GPIO sense wakeup from system on (__WFE or __WFI) not working on nrf9160dk
Hi! I have a problem with waking up from system on using gpio interrupts. Originally I was using SYSTEM OFF and that was working fine but i also wanted to wake the system up with the RTC. Now this works on SYSTEM ON. I can specify a time and the system wakes up by an interrupt from an RTC. But now I want it to work with gpios too but for some reason it does not wake up. This is my code so far:
 * Copyright (c) 2019 Nordic Semiconductor ASA
#include <stdio.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/pm/device.h>
#include <zephyr/sys/poweroff.h>
#include <soc.h>
#include <hal/nrf_gpio.h>
#include <hal/nrf_regulators.h>
#include <modem/lte_lc.h>
#include <modem/nrf_modem_lib.h>
#include <nrfx_rtc.h>
#include <nrfx_clock.h>
#define BUSY_WAIT_S 2U
#define SLEEP_S 2U
#define NODE_SWITCH DT_ALIAS(sw0)
#define SW0_PIN 6
#define LED0_NODE DT_ALIAS(led0)
#define INPUT_PIN_NODE DT_NODELABEL(input_pin)
#define INPUT_PIN_NODE2 DT_NODELABEL(input_pin2)
#define OUTPUT_PIN_NODE DT_NODELABEL(output_pin)
// static const struct device *switch_dev = DEVICE_DT_GET(NODE_SWITCH);
static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
static const struct gpio_dt_spec input_pin = GPIO_DT_SPEC_GET(INPUT_PIN_NODE, gpios);
static const struct gpio_dt_spec input2_pin = GPIO_DT_SPEC_GET(INPUT_PIN_NODE2, gpios);
// static const struct gpio_dt_spec output_pin = GPIO_DT_SPEC_GET(OUTPUT_PIN_NODE, gpios);
static const nrfx_rtc_t rtc = NRFX_RTC_INSTANCE(0);
static void rtc_handler(nrfx_rtc_int_type_t int_type)
    if (int_type == NRFX_RTC_INT_COMPARE0)
        printk("RTC compare event\n");
    else if (int_type == NRFX_RTC_INT_TICK)
		printk("RTC tick event\n");
static void rtc_config(void)
    nrfx_err_t err_code;
    //Initialize RTC instance
	printf("RTC instance\n");
	nrfx_rtc_config_t config = NRFX_RTC_DEFAULT_CONFIG;
    err_code = nrfx_rtc_init(&rtc, &config, rtc_handler);
    if (err_code != NRFX_SUCCESS)
		printk("Error initializing RTC\n");
		k_msleep(1000);
	printf("RTC initialized\n");
    //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
    err_code = nrfx_rtc_cc_set(&rtc,0, 32768*35, true);
		printk("Error setting compare channel\n");
	printf("RTC compare channel set\n");
    //Power on RTC instance
    nrfx_rtc_enable(&rtc);
	printf("RTC enabled\n");
	uint32_t input_pin_nr = DT_GPIO_PIN(INPUT_PIN_NODE, gpios);
	uint32_t input2_pin_nr = DT_GPIO_PIN(INPUT_PIN_NODE2, gpios);
	printf("latch input pin 16 %d\n", nrf_gpio_pin_latch_get(input_pin_nr));
	printf("latch input pin 13 %d\n", nrf_gpio_pin_latch_get(input2_pin_nr));
	// Toggle LED0 ON
	int ret;
	// Output pin
	if (!gpio_is_ready_dt(&output_pin)) {
		printf("Output pin is not ready\n");
		return 0;
	ret = gpio_pin_configure_dt(&output_pin, GPIO_OUTPUT_ACTIVE);
	if (ret != 0) {
		printf("Configuring GPIO pin failed: %d\n", ret);
		return 0;
	gpio_pin_set_dt(&output_pin, 1);
	if (!gpio_is_ready_dt(&led)) {
