How to use http_client or https_client to send a post message to my web server?
Hello!
I threw away the Sparkfun board and replaced it with a nRF9151DK board; I'm hoping to get it work now, after trying for a year.
I'm using SDK 2.6.1 and 2.8.0; the default is SDK 2.8.0.
My setup:
Updated Windows 11.
Onomondo SIM.
I built https_client from a sample and it worked; but, when I changed the URL to "">https://ptsv3.com," it stopped working, although the idea is to send an HTTP(S) post message to my web server, which includes a path and the receiver PHP program.
I did not include the build log or code because I could not post it; perhaps the post was too large, but a serial terminal image
Also, which library should I use to remove these errors?
*- error: unknown type name 'u32t'
*- error: unknown type name 'u8t'
With kind regards
  • I guess, "HTTPS_HOSTNAME" doesn't support a "path" element as you used ("https://" + HTTPS_HOSTNAME + "/t/mypts123/post/"). I didn't test it on my own, but I guess, if you add a "HTTPS_PATH" ("/t/mypts123/post/") as separate definition and use both in "HTTP_HEAD", the "getaddrinfo" with a pure "HTTPS_HOSTNAME" ("ptsv3.com") may have a chance to work.
  • Thanks for the information. Where can I see the whole header parameters? I added this:
    #define HTTP_HEAD   \
                "HEAD / HTTP/1.1\r\n"   \
                "Host: " CONFIG_HTTPS_HOSTNAME ":" HTTPS_PORT "\r\n"    \
                "Connection: close\r\n\r\n"     \
                "HTTPS_PATH: /t/mypts123/post"
    It is Ok to set HTTPS_PATH: os it is HTTPS_PATH, where can I see it?
    Are the following rows useful at all?
                "Content-type: text/plain\r\n"  \
                "Content-Length: 14"
                {"Hello word"}
    Also, the program https_client employs 89% Flash, and I need to integrate GNSS to provide geolocation while posting a message
    I don't require SSL at all.
    What am i doing wrong?
    with kind regards
    Francisco
  • There is no http-header "HTTPS_PATH: /t/mypts123/post", so that doesn't work.
    Replace:
    "Host: " HTTPS_HOSTNAME ":" HTTPS_PORT "\r\n"    \
    by
    #define HTTPS_HOSTNAME "ptsv3.com"
    #define HTTPS_PATH "/t/mypts123/post"
    "Host: " HTTPS_HOSTNAME ":" HTTPS_PORT HTTPS_PATH  "\r\n"    \
    edited:
    Just as background info:
    DNS uses hostnames, e.g. "ptsv3.com", but no URI as
    https://ptsv3.com/t/mypts123/post
    The sample only offers a very simple function, I'm not sure, if that is the right place to start for you.
    Anyway, I'm just an other user. Maybe you get better advice from someone else.
  • Hello, Achim Kraus. I value your assistance as a user.
    As I still have questions; I'm hoping a Nordic engineer can help.
    Why do I have to press the reset button to get some letters, or even rows of text? from the board?
    Say, in the attached image, the output text required three resets.
    How can I include a payload with the post message?
    With warm regards
    Francisco
  • Some more answers (still not complete):
    Build it with:
    west build -b nrf9151dk/nrf9151/ns -p
    requires about 11% of the flash.
    Sometimes the modem requires some time for tasks. e.g. searching a network may require up to 1-2 minutes.
    That mainly means, not using "IPPROTO_TLS_1_2" and instead "IPPROTO_TCP". Also change the port form 443 to 80 an don't call "tls_setup".
    There is also a http-client in zephyr, see http_client . That may be easier, but I'm not common with it, I'm using CoAP/DTLS 1.2 CID.
