Can't download code to NRF52832 chip
I have made my own NRF52832 Dev board as in the next image:
I received the board, and ICs and hand-soldered them in my home.
however, I am still a newbie in nRF SDK, I started watching https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/ video series, I have followed along, used blinky app as in the course and entered the following build configuration for the board:
after the build was successful, I used the "merged.hex" output file and I am trying to download it manually into the board using a j-link.
here is the log of me trying to download the code onto the board:
License(s): FlashBP, GDB
USB speed mode: Full speed (12 MBit/s)
VTref=3.295V
Type "connect" to establish a target connection, '?' for help
J-Link>connect
Please specify device / core. <Default>: NRF52832_XXAA
Type '?' for selection dialog
Device>
Please specify target interface:
  J) JTAG (Default)
  S) SWD
  T) cJTAG
TIF>S
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>
Device "NRF52832_XXAA" selected.
Connecting to target via SWD
InitTarget() start
InitTarget() end - Took 2.90ms
Found SW-DP with ID 0x2BA01477
DPIDR: 0x2BA01477
CoreSight SoC-400 or earlier
Scanning AP map to find all available APs
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011)
AP[1]: JTAG-AP (IDR: 0x02880000)
Iterating through AP map to find AHB-AP to use
AP[0]: Skipped. Could not read AHB ROM register
AP[1]: Skipped. Not an AHB-AP
Attach to CPU failed. Executing connect under reset.
DPIDR: 0x2BA01477
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
Found Cortex-M4 r0p1, Little endian.
Cortex-M: The connected J-Link (S/N 801045859) uses an old firmware module: V1 (current is 2)
FPUnit: 6 code (BP) slots and 2 literal slots
CoreSight components:
ROMTbl[0] @ E00FF000
[0][0]: E000E000 CID B105E00D PID 000BB00C SCS-M7
[0][1]: E0001000 CID B105E00D PID 003BB002 DWT
[0][2]: E0002000 CID B105E00D PID 002BB003 FPB
[0][3]: E0000000 CID B105E00D PID 003BB001 ITM
[0][4]: E0040000 CID B105900D PID 000BB9A1 TPIU
[0][5]: E0041000 CID B105900D PID 000BB925 ETM
Memory zones:
  Zone: "Default" Description: Default access mode
Cortex-M4 identified.
J-Link>loadfile C:\Users\User\Downloads\merged.hex
'loadfile': Performing implicit reset & halt of MCU.
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
Downloading file [C:\Users\User\Downloads\merged.hex]...
****** Error: Failed to preserve target RAM @ 0x20000000-0x2000FFFF.
Failed to prepare for programming.
Unspecified error -1
J-Link>
I don't know what "Error: Failed to preserve target RAM @ 0x20000000-0x2000FFFF." mean but what makes me sure the IC is working is that I can halt the CPU and get the registers content as in the following log:
J-Link>halt
PC = EFFFFFFE, CycleCnt = 00000000
R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
R12= 00000000
SP(R13)= FFFFFFFC, MSP= FFFFFFFC, PSP= 00000000, R14(LR) = 7FFFFFFF
XPSR = FFFFFFFE: APSR = NZCVQ, EPSR = 0700FC00, IPSR = 01E (INTISR14)
CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00
FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000
FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000
FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000
FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000
FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000
FPSCR= 00000000
J-Link>
UPDATE: I upgraded J-link firmware and got this error (it seems the same thing but more specific):
J-Link>loadfile C:\Users\User\Downloads\merged2.hex
Downloading file [C:\Users\User\Downloads\merged2.hex]...
****** Error: Verification of RAMCode failed @ address 0x200000A4.
Write: 0xBDF21C18 F0009800
Read: 0x5DF21C18 F0009800
Failed to download RAMCode!
I tried command 'nrfjprog --recover' and got the following response
Recovering device. This operation might take 30s.
Erasing user code and UICR flash areas.
then used the command 'nrfjprog -f NRF52 --program merged.hex --sectorerase'
and got the response:
[ #################### ]   0.323s | Erase file - Done erasing
[error] [  nRF52] - The write access failed, but no cause could be determined.
[error] [  nRF52] - It may be due to an unaligned access, accessing a nonexistent memory, or a communication issue.
[error] [  nRF52] - Failed while performing 'Write' operation on target address 0x00000000.
-102: An unknown error.
[error] [  nRF52] - Failed while reading device information.
[error] [ Client] - Encountered error -102: Command program_file executed for 374 milliseconds with result -102
[error] [ Worker] - An unknown error.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
PS C:\Users\User\Downloads> nrfjprog --recover
[error] [  JLink] - DAP error while reading AIRCR.
I tried to write and read into RAM memory region and it was successful:
I then tried to do the same for Flash, I couldn't read memory on the first trial, and then on the second trial I could read it successfully. I don't know what may cause that.
J-Link>Mem8 0x0000000020000000
Syntax: mem8 <Addr>, <NumBytes>
J-Link>Mem8 0x0000000020000000, 2
20000000 = 6F 8D
J-Link>Write1 0x0000000020000000, 0xff
Writing FF -> 20000000
20000000 = FF 8D
J-Link>Mem8 0x0000000000000000,2
00000000 = 80 16
J-Link>Write1 0x0000000000000000, 0xff
Writing FF -> 00000000
Could not read memory.
J-Link>Mem8 0x0000000000000000,4
00000000 = FF 16 00 20
00000000 = FF 16
J-Link>
another update, as shown in the image, it seems as if it works with my black magic probe but doesn't work with my segger j-link:
    It sounds a bit random the behaviour and in those cases we start with having a look at the power supply of the device and the programmer. It does seem like you've gotten your setup to work, but I suspect there's a voltage difference between your board and the Segger device. It might allow for RAM and registers to be read, but not reliably Flash memory. This can be handled better either by luck, more similar voltage, the "Balc magic probe" able to deliver more current or there's level shifters involved on the second programmer.
    Have you checked the voltages between the programmer and device? Is it the same or close? Are you still seeing problems with your setup?
    Best regards
    Asbjørn
  • I don't know how a "voltage difference between your board and Segger device" can occur. Both grounds of the 2 boards are connected, and all of the signals are 3.3V signals. And yes, there are level shifters on the black magic probe side. I really don't know what caused this problem but it's working with my black magic probe. So, I guess I am happy with it.
