ANT shared channel broadcast reverse does not work correctly
Hi, i'm newbie to ANT world and i'm trying to create a mesh-like network using broadcast messages and shared channel with nRF51422 SoC and S310 soft-device.
So, i created channel on transmitter with this configuration:
  • TRANSMISSION TYPE = 0x01
  • DEVICE_TYPE = 0x2
  • DEVICE_NUMBER = 0x02
  • CHANNEL_PERIOD = 16384 (4 Hz)
  • FREQUENCY = 66 (2425 MHz)
  • NETWORK_NUMBER = 0x00
  • CHANNEL_TYPE = SHARED MASTER
On receiver i used same configuration with CHANNEL_TYPE = SHARED SLAVE.
Master creates the channel and slaves open the channel and then send a broadcast message to setup their shared address (with different addresses, obviously).
My goal is to send broadcast messages from master to slaves (2 slave nodes) and slaves have to respond with different data.
Actually slave nodes receive correctly the broadcast messages from the master but master receive broadcast responses only from the nearest slave (i think that is the slave that have the highest TX power).
So what is the problem? Is that an interference or a packet collision?
Thank you and regards.
