Hi all
I want to add a small antenna to nrf52840 chip
Which part and how I can use it?
Is it any tutorial or reference?
Hi all
Hi katrin,
How small do you need the antenna to be? The smallest solution is probably a chip-antenna. We generallly do not provide recommendations, however, the prototyping platforms, Thingy:53, Thingy:91 X and Thingy:91 are all using small chip-antennas and will provide you with some examples. The BOM is available in the hardware files for example, Thingy:91 hardware files (there are two BOM-folders in the .zip files, look in PCA****->Production files->BOM).
Please see the nRF52840 Dongle for an example showing a small PCB-antenna. You may copy the antenna from the dongle hardware files, just keep in mind this antenna needs to be tuned for your specific custom PCB + casing. If you make the antenna a little bit longer than what you need you can tune it by cutting the PCB and shortening the trace.
PCB-antennas are said to provide more flexibility for tuning, however, chipantennas are widely used as well.
i want a small antenna that can be implement in a 5mm * 5mm pcb, PCB antennas require large space
You can look for a 2.4Ghz 50ohm chip antenna.
they need large space
this pic is a sample
