025-Jan-07 10:39:48] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2025-Jan-07 10:39:48] [ info] Library loaded, loading member functions.
    [2025-Jan-07 10:39:48] [ info] Member functions succesfully loaded.
    [2025-Jan-07 10:39:48] [debug] [ Client] - open
    [2025-Jan-07 10:39:48] [debug] [ Client] - start
    [2025-Jan-07 10:39:48] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 934ffcd1-cd0a-4f75-8f5d-cf8551868c4b.
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2025-Jan-07 10:39:48] [debug] [  JLink] - Logger sink registered in JLink logger
    [2025-Jan-07 10:39:48] [debug] [  nRFXX] - open
    [2025-Jan-07 10:39:48] [debug] [  nRFXX] - just_check_family
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - open_dll
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2025-Jan-07 10:39:48] [trace] [ Client] - Command open executed for 61 milliseconds with result 0
    [2025-Jan-07 10:39:48] [debug] [ Client] - config
    [2025-Jan-07 10:39:48] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2025-Jan-07 10:39:48] [debug] [ Client] - enum_emu_snr
    [2025-Jan-07 10:39:48] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V812\JLink_x64.dll.
    [2025-Jan-07 10:39:48] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2025-Jan-07 10:39:48] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - Set batch mode
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - dll_version
    [2025-Jan-07 10:39:48] [ info] [SeggerBackend] - Segger dll version 8.12.  loaded.
    [2025-Jan-07 10:39:48] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
    [2025-Jan-07 10:39:48] [debug] [  nRFXX] - config
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - enum_emu_snr
    [2025-Jan-07 10:39:48] [trace] [ Worker] - Command config executed for 3 milliseconds with result 0
    [2025-Jan-07 10:39:48] [debug] [  nRFXX] - enum_emu_con_info
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - enum_emu_con_info
    [2025-Jan-07 10:39:48] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2025-Jan-07 10:39:48] [debug] [ Client] - connect_to_emu_with_snr
    [2025-Jan-07 10:39:48] [trace] [ Worker] - Command enum_emu_con_info executed for 3 milliseconds with result 0
    [2025-Jan-07 10:39:48] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_get_num_emus
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - Segger logging enabled.
    [2025-Jan-07 10:39:48] [trace] [  JLink] - Firmware: J-Link V10 compiled Jan 30 2023 11:28:07
    [2025-Jan-07 10:39:48] [trace] [  JLink] - Decompressing FW timestamp took 125 us
    [2025-Jan-07 10:39:48] [trace] [  JLink] - Hardware: V10.10
    [2025-Jan-07 10:39:48] [trace] [  JLink] - S/N: 260116832
    [2025-Jan-07 10:39:48] [trace] [  JLink] - OEM: SEGGER-EDU
    [2025-Jan-07 10:39:48] [trace] [  JLink] - Feature(s): FlashBP, GDB
    [2025-Jan-07 10:39:48] [trace] [  JLink] - Bootloader: (FW returned invalid version)
    [2025-Jan-07 10:39:48] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2025-Jan-07 10:39:48] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2025-Jan-07 10:39:48] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2025-Jan-07 10:39:48] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V812\JLinkGUIServer.exe
    [2025-Jan-07 10:39:48] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V812\JLinkGUIServer.exe
    [2025-Jan-07 10:39:48] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.12 "
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 39.176ms returns "O.K."
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_HasError()
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_Lock()
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.001ms returns 0x01
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.002ms returns 0x00
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.003ms returns 0x00
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.011ms returns 0
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.755ms returns 0x00
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2025-Jan-07 10:39:48] [trace] [  JLink] - 180000000 Hz / n, n >= 12
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.008ms
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 15000kHz
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.127ms
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_GetSpeed()
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.003ms returns 2000
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_GetSN()
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.013ms returns 260116832
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.005ms
    [2025-Jan-07 10:39:48] [debug] [  nRFXX] - read_device_family
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_IsOpen()
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.003ms returns 0x01
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - read_debug_port_idr
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - read_debug_port_register
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - coresight_configure
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.204ms returns 0
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 100.501ms returns 0
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.863ms returns -1
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.943ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.878ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.854ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.857ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.831ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.907ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.920ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.887ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.928ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.810ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.844ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.768ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.858ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.784ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.813ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.755ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.910ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.856ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.806ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.735ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.739ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.850ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.764ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.803ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.688ms returns -1
    [2025-Jan-07 10:39:48] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 204 milliseconds with result -102
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.690ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.780ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.776ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.805ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.678ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.653ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.819ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.792ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.650ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.747ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.703ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.719ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.783ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.077ms
    [2025-Jan-07 10:39:48] [error] [ Worker] - An unknown error.
    [2025-Jan-07 10:39:48] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 198 milliseconds with result -102
    [2025-Jan-07 10:39:48] [debug] [  nRFXX] - close
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.018ms returns 0x01
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - close
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - disconnect_from_emu
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - is_connected_to_device
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_IsConnected()
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.008ms returns FALSE
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.663ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.555ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.583ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.640ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.585ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.524ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.556ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.477ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.490ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.553ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.488ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.520ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.484ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.542ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.485ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.518ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.562ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.464ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.478ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.457ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.514ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.482ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.625ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.580ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.489ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.515ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.481ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.513ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.476ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.687ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.588ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.646ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.629ms returns -1
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.624ms returns -1
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2025-Jan-07 10:39:48] [trace] [  JLink] - - 0.043ms
    [2025-Jan-07 10:39:48] [trace] [  JLink] - JLINK_Close()
    [2025-Jan-07 10:39:48] [debug] [SeggerBackend] - Segger Backend closed.
    [2025-Jan-07 10:39:48] [debug] [  nRFXX] - nRF family DLL closed
    [2025-Jan-07 10:39:48] [trace] [ Client] - Command close executed for 90 milliseconds with result 0
    [2025-Jan-07 10:39:48] [debug] [ Client] - terminate
    [2025-Jan-07 10:39:48] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2025-Jan-07 10:39:48] [trace] [ Worker] - Command close executed for 73 milliseconds with result 0
    [2025-Jan-07 10:39:48] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2025-Jan-07 10:39:48] [trace] [ Worker] - Executed 6 commands for 281 milliseconds
    [2025-Jan-07 10:39:48] [debug] [ Client] - Worker process exited with code: 0
    [2025-Jan-07 10:39:48] [debug] [ Client] - Child process terminated with result 0
    [2025-Jan-07 10:39:48] [trace] [ Client] - Executed 6 commands for 385 milliseconds
    I re-checked the USB cable, tag-connect cable, and other hardware components. Everything appears to be in working order. Interestingly, the board restarts after a failed connection, suggesting a connection attempt is being made.
    Are there any additional tests or debugging steps you’d recommend to identify the issue?
    I appreciate your support!
    Valentin.
  • I also tested downgrading the Jlink Software/Driver version  (8.12, 8.10l, 8.10k) just in case this affects the interaction with the microcontroller, and I have the same issue.