		return 0;
	ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
	if (ret < 0) {
		return 0;
	int rc;
	const struct device *const cons = DEVICE_DT_GET(DT_CHOSEN(zephyr_console));
	if (!device_is_ready(cons)) {
		printk("%s: device not ready.\n", cons->name);
		return 0;
	printk("\n%s system off demo\n", CONFIG_BOARD);
	/* Configure to generate PORT event (wakeup) on input pin interrupt. */
	nrf_gpio_cfg_input(NRF_DT_GPIOS_TO_PSEL(INPUT_PIN_NODE, gpios),
			   NRF_GPIO_PIN_PULLUP);
	nrf_gpio_cfg_sense_set(NRF_DT_GPIOS_TO_PSEL(INPUT_PIN_NODE, gpios),
			       NRF_GPIO_PIN_SENSE_LOW);
	nrf_gpio_cfg_input(NRF_DT_GPIOS_TO_PSEL(INPUT_PIN_NODE2, gpios),
	nrf_gpio_cfg_sense_set(NRF_DT_GPIOS_TO_PSEL(INPUT_PIN_NODE2, gpios),
	//configure GPIOTE interrupt
	NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Msk;
	NVIC_EnableIRQ(GPIOTE0_IRQn);
	printk("Busy-wait %u s\n", BUSY_WAIT_S);
	k_busy_wait(BUSY_WAIT_S * USEC_PER_SEC);
	printk("Busy-wait %u s with UART off\n", BUSY_WAIT_S);
	rc = pm_device_action_run(cons, PM_DEVICE_ACTION_SUSPEND);
	rc = pm_device_action_run(cons, PM_DEVICE_ACTION_RESUME);
	printk("Sleep %u s\n", SLEEP_S);
	k_sleep(K_SECONDS(SLEEP_S));
	printk("Sleep %u s with UART off\n", SLEEP_S);
	printk("Entering system off; Waiting to be awaken from input_pin\n");
	// Turn off output pin before entering system off
	ret = gpio_pin_set_dt(&output_pin, 0);
	if (ret) {
		printf("Error setting output pin: %d\n", ret);
		return 0;
	// Toggle LED0 OFF before entering system off
	ret = gpio_pin_toggle_dt(&led);
	if (ret < 0) {
		return 0;
	// turn off the LTE modem to allow the system to enter full system off.
	printf("resetting latch\n");
	nrf_gpio_pin_latch_clear(input_pin_nr);
	nrf_gpio_pin_latch_clear(input2_pin_nr);
	rtc_config();
	nrf_modem_lib_init();
	lte_lc_power_off();
	k_msleep(1000);
    __SEV();
	__WFE();
	__WFE();
	// NRF_REGULATORS->SYSTEMOFF = 1;
	return 0;
void GPIOTE_IRQHandler(void)
    // This handler will be run after wakeup from system ON (GPIO wakeup)
    if(NRF_GPIOTE->EVENTS_PORT)
        NRF_GPIOTE->EVENTS_PORT = 0;
And this is my prj.conf:
# Required to disable default behavior of deep sleep on timeout
CONFIG_PM_DEVICE=y
CONFIG_GPIO=y
# Optional select RAM retention (nRF52 only)
#CONFIG_APP_RETENTION=y
CONFIG_CRC=y
CONFIG_POWEROFF=y
CONFIG_NRFX_RTC0=y
#Below forces us to build the nonsecure image for the nRF9160dk i.e.: "west build -p -b nrf9160dk_nrf9160ns".
CONFIG_LTE_LINK_CONTROL=y
#Below means that the modem will not automatically connect to the network on boot, you need to manually enable it of you want to connect to the network.
#Putting this to "y" will mess with the system off mode current consumption.
#If auto connect is enabled, the MCU will restart itself straight after it has entered system off mode.
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_NRF_MODEM_LIB=y
#Below is not crucial to be disabled to allow the system off mode to work.
CONFIG_DEBUG=n
CONFIG_PM_DEVICE=y
Thanks in advance!
Best,
Ray
