I added my own overlay to the website routine "ncs-fund\v2.8.x-v2.7.0\l5\l5_e1_sol". The contents are as follows
Not tried it, but for test you can at least try to remove the "hw-flow-control" in case RTS/CTS is not handled properly, also make sure that the RXD pin is pulled high (else it will trigger framing errors). Last comment, I can see two pins are by default used by led, have you also disabled those in the devicetree?
https://docs.nordicsemi.com/bundle/ug_nrf54l15_dk/page/UG/nRF54L15_DK/hw_desription/connector_if.html
Kenneth
Is there any example of self-built board test serial port on NRF54L15PDK.There seems to be a slight difference between the 54 series and the 52 series, and I think the external connection test serial port has been trying to fail
Dtcong
Think,
I found the problem.When configuring serial port flow control for the 54 series, pull up the CTS and RX configurations in the default state.
Dtcong
