I have a device with 3 major components:
- Fanstel nrf52840
- PMIC1300
- spi display (Waveshare 2.13inch E-Ink Display)
PMIC:
- BUCK1: power Fanstel
- BUCK2: power display
- I'm not using the LDO's
I would like to control power to the display. Normally I would put a MOSFET on the ground line of the display and control the gate with a gpio.
Instead of a MOSFET, can I turn BUCK2 on and off in firmware to control power to the display? Any examples?
/* * Copyright (c) 2023 Nordic Semiconductor ASA * * SPDX-License-Identifier: LicenseRef-Nordic-5-Clause */ / { /* The timer instance to use. */ chosen { ncs,dm-timer = &timer2; }; /* The selected pins will be used by Distance Measurement module for debug purposes. */ dm_gpio { compatible = "gpio-leds"; dm_ranging: dm-ranging { gpios = <&gpio0 27 GPIO_ACTIVE_LOW>; label = "DM Ranging Pin"; }; dm_add_request: dm-add-request { gpios = <&gpio0 26 GPIO_ACTIVE_LOW>; label = "DM Add request Pin"; }; }; // &gpio0 10 (and &gpio0 9) causes ASSERTION FAIL??? dm_leds { compatible = "gpio-leds"; dm_led0: dm-led0 { gpios = <&gpio0 15 GPIO_ACTIVE_LOW>; label = "GDM Test LED"; }; }; }; /* * Copyright (C) 2023 Nordic Semiconductor ASA * SPDX-License-Identifier: Apache-2.0 */ #include <dt-bindings/regulator/npm1300.h> #include <zephyr/dt-bindings/input/input-event-codes.h> &arduino_i2c { npm1300_ek_pmic: pmic@6b { compatible = "nordic,npm1300"; reg = <0x6b>; // long-press-reset = "one_button"; // ship-to-active-time = <96>; npm1300_ek_gpio: gpio-controller { compatible = "nordic,npm1300-gpio"; gpio-controller; #gpio-cells = <2>; ngpios = <5>; }; npm1300_ek_regulators: regulators { compatible = "nordic,npm1300-regulator"; npm1300_ek_buck1: BUCK1 { regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; // regulator-init-microvolt = <3000000>; regulator-init-microvolt = <3300000>; retention-microvolt = <3300000>; }; npm1300_ek_buck2: BUCK2 { regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3400000>; // regulator-init-microvolt = <1800000>; regulator-init-microvolt = <3300000>; retention-microvolt = <3300000>; }; // npm1300_ek_ldo1: LDO1 { // regulator-min-microvolt = <1000000>; // regulator-max-microvolt = <3300000>; // regulator-initial-mode = <NPM1300_LDSW_MODE_LDSW>; // // soft-start-microamp = <20000>; // }; // npm1300_ek_ldo2: LDO2 { // regulator-min-microvolt = <1000000>; // regulator-max-microvolt = <3300000>; // regulator-initial-mode = <NPM1300_LDSW_MODE_LDSW>; // // soft-start-microamp = <20000>; // }; }; npm1300_ek_charger: charger { compatible = "nordic,npm1300-charger"; term-microvolt = <4100000>; term-warm-microvolt = <4200000>; // term-current-percent = <10>; current-microamp = <100000>; // trickle-microvolt = <2500000>; dischg-limit-microamp = <1340000>; vbus-limit-microamp = <500000>; thermistor-ohms = <10000>; thermistor-beta = <3380>; // disable-recharge; charging-enable; }; npm1300_ek_leds: leds { compatible = "nordic,npm1300-led"; nordic,led0-mode = "error"; nordic,led1-mode = "charging"; nordic,led2-mode = "host"; }; }; }; &arduino_header { gpio-map = <0 0 &gpio0 3 0>, <1 0 &gpio0 4 0>, <2 0 &gpio0 28 0>, <3 0 &gpio0 29 0>, <4 0 &gpio0 30 0>, <5 0 &gpio0 31 0>, <6 0 &gpio1 1 0>, <7 0 &gpio1 2 0>, <8 0 &gpio1 3 0>, <9 0 &gpio1 4 0>, <10 0 &gpio1 5 0>, <11 0 &gpio1 6 0>, <12 0 &gpio1 7 0>, <13 0 &gpio1 8 0>, <14 0 &gpio1 10 0>, <15 0 &gpio1 11 0>, <16 0 &gpio1 12 0>, <17 0 &gpio1 13 0>, <18 0 &gpio1 14 0>, <19 0 &gpio1 15 0>, <20 0 &gpio0 26 0>, <21 0 &gpio0 27 0>; }; /* npm1300_fule_guage */ &i2c0_default { group1 { bias-pull-up; }; };
