Setting appropriate BLE Event Length with KCONFIG
I am currently on a project where we have 4 BLE peripheral devices equipped with NRF52840 connecting to one BLE Central, which is an app on iOS or Android. From time to time the peripherals need to send a higher amount of data to the central. The four peripherals send this data at the same time.
In most cases this works well, however, from time to time I see issues, where one of the four peripherals is sending data much slower.
I think this correlates to an issue with the BLE Parameters, which I would like to optimize for my use case. However, from the documentation as well as other discussion on here I have hard times understanding the relationship between the following parameters:
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE
CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT
In the following discussion How to set up NCS so that the Bluetooth connection interval can always send data - Nordic Q&A - Nordic DevZone - Nordic DevZone it is explained that CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT controls the event length.
In another discussion BLE multiple connection overlap - Nordic Q&A - Nordic DevZone - Nordic DevZone only CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is mentioned in relation with the event extension. However, here it is used from my perspective falsely as CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT.
My questions:
Q1: As the second discussion irritated me: What is the purpose of BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE? Will this allow to override the Event Length during runtime. How does the event length override working? Is there an example?
Q2: Are the Config options only effective for devices configured as central or will they also have an effect on peripherals?
Thanks
    My mistake in the second thread you link to, think I have fixed it now, but quickly commenting here also:
    1. I think the intention was that setting BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE=y will allow to update "override" default CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=something. Though, on second look I can't seem to find any reference to BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE in code or examples, and after asking internally I don't think the setting BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE=y actually does anything, I think it might have been used for some internal testing at some point. So as you already indicate, just setting BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT is sufficient.
    2. They should affect both roles yes.
    Sorry for the confusion,
    Kenneth
