I'm migrating code from ncs 2.7 to 2.9.
I am using CONFIG_BT_EXT_ADV and scan timeout callback - such timeout requires CONFIG_BT_EXT_ADV: RE: nRF Connect SDK Scan Timeout
It was working fine. Now it's no more. Scan start returns error, and this error boils down to the following code in function valid_le_scan_param() located in ncs/zephyr/subsys/bluetooth/host/scan.c
if (IS_ENABLED(CONFIG_BT_PRIVACY) &&
param->type == BT_LE_SCAN_TYPE_ACTIVE &&
param->timeout != 0) {
/* This is marked as not supported as a stopgap until the (scan,
* adv, init) roles are reworked into proper state machines.
* Having proper state machines is necessary to be able to
* suspend all roles that use the (resolvable) private address,
* update the RPA and resume them again with the right
* parameters.
* Else we lower the privacy of the device as either the RPA
* update will fail or the scanner will not use the newly
* generated RPA.
return false;
As can be seen, timeout != 0 ends in error.
It's new condition, added somewhere between ncs 2.7 and 2.9 and I would call it regression and breaking change.
So, what's the expected path forward?
