Moving to 2.9.0 from 2.7.0
In 2.7.0 in file c_cpp_properties.json I had direct path to compiler. Now moving I need to change the path.
AI suggested to use ${nrf-connect.toolchain} for compiler and ${nrf-connect.sdk} for sdk.
Unlike launch.json where it works, in c_cpp_properties.json there is no way to let accect and resolve this
path.
Please do you have any suggestion?
Best Regards
  • Hi Fortunato,
    Sorry about the arbitrary changes regarding who is helping you here on this case.
    I remember there being a lot of cases about intellisense placing red squiggles everywhere in the past, but it has been a while since I've seen this problem.
    Could you show me the c_cpp_properties.json file?
    Marbro1965 said:
    I am programming in C++
    Are you not seeing this problem when using C?
    Marbro1965 said:
    but not for all the instruction. It compiles but intellisense does not work well.
    Could you show me this difference in what it reacts on?
    Elfving
    there are some images of the error and the c_cpp_properties.json.
    In the last image there are highlighted the libraries which drive intellisense crazy))).
    Thanks very much
        "configurations": [
                "name": "Win32",
                "includePath": [
                    "${workspaceFolder}/**",
                    "${config:nrf-connect.toolchain}/opt/zephyr-sdk/arm-zephyr-eabi/bin",
                    "${config:nrf-connect.toolchain}/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/include",
                    "${config:nrf-connect.toolchain}/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/include/c++/12.2.0",
                    "${config:nrf-connect.toolchain}/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/include/c++/12.2.0/arm-zephyr-eabi",
                    "${config:nrf-connect.toolchain}/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/include/c++/12.2.0/backward",
                    "${config:nrf-connect.toolchain}/opt/zephyr-sdk/arm-zephyr-eabi/lib/gcc/arm-zephyr-eabi/12.2.0/include",
                    "${config:nrf-connect.toolchain}/opt/zephyr-sdk/arm-zephyr-eabi/lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed",
                    "c:/ncs/v2.7.0/zephyr/include",
                    "c:/ncs/v2.7.0/zephyr/include/zephyr",
                    "c:/ncs/v2.7.0/nrfxlib",
                    "c:/ncs/v2.7.0/zephyr/include/zephyr/drivers",
                    "c:/ncs/v2.7.0/zephyr/include/zephyr/kernel",
                    "c:/ncs/v2.7.0/zephyr/include/zephyr/usb",
                    "c:/ncs/v2.7.0/zephyr/arch",
                    "c:/ncs/v2.7.0/nrfxlib/nrf_modem/include",
                    "c:/ncs/v2.7.0/nrf/include",
                    "c:/ncs/v2.7.0/nrf/include/modem",
                    "c:/ncs/v2.7.0/zephyr/drivers",
                    "c:/ncs/v2.7.0/zephyr/kernel",
                    "c:/ncs/v2.7.0/modules/lib/cjson",
                    "c:/ncs/v2.7.0/modules/fs/fatfs/include",
                    "c:/ncs/v2.7.0/modules/hal/nordic/nrfx",
                    "c:/ncs/v2.7.0/modules/hal/nordic/nrfx/mdk"
                "defines": [
                    "_DEBUG",
                    "UNICODE",
                    "_UNICODE",
                    "CONFIG_SYS_CLOCK_TICKS_PER_SEC=1000",
                    "ARCH_STACK_PTR_ALIGN=4"
                "configurationProvider": "nordic-semiconductor.nrf-connect",
                "compilerPath": "${config:nrf-connect.toolchain}/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe",
                "cppStandard": "gnu++11",
                "cStandard": "gnu11"
        "version": 4
  • Could you try adding "intelliSenseMode": "windows-gcc-arm"? And if that doesn't help, could you try setting the configurationProvider to "nrf-connect"? I see there is conflicting advice regarding that last one.
    Marbro1965 said:
    It works only with absolute path (2.0.9 ), but not for all the instruction. It compiles but intellisense does not work well.
    I go back to 2.7.0
    So it doesn't work perfectly with direct path either then. I guess it could be that AI was mistaken about eg. "nrf-connect.toolchain" working in c_cpp_properties.json. Though that a direct path doesn't work either makes this more interesting. What sort of instructions does it not work on?
    Elfving
