Little problem with send data to BLE
Good afternoon.
I´m using nrf51-dk with SDK 9.0.0, s110 softdevice and uart nordic app on mobile. I have a program in my nrf51-dk that it sends and receives data between nrf51-dk and mobile device.
I want to send a data when mobile device establishes connection with my nrf51-dk, the problem is that the first time that mobile device establishes the connection doesn´t receive "Pulse c para calibra" but when I disconnect and connect again the mobile device with my nrf51-dk, it receives the data correctly.
I have modified "on_ble_evt" function.
static void on_ble_evt(ble_evt_t * p_ble_evt){
    uint32_t                         err_code;
	uint8_t instrucciones[20] =     "Pulse c para calibra";
switch (p_ble_evt->header.evt_id){
    case BLE_GAP_EVT_CONNECTED:
                                conectado = true;
                   				nrf_delay_ms(1500);
        						ble_nus_string_send(&m_nus, instrucciones, 20);
            					app_timer_start(timer_id,  APP_TIMER_TICKS(500, APP_TIMER_PRESCALER), NULL);   //10 segundos para configurar
					            conectado = false;
         						temporizador_menu = tiempo_espera_menu;
	            				limpiar_datos_recibidos_bluetooth();
        						app_timer_stop(timer_id);
                                // Pairing not supported
        // No implementation needed.
Screen of data received by mobile device:
image description
Thank you.
