vscode extension can not found the sdk in macOS
    My VSCode extension is not working now. could you please give me some advice? thanks!
    1.<Manange toolchains> could not display and select the toolchanis version
    2.<Manage SDKs> could not found any sdk which been installed by itself
    3. after open an exiting application, there is nothing show in nrf connet extention window
env:
macOS: 15.2
VSCode: 1.96.2
nrf connect vscode extention pack: 2024.95
    I can check with the vs code extension team, but first can you generate the support information by clicking on the headset icon?
    Kenneth
  • sure, please see the json file:
    // IMPORTANT: The following data can contain sensitive or confidential information about your environment.
    // If you do not want others to see this information, make sure to remove it before sharing the data.
    // For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "darwin",
        "osVersion": "Darwin Kernel Version 24.2.0: Fri Dec  6 19:02:41 PST 2024; root:xnu-11215.61.5~2/RELEASE_ARM64_T6030",
        "osKernel": "24.2.0",
        "vscode": "1.96.3",
        "electron": "32.2.6",
        "node": "v20.18.1"
      "system": {
        "date": "2025-01-14T08:18:25.403Z",
        "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
        "nrfConnectForDesktopInstalled": false,
        "vscodeUptime": "00:00:11",
        "osUptime": "289:22:49",
        "cpu": "Apple M3 Pro"
      "workspace": {
        "name": null,
        "workspaceFile": null,
        "folders": []
      "sdks": [],
      "apps": [],
      "toolchains": [
          "version": "2.9.0",
          "path": "/opt/nordic/ncs/toolchains/b8efef2ad5"
          "version": "2.7.0",
          "path": "/opt/nordic/ncs/toolchains/f8037e9b83"
      "connectedDevices": [],
      "tools": {
        "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.17.0 (arm64)",
        "/Applications/SEGGER/JLink/JLinkExe": "7.94i (x64,arm64)",
        "/usr/local/bin/nrfjprog": "10.24.2 (x64,arm64)",
        "/usr/local/bin/nrfutil": "7.13.0 (arm64)",
        "/opt/nordic/ncs/toolchains/b8efef2ad5/bin/cmake": "3.21.0 (arm64)",
        "/opt/nordic/ncs/toolchains/b8efef2ad5/bin/west": "1.2.0",
        "/opt/nordic/ncs/toolchains/b8efef2ad5/bin/python3": "3.12.4 (arm64)",
        "/opt/nordic/ncs/toolchains/b8efef2ad5/bin/ninja": "1.10.2 (arm64)",
        "/opt/nordic/ncs/toolchains/b8efef2ad5/bin/gperf": "3.1 (arm64)",
        "/opt/nordic/ncs/toolchains/b8efef2ad5/bin/dtc": "1.6.1 (arm64)",
        "/opt/nordic/ncs/toolchains/b8efef2ad5/bin/gn": "2202 (arm64)",
        "/opt/nordic/ncs/toolchains/b8efef2ad5/bin/git": "2.37.3 (arm64)",
        "arm-gdbPath": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb",
        "riscv-gdbPath": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/riscv64-zephyr-elf/bin/riscv64-zephyr-elf-gdb"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.7.2",
          "binPath": "/Users/gaojin/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.12.55-darwin-arm64/platform/nrfutil/bin/nrfutil-device",
          "jlinkInfo": {
            "name": "JlinkARM",
            "version": "JLink_V7.94i",
            "versionFormat": "string"
        "nrfutil-toolchain-manager": {
          "version": "0.14.4",
          "binPath": "/Users/gaojin/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.12.55-darwin-arm64/platform/nrfutil/bin/nrfutil-toolchain-manager"
      "environment": {
        "westEnv": {
          "GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/git/2.37.3/libexec/git-core",
          "HOME": "/Users/gaojin",
          "PATH": "/opt/nordic/ncs/toolchains/b8efef2ad5/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/usr/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/usr/local/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/opt/homebrew/bin:/Applications/CMake.app/Contents/bin:/opt/anaconda3/bin:/opt/anaconda3/condabin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/opt/homebrew/bin:/Applications/CMake.app/Contents/bin:/opt/anaconda3/bin:/opt/anaconda3/condabin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin",
          "ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk",
          "USER": "gaojin"
        "inherited": {
          "ELECTRON_RUN_AS_NODE": "1",
          "PATH": "/opt/homebrew/bin:/Applications/CMake.app/Contents/bin:/opt/anaconda3/bin:/opt/anaconda3/condabin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin",
          "USER": "gaojin"
      "terminal": {
        "defaultProfile": null
      "config": {
          "topdir": "",
          "toolchain": {
            "path": ""
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": false
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": true,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": null
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask",
          "terminalProfile": {
            "shell": null
          "terminalMode": "character"
      "extensions": {
        "internal": {
            "version": "2024.12.55",
            "path": "/Users/gaojin/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.12.55-darwin-arm64",
            "isActive": true
            "version": "2024.9.14",
            "path": "/Users/gaojin/.vscode/extensions/nordic-semiconductor.nrf-terminal-2024.9.14",
            "isActive": true
            "version": "2024.12.15",
            "path": "/Users/gaojin/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2024.12.15",
            "isActive": true
            "version": "2024.12.13",
            "path": "/Users/gaojin/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2024.12.13",
            "isActive": true
        "external": {
          "marus25.cortex-debug": null,
          "ms-vscode.cpptools": "1.22.11",
          "ms-vscode.js-debug": "1.96.0",
          "MS-CEINTL.vscode-language-pack-zh-hans": "1.96.2024121109",
          "ms-python.debugpy": "2024.14.0",
          "ms-python.python": "2024.22.2",
          "ms-python.vscode-pylance": "2024.12.1",
          "twxs.cmake": "0.0.17"
    We think the problem might be related to (chinese?) firewall, do you have the possibility to try with a VPN? There might be network calls to GitHub in those commands that are timing out.
    If that is not the problem, then we can see that /opt/nordic/ncs is owned by root, but not your user. Can you delete /opt/nordic and start from clean slate?
    Kenneth
  • Yes, I have a VPN, but it still have an error code exited below:
    [west]: ERROR: update failed for projects: suit-generator, suit-processor, cmock, memfault-firmware-sdk, coremark, canopennode, cmsis-dsp, fatfs, hal_nordic, hostap, libmetal
    [west]: exited with code 1.
    and i finished all repository by "west update"
    also, I delete /opt/nordic by command "sudo rm -r /opt/nordic" , then redo the installing process, the owner of folders show below:
    and the problem is still there.
      "platform": {
        "os": "darwin",
        "vscode": "1.96.3",
        "node": "v20.18.1"
      "system": {
        "date": "2025-01-15T00:39:32.490Z",
        "vscodeUptime": "16:21:18",
        "osUptime": "305:43:56",
      "workspace": {
        "name": null,
        "folders": []
      "sdks": [],
      "apps": [],
      "toolchains": [
          "version": "2.9.0",
      "tools": {
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.7.2",
          "jlinkInfo": {
            "name": "JlinkARM",
      "environment": {
        "westEnv": {
          "USER": "gaojin"
        "inherited": {
          "USER": "gaojin"
      "terminal": {
      "config": {
          "topdir": "",
          "toolchain": {
            "path": ""
          "ozonePath": "",
          "applications": [],
          "kconfig": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": false
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
            "indexURL": null,
          "nrfutil": {
            "home": null
            "shell": null
      "extensions": {
        "internal": {
            "isActive": true
            "isActive": true
            "isActive": true
            "isActive": true
        "external": {
  • After set the full disk access permission to enable of vscode, and delete /opt/nordic folder, reinstall toolchain and sdk by nrf connect vscode extentions, the problem is gone!
